This Laptop used to run find under the (adapted) display resolution setting. About 4-6 weeks ago, after a dom0 update, it resulted in a blank screen.
The problem is that Qubes is unusable under the native settings as icons are tiny. Some workarounds exists but a change of the display resolution is preferred and used to work.
- 1920×1080 (native)
- 1020x720 (adapted)
Any advice?
