Windscribe VPN (gui) setup help
Hi Guys, this is my first time post here, looking for solution.
I set my fedora42 template and appvm up from Using Mullvad VPN on Qubes OS | PrivSec - A practical approach to Privacy and Security TommyTran732 guide, not using mullvad repo of cause, only download and install windscribe rpm package from their site, after all done I made sys-windscribe-vpn(which I name it) somehow I got disconnected every 10-15 second not sure why, maybe I could not found settings.json, and I tested these two guide from privsec.dev, mullvad and IVPN each of these have settings.json in its, so I found it every inconvenient. And also I made and other approach from Mullvad VPN App 4.3 (and 4.2) setup guide solene guide, create standalone template, still have the same problem, so anyone can help me with this?
