I’m new to Qubes and I am trying to follow the installation guide as I install the OS but I am noticing it is a outdated in a few places. There is no longer an option for the addons for Debian and Whonix in the installation process where users have to check the box, I am assuming it was probably moved to the standard install for all Qubes OS or something.
I also noticed that once you move into post-installation setup there is now two options for the Xen Hypervisor. I am new to Qubes, and new to Linux so I am just trying to make sure I don’t mess anything up. The two options are:
Xen Hypervisor, version 4.14.3
Xen Hypervisor, versions 4.14.3.config
I tried looking up information about it in the forums and across google and reddit but I dont see any information pertaining to this. I even tried looking on the Xen Hypervisor website. I am assuming I should just do the “normal” 4.14.3 option, but I want to make sure that by not choosing .config that I am not going to miss the step that allows you to choose the default “Initial Setup” Qubes. Can someone please explain what the difference between these two options is?
