How do I add command line flags to a XFCE launcher in Dom0?
I installed Ungoogled Chromium and this is the default command when I create a launcher: qvm-run -q -a --service -- untrusted qubes.StartApp+ungoogled-chromium
If I add a command line flag at the end, chromium does not start anymore: qvm-run -q -a --service -- untrusted qubes.StartApp+ungoogled-chromium --js-flags=--jitless
I know that sometimes you need to use quotation marks, but I’ve tried these and it also doesn’t work: qvm-run -q -a --service -- untrusted qubes.StartApp+"ungoogled-chromium --js-flags=--jitless"
qvm-run -q -a --service -- untrusted "qubes.StartApp+ungoogled-chromium --js-flags=--jitless"
Is it possible to create a shortcut in the menu which would include flags (for example ungoogled-chromium-flagged) and then to call it via qvm-run -q -a --service -- untrusted qubes.StartApp+ungoogled-chromium-flagged?
i didn’t try this because I still don’t have UC installed.
