I see we now use nfttables exclusively, which breaks backwards compatibility with legacy Qubes iptables scripts.
Here’s the most straightforward configuration I’ve used for a “fail closed” Wireguard tunnel in a proxyVM.
Create a ProxyVM (ensure “provides network” is checked)
/rw/config/rc.local
#!/bin/bash
# Bring up WG
wg-quick up /rw/config/wg0.conf || exit 1
##DNS forwarding
DNS=9.9.9.9 #your DNS server of choice
# Create a NAT table if not already present
nft add table ip qubes
# Add a prerouting chain for destination NAT in that table
nft add chain ip qubes nat { type nat hook prerouting priority dstnat \; }
# Add rules for tcp and udp port 53 redirecting DNS queries to the DNS IP
nft add rule ip qubes nat iifname "vif*" tcp dport 53 dnat to $DNS
nft add rule ip qubes nat iifname "vif*" udp dport 53 dnat to $DNS
Important: in the qubes firewall GUI, set “Limit outgoing connections to…” and enter (UDP) your IP address and port of the Wireguard endpoint
Put your wireguard config in /rw/config/wg0.conf
Would be useful if this were in an FAQ somewhere, or there was a script to install it, or if it was just standalone. Using nm to control wireguard tunnels seems to be a bad idea due to reports of connections dropping. Just call wg-quick directly.
Errata: This script isn’t running at startup for me, which is weird, so I run it manually. Edit: runs at startup as expected with a Debian 13 template. Seems to have been a Fedora/SeLinux issue.
