Hello!
My native language has some accents, and if i’m on a webpage which has accents in its title, the browser’s tab on the panel shows a “__” instead of the accented letter. For example: Here is this webpage: link. On the panel this should be appear: Épeler - French Verb Conjugation, but instead this appears on the browser’s tab at the panel: __peler - French Verb Conjugation. I’ve checked the locales in dom0 with the command locale and everything seems good, every locale is set to en_US.utf8. With this setup it works perfectly fine on other linux system. Is it something i should check and set in Qubes to work with accents?
Thanks any help!
