i have created a windows qubes and intend running whatsapp inside of that qube. is it possible that my wireless bluetooth headset that has microphone also that i can attach it to the windows qubes and hear audio and use the microphone. any solution to this?
If you have USB Bluetooth adapter then you can attach it to your Windows qube and use it there.
If you don’t have Qubes Windows Tools installed in your Windows qube then you need to enable the USB integration for this qube by running this command in dom0 terminal:
qvm-features YourWindowsQubeName stubdom-qrexec 1
Also you can use the WhatsApp in the browser or use third-party WhatsApp client in Linux qube:
WhatsApp - ArchWiki
