### Brief summary
I am having problems with a Novacustom V56 laptop when using… the Intel BE200 wifi 7 NIC.
After suspending and then resuming the system the BE200 disappears from the available
adapters in the sys-net vm.
Today I installed the system using Qubes-R4.2.4-x86_64.iso using the kernel_latest option.
I am using standard install options with my sys-net VM based off fedora-41-xfce.
The system has been patched.
Current kernel is 6.13.7-1.qubes.fc37.x86_64 (I see this matching in dom0 and sys-net)
### Steps to reproduce
Resume system after suspending the system to memory via the UI or suspend by closing the
lid.
### Expected behavior
The wireless adapter will still be present in sys-net and will reconnect to the network.
### Actual behavior
The adapter is not present.
### Additional information
I captured data from both dom0 and sys-net from when things were working before suspend, and when they weren't after suspend:
#### Before
**sys-net# dmesg | grep wifi**
<details>
> [ 3.134514] iwlwifi 0000:00:07.0: Detected crf-id 0x2001910, cnv-id 0x2001910 wfpm id 0x80000000
> [ 3.134631] iwlwifi 0000:00:07.0: PCI dev 272b/00f4, rev=0x472, rfid=0x112200
> [ 3.134655] iwlwifi 0000:00:07.0: Detected Intel(R) Wi-Fi 7 BE200 320MHz
> [ 3.266294] iwlwifi 0000:00:07.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.4.191
> [ 3.267297] iwlwifi 0000:00:07.0: loaded firmware version 94.62990553.0 gl-c0-fm-c0-94.ucode op_mode iwlmvm
> [ 3.742162] iwlwifi 0000:00:07.0: loaded PNVM version 97f4ce1a
> [ 3.762211] iwlwifi 0000:00:07.0: Detected RF FM, rfid=0x112200
> [ 3.854811] iwlwifi 0000:00:07.0: base HW address: 44:a3:bb:8d:9d:98
> [ 3.947696] iwlwifi 0000:00:07.0 wls7f0: renamed from wlan0
> [ 5.057881] iwlwifi 0000:00:07.0: Registered PHC clock: iwlwifi-PTP, with index: 1
</details>
**sys-net# lspci -vvv -s 00:07.0**
<details>
> 00:07.0 Network controller: Intel Corporation Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2 (rev 1a)
> Subsystem: Intel Corporation BE200 320MHz [Gale Peak]
> Physical Slot: 7
> Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
> Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
> Latency: 0
> Interrupt: pin A routed to IRQ 44
> Region 0: Memory at f2030000 (64-bit, non-prefetchable) [size=16K]
> Capabilities: [40] Power Management version 3
> Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
> Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
> Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
> Address: 0000000000000000 Data: 0000
> Capabilities: [70] Express (v2) Endpoint, IntMsgNum 0
> DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
> ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 10W TEE-IO-
> DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
> RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
> MaxPayload 128 bytes, MaxReadReq 512 bytes
> DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr+ TransPend-
> LnkCap: Port #0, Speed 16GT/s, Width x1, ASPM L1, Exit Latency L1 <64us
> ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
> LnkCtl: ASPM Disabled; RCB 64 bytes, LnkDisable- CommClk-
> ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
> LnkSta: Speed 16GT/s, Width x1
> TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
> DevCap2: Completion Timeout: Not Supported, TimeoutDis+ NROPrPrP- LTR+
> 10BitTagComp+ 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
> EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
> FRS- TPHComp- ExtTPHComp-
> AtomicOpsCap: 32bit- 64bit- 128bitCAS-
> DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-
> AtomicOpsCtl: ReqEn-
> IDOReq- IDOCompl- LTR- EmergencyPowerReductionReq-
> 10BitTagReq- OBFF Disabled, EETLPPrefixBlk-
> LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
> EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
> Retimer- 2Retimers- CrosslinkRes: Upstream Port
> Capabilities: [b0] MSI-X: Enable+ Count=32 Masked-
> Vector table: BAR=0 offset=00002000
> PBA: BAR=0 offset=00003000
> Kernel driver in use: iwlwifi
> Kernel modules: iwlwifi
</details>
**dom0# lspci -vvv 0s 2f:00.0**
<details>
> 2f:00.0 Network controller: Intel Corporation Device 272b (rev 1a)
> Subsystem: Intel Corporation Device 00f4
> Latency: 0, Cache Line Size: 64 bytes
> Interrupt: pin A routed to IRQ 19
> Region 0: Memory at b5500000 (64-bit, non-prefetchable) [size=16K]
> Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
> Capabilities: [70] Express (v2) Endpoint, MSI 00
> ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 10W
> DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
> RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
> LnkCtl: ASPM L1 Enabled; RCB 64 bytes, Disabled- CommClk+
> ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
> DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis+ LTR+ 10BitTagReq- OBFF Disabled,
> LnkCap2: Supported Link Speeds: 2.5-16GT/s, Crosslink- Retimer+ 2Retimers+ DRS-
> LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
> Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
> Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
> Capabilities: [100 v2] Advanced Error Reporting
> UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
> UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
> UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
> CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
> CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
> AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
> MultHdrRecCap+ MultHdrRecEn- TLPPfxPres- HdrLogCap-
> HeaderLog: 00000000 00000000 00000000 00000000
> Capabilities: [148 v1] Secondary PCI Express
> LnkCtl3: LnkEquIntrruptEn- PerformEqu-
> LaneErrStat: 0
> Capabilities: [158 v1] Physical Layer 16.0 GT/s <?>
> Capabilities: [17c v1] Lane Margining at the Receiver <?>
> Capabilities: [188 v1] Latency Tolerance Reporting
> Max snoop latency: 15728640ns
> Max no snoop latency: 15728640ns
> Capabilities: [190 v1] L1 PM Substates
> L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
> PortCommonModeRestoreTime=10us PortTPowerOnTime=14us
> L1SubCtl1: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+
> T_CommonMode=0us LTR1.2_Threshold=116736ns
> L1SubCtl2: T_PwrOn=50us
> Capabilities: [1a0 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
> Capabilities: [2a0 v1] Data Link Feature <?>
> Capabilities: [2ac v1] Precision Time Measurement
> PTMCap: Requester:+ Responder:- Root:-
> PTMClockGranularity: Unimplemented
> PTMControl: Enabled:+ RootSelected:-
> PTMEffectiveGranularity: 4ns
> Capabilities: [2b8 v1] Vendor Specific Information: ID=0003 Rev=1 Len=054 <?>
> Capabilities: [500 v1] Vendor Specific Information: ID=0023 Rev=1 Len=010 <?>
> Kernel driver in use: pciback
</details>
#### After
<details>
> [ 2947.459857] iwlwifi 0000:00:07.0: Unregistering PHC clock: iwlwifi-PTP, with index: 1
> [ 2948.154855] iwlwifi 0000:00:07.0: Detected crf-id 0x2001910, cnv-id 0x2001910 wfpm id 0x80000000
> [ 2948.154955] iwlwifi 0000:00:07.0: PCI dev 272b/00f4, rev=0x472, rfid=0x112200
> [ 2948.154967] iwlwifi 0000:00:07.0: Detected Intel(R) Wi-Fi 7 BE200 320MHz
> [ 2948.231903] iwlwifi 0000:00:07.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.4.191
> [ 2948.232866] iwlwifi 0000:00:07.0: loaded firmware version 94.62990553.0 gl-c0-fm-c0-94.ucode op_mode iwlmvm
> [ 2948.259195] ? iwl_pcie_rx_alloc+0x6f/0x300 [iwlwifi]
> [ 2948.259231] ? iwl_pcie_rx_alloc+0x6f/0x300 [iwlwifi]
> [ 2948.259245] iwl_pcie_rx_alloc+0x6f/0x300 [iwlwifi]
> [ 2948.259259] _iwl_pcie_rx_init+0x34c/0x370 [iwlwifi]
> [ 2948.259305] iwl_trans_pcie_gen2_start_fw+0x2ab/0x5f0 [iwlwifi]
> [ 2948.259326] iwl_trans_start_fw+0x41/0x60 [iwlwifi]
> [ 2948.259381] ? _iwl_dbg_tlv_time_point+0x19d/0x200 [iwlwifi]
> [ 2948.259449] ? iwl_pcie_check_hw_rf_kill+0x21/0x90 [iwlwifi]
> [ 2948.259515] _iwl_op_mode_start+0xa7/0xd0 [iwlwifi]
> [ 2948.259530] iwl_req_fw_callback+0x78b/0xab0 [iwlwifi]
> [ 2948.260724] iwlwifi 0000:00:07.0: Unable to init nic
> [ 2948.260741] iwlwifi 0000:00:07.0: Failed to start RT ucode: -12
> [ 2948.260764] iwlwifi 0000:00:07.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
> [ 2948.510631] iwlwifi 0000:00:07.0: Start IWL Error Log Dump:
> [ 2948.510656] iwlwifi 0000:00:07.0: Transport status: 0x00000042, valid: 6
> [ 2948.510674] iwlwifi 0000:00:07.0: Loaded firmware version: 94.62990553.0 gl-c0-fm-c0-94.ucode
> [ 2948.510697] iwlwifi 0000:00:07.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
> [ 2948.510714] iwlwifi 0000:00:07.0: 0x000002F0 | trm_hw_status0
> [ 2948.510730] iwlwifi 0000:00:07.0: 0x00000000 | trm_hw_status1
> [ 2948.510752] iwlwifi 0000:00:07.0: 0x002C4996 | branchlink2
> [ 2948.510766] iwlwifi 0000:00:07.0: 0x00015F80 | interruptlink1
> [ 2948.510782] iwlwifi 0000:00:07.0: 0x00015F80 | interruptlink2
> [ 2948.510798] iwlwifi 0000:00:07.0: 0x00015C56 | data1
> [ 2948.510811] iwlwifi 0000:00:07.0: 0x01000000 | data2
> [ 2948.510825] iwlwifi 0000:00:07.0: 0x00000000 | data3
> [ 2948.510841] iwlwifi 0000:00:07.0: 0x00000000 | beacon time
> [ 2948.510855] iwlwifi 0000:00:07.0: 0xAF590F54 | tsf low
> [ 2948.510868] iwlwifi 0000:00:07.0: 0x00000000 | tsf hi
> [ 2948.510882] iwlwifi 0000:00:07.0: 0x00000000 | time gp1
> [ 2948.510896] iwlwifi 0000:00:07.0: 0xAF57F299 | time gp2
> [ 2948.510909] iwlwifi 0000:00:07.0: 0x00000001 | uCode revision type
> [ 2948.510925] iwlwifi 0000:00:07.0: 0x0000005E | uCode version major
> [ 2948.510945] iwlwifi 0000:00:07.0: 0x62990553 | uCode version minor
> [ 2948.510962] iwlwifi 0000:00:07.0: 0x00000472 | hw version
> [ 2948.510975] iwlwifi 0000:00:07.0: 0x18C80002 | board version
> [ 2948.510991] iwlwifi 0000:00:07.0: 0x8042FA00 | hcmd
> [ 2948.511005] iwlwifi 0000:00:07.0: 0x00020000 | isr0
> [ 2948.511018] iwlwifi 0000:00:07.0: 0x20000000 | isr1
> [ 2948.511035] iwlwifi 0000:00:07.0: 0x58F04082 | isr2
> [ 2948.511049] iwlwifi 0000:00:07.0: 0x00C0000C | isr3
> [ 2948.511062] iwlwifi 0000:00:07.0: 0x02000000 | isr4
> [ 2948.511075] iwlwifi 0000:00:07.0: 0x00E60103 | last cmd Id
> [ 2948.511089] iwlwifi 0000:00:07.0: 0x00015C56 | wait_event
> [ 2948.511106] iwlwifi 0000:00:07.0: 0x10000004 | l2p_control
> [ 2948.511119] iwlwifi 0000:00:07.0: 0x00000000 | l2p_duration
> [ 2948.511132] iwlwifi 0000:00:07.0: 0x00000000 | l2p_mhvalid
> [ 2948.511146] iwlwifi 0000:00:07.0: 0x00000000 | l2p_addr_match
> [ 2948.511165] iwlwifi 0000:00:07.0: 0x0000002B | lmpm_pmg_sel
> [ 2948.511178] iwlwifi 0000:00:07.0: 0x00000000 | timestamp
> [ 2948.511191] iwlwifi 0000:00:07.0: 0x00003064 | flow_handler
> [ 2948.511610] iwlwifi 0000:00:07.0: Start IWL Error Log Dump:
> [ 2948.511626] iwlwifi 0000:00:07.0: Transport status: 0x00000042, valid: 6
> [ 2948.511643] iwlwifi 0000:00:07.0: Loaded firmware version: 94.62990553.0 gl-c0-fm-c0-94.ucode
> [ 2948.511669] iwlwifi 0000:00:07.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
> [ 2948.511685] iwlwifi 0000:00:07.0: 0x000002F0 | trm_hw_status0
> [ 2948.511728] iwlwifi 0000:00:07.0: 0x00000000 | trm_hw_status1
> [ 2948.511744] iwlwifi 0000:00:07.0: 0x002C4996 | branchlink2
> [ 2948.511758] iwlwifi 0000:00:07.0: 0x002B8CC8 | interruptlink1
> [ 2948.511777] iwlwifi 0000:00:07.0: 0x002B8CC8 | interruptlink2
> [ 2948.511793] iwlwifi 0000:00:07.0: 0x002A5B6E | data1
> [ 2948.511806] iwlwifi 0000:00:07.0: 0x01000000 | data2
> [ 2948.511821] iwlwifi 0000:00:07.0: 0x00000000 | data3
> [ 2948.511837] iwlwifi 0000:00:07.0: 0x00000000 | beacon time
> [ 2948.511850] iwlwifi 0000:00:07.0: 0xAF590F54 | tsf low
> [ 2948.511863] iwlwifi 0000:00:07.0: 0x00000000 | tsf hi
> [ 2948.511877] iwlwifi 0000:00:07.0: 0x00000000 | time gp1
> [ 2948.511890] iwlwifi 0000:00:07.0: 0xAF57F29A | time gp2
> [ 2948.511904] iwlwifi 0000:00:07.0: 0x00000001 | uCode revision type
> [ 2948.511922] iwlwifi 0000:00:07.0: 0x0000005E | uCode version major
> [ 2948.511938] iwlwifi 0000:00:07.0: 0x62990553 | uCode version minor
> [ 2948.511954] iwlwifi 0000:00:07.0: 0x00000472 | hw version
> [ 2948.511968] iwlwifi 0000:00:07.0: 0x18C80002 | board version
> [ 2948.511984] iwlwifi 0000:00:07.0: 0x8041F503 | hcmd
> [ 2948.511997] iwlwifi 0000:00:07.0: 0x00020000 | isr0
> [ 2948.512014] iwlwifi 0000:00:07.0: 0x20000000 | isr1
> [ 2948.512027] iwlwifi 0000:00:07.0: 0x58F00082 | isr2
> [ 2948.512040] iwlwifi 0000:00:07.0: 0x00C0000C | isr3
> [ 2948.512053] iwlwifi 0000:00:07.0: 0x02000000 | isr4
> [ 2948.512067] iwlwifi 0000:00:07.0: 0x00000000 | last cmd Id
> [ 2948.512080] iwlwifi 0000:00:07.0: 0x002A5B6E | wait_event
> [ 2948.512093] iwlwifi 0000:00:07.0: 0x10000004 | l2p_control
> [ 2948.512107] iwlwifi 0000:00:07.0: 0x00000000 | l2p_duration
> [ 2948.512120] iwlwifi 0000:00:07.0: 0x00000000 | l2p_mhvalid
> [ 2948.512135] iwlwifi 0000:00:07.0: 0x00000000 | l2p_addr_match
> [ 2948.512151] iwlwifi 0000:00:07.0: 0x00000028 | lmpm_pmg_sel
> [ 2948.512165] iwlwifi 0000:00:07.0: 0x00000000 | timestamp
> [ 2948.512178] iwlwifi 0000:00:07.0: 0x00003064 | flow_handler
> [ 2948.512289] iwlwifi 0000:00:07.0: Start IWL Error Log Dump:
> [ 2948.512305] iwlwifi 0000:00:07.0: Transport status: 0x00000042, valid: 7
> [ 2948.512321] iwlwifi 0000:00:07.0: 0x20000074 | ADVANCED_SYSASSERT
> [ 2948.512341] iwlwifi 0000:00:07.0: 0x00000000 | umac branchlink1
> [ 2948.512358] iwlwifi 0000:00:07.0: 0xC008089A | umac branchlink2
> [ 2948.512377] iwlwifi 0000:00:07.0: 0x8028A292 | umac interruptlink1
> [ 2948.512393] iwlwifi 0000:00:07.0: 0x01077154 | umac interruptlink2
> [ 2948.512410] iwlwifi 0000:00:07.0: 0x01000000 | umac data1
> [ 2948.512426] iwlwifi 0000:00:07.0: 0x01077154 | umac data2
> [ 2948.512439] iwlwifi 0000:00:07.0: 0x00000000 | umac data3
> [ 2948.512453] iwlwifi 0000:00:07.0: 0x0000005E | umac major
> [ 2948.512478] iwlwifi 0000:00:07.0: 0x62990553 | umac minor
> [ 2948.512492] iwlwifi 0000:00:07.0: 0xAF57F28F | frame pointer
> [ 2948.512508] iwlwifi 0000:00:07.0: 0xD00D6258 | stack pointer
> [ 2948.512527] iwlwifi 0000:00:07.0: 0x00EB0F07 | last host cmd
> [ 2948.512543] iwlwifi 0000:00:07.0: 0x00000400 | isr status reg
> [ 2948.512666] iwlwifi 0000:00:07.0: TCM1 status:
> [ 2948.512682] iwlwifi 0000:00:07.0: 0x00000070 | error ID
> [ 2948.512695] iwlwifi 0000:00:07.0: 0x00001A96 | tcm branchlink2
> [ 2948.512714] iwlwifi 0000:00:07.0: 0x00001E38 | tcm interruptlink1
> [ 2948.512731] iwlwifi 0000:00:07.0: 0x00001E38 | tcm interruptlink2
> [ 2948.512750] iwlwifi 0000:00:07.0: 0x40000000 | tcm data1
> [ 2948.512764] iwlwifi 0000:00:07.0: 0xDEADBEEF | tcm data2
> [ 2948.512778] iwlwifi 0000:00:07.0: 0xDEADBEEF | tcm data3
> [ 2948.512794] iwlwifi 0000:00:07.0: 0x00001AF4 | tcm log PC
> [ 2948.512807] iwlwifi 0000:00:07.0: 0x00803FF0 | tcm frame pointer
> [ 2948.512823] iwlwifi 0000:00:07.0: 0x00803F5C | tcm stack pointer
> [ 2948.512840] iwlwifi 0000:00:07.0: 0x00000000 | tcm msg ID
> [ 2948.512856] iwlwifi 0000:00:07.0: 0x40000000 | tcm ISR status
> [ 2948.512872] iwlwifi 0000:00:07.0: 0x000002F0 | tcm HW status[0]
> [ 2948.512888] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[1]
> [ 2948.512904] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[2]
> [ 2948.512920] iwlwifi 0000:00:07.0: 0x00008100 | tcm HW status[3]
> [ 2948.512936] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[4]
> [ 2948.512952] iwlwifi 0000:00:07.0: 0x00000000 | tcm SW status[0]
> [ 2948.513073] iwlwifi 0000:00:07.0: RCM1 status:
> [ 2948.513086] iwlwifi 0000:00:07.0: 0x00000070 | error ID
> [ 2948.513099] iwlwifi 0000:00:07.0: 0x00001AF2 | rcm branchlink2
> [ 2948.513115] iwlwifi 0000:00:07.0: 0x00002468 | rcm interruptlink1
> [ 2948.513131] iwlwifi 0000:00:07.0: 0x00002468 | rcm interruptlink2
> [ 2948.513147] iwlwifi 0000:00:07.0: 0x20000000 | rcm data1
> [ 2948.513160] iwlwifi 0000:00:07.0: 0xDEADBEEF | rcm data2
> [ 2948.513173] iwlwifi 0000:00:07.0: 0xDEADBEEF | rcm data3
> [ 2948.513187] iwlwifi 0000:00:07.0: 0x00001B4C | rcm log PC
> [ 2948.513200] iwlwifi 0000:00:07.0: 0x00803FF0 | rcm frame pointer
> [ 2948.513216] iwlwifi 0000:00:07.0: 0x00803F5C | rcm stack pointer
> [ 2948.513232] iwlwifi 0000:00:07.0: 0x00000000 | rcm msg ID
> [ 2948.513245] iwlwifi 0000:00:07.0: 0x20000000 | rcm ISR status
> [ 2948.513261] iwlwifi 0000:00:07.0: 0x00020400 | frame HW status
> [ 2948.513277] iwlwifi 0000:00:07.0: 0x00000000 | LMAC-to-RCM request mbox
> [ 2948.513293] iwlwifi 0000:00:07.0: 0x00000000 | RCM-to-LMAC request mbox
> [ 2948.513310] iwlwifi 0000:00:07.0: 0x00000000 | MAC header control
> [ 2948.513326] iwlwifi 0000:00:07.0: 0x00000000 | MAC header addr1 low
> [ 2948.513342] iwlwifi 0000:00:07.0: 0x003C0000 | MAC header info
> [ 2948.513358] iwlwifi 0000:00:07.0: 0x00000000 | MAC header error
> [ 2948.513573] iwlwifi 0000:00:07.0: TCM2 status:
> [ 2948.513587] iwlwifi 0000:00:07.0: 0x00000070 | error ID
> [ 2948.513600] iwlwifi 0000:00:07.0: 0x00001A96 | tcm branchlink2
> [ 2948.513616] iwlwifi 0000:00:07.0: 0x00001E38 | tcm interruptlink1
> [ 2948.653141] iwlwifi 0000:00:07.0: 0x00001E38 | tcm interruptlink2
> [ 2948.653168] iwlwifi 0000:00:07.0: 0x40000000 | tcm data1
> [ 2948.653186] iwlwifi 0000:00:07.0: 0xDEADBEEF | tcm data2
> [ 2948.653200] iwlwifi 0000:00:07.0: 0xDEADBEEF | tcm data3
> [ 2948.653216] iwlwifi 0000:00:07.0: 0x00001AF4 | tcm log PC
> [ 2948.653230] iwlwifi 0000:00:07.0: 0x00803FF0 | tcm frame pointer
> [ 2948.653248] iwlwifi 0000:00:07.0: 0x00803F5C | tcm stack pointer
> [ 2948.653265] iwlwifi 0000:00:07.0: 0x00000000 | tcm msg ID
> [ 2948.653281] iwlwifi 0000:00:07.0: 0x40000000 | tcm ISR status
> [ 2948.653297] iwlwifi 0000:00:07.0: 0x000002F0 | tcm HW status[0]
> [ 2948.653316] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[1]
> [ 2948.653332] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[2]
> [ 2948.653352] iwlwifi 0000:00:07.0: 0x00008000 | tcm HW status[3]
> [ 2948.653368] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[4]
> [ 2948.653386] iwlwifi 0000:00:07.0: 0x00000000 | tcm SW status[0]
> [ 2948.653608] iwlwifi 0000:00:07.0: RCM2 status:
> [ 2948.653625] iwlwifi 0000:00:07.0: 0x00000070 | error ID
> [ 2948.653641] iwlwifi 0000:00:07.0: 0x00001AF2 | rcm branchlink2
> [ 2948.653660] iwlwifi 0000:00:07.0: 0x00002468 | rcm interruptlink1
> [ 2948.653678] iwlwifi 0000:00:07.0: 0x00002468 | rcm interruptlink2
> [ 2948.653697] iwlwifi 0000:00:07.0: 0x20000000 | rcm data1
> [ 2948.653710] iwlwifi 0000:00:07.0: 0xDEADBEEF | rcm data2
> [ 2948.653724] iwlwifi 0000:00:07.0: 0xDEADBEEF | rcm data3
> [ 2948.653740] iwlwifi 0000:00:07.0: 0x00001B4C | rcm log PC
> [ 2948.653754] iwlwifi 0000:00:07.0: 0x00803FF0 | rcm frame pointer
> [ 2948.653773] iwlwifi 0000:00:07.0: 0x00803F5C | rcm stack pointer
> [ 2948.653789] iwlwifi 0000:00:07.0: 0x00000000 | rcm msg ID
> [ 2948.653805] iwlwifi 0000:00:07.0: 0x20000000 | rcm ISR status
> [ 2948.653825] iwlwifi 0000:00:07.0: 0x00020400 | frame HW status
> [ 2948.653841] iwlwifi 0000:00:07.0: 0x00000000 | LMAC-to-RCM request mbox
> [ 2948.653860] iwlwifi 0000:00:07.0: 0x00000000 | RCM-to-LMAC request mbox
> [ 2948.653877] iwlwifi 0000:00:07.0: 0x00000000 | MAC header control
> [ 2948.653893] iwlwifi 0000:00:07.0: 0x00000000 | MAC header addr1 low
> [ 2948.653912] iwlwifi 0000:00:07.0: 0x003C0000 | MAC header info
> [ 2948.653930] iwlwifi 0000:00:07.0: 0x00000000 | MAC header error
> [ 2948.654030] iwlwifi 0000:00:07.0: IML/ROM dump:
> [ 2948.654046] iwlwifi 0000:00:07.0: 0x00000000 | IML/ROM error/state
> [ 2948.654225] iwlwifi 0000:00:07.0: 0x00000000 | IML/ROM data1
> [ 2948.654326] iwlwifi 0000:00:07.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
> [ 2948.654424] iwlwifi 0000:00:07.0: Fseq Registers:
> [ 2948.654526] iwlwifi 0000:00:07.0: 0x60000A00 | FSEQ_ERROR_CODE
> [ 2948.654623] iwlwifi 0000:00:07.0: 0x80B00004 | FSEQ_TOP_INIT_VERSION
> [ 2948.654759] iwlwifi 0000:00:07.0: 0x00570000 | FSEQ_CNVIO_INIT_VERSION
> [ 2948.654851] iwlwifi 0000:00:07.0: 0x0000AA14 | FSEQ_OTP_VERSION
> [ 2948.654943] iwlwifi 0000:00:07.0: 0x0000000F | FSEQ_TOP_CONTENT_VERSION
> [ 2948.655033] iwlwifi 0000:00:07.0: 0x4552414E | FSEQ_ALIVE_TOKEN
> [ 2948.655126] iwlwifi 0000:00:07.0: 0x02001910 | FSEQ_CNVI_ID
> [ 2948.655214] iwlwifi 0000:00:07.0: 0x02001910 | FSEQ_CNVR_ID
> [ 2948.655335] iwlwifi 0000:00:07.0: 0x02001910 | CNVI_AUX_MISC_CHIP
> [ 2948.655428] iwlwifi 0000:00:07.0: 0x02001910 | CNVR_AUX_MISC_CHIP
> [ 2948.655535] iwlwifi 0000:00:07.0: 0x8F0F1041 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
> [ 2948.655634] iwlwifi 0000:00:07.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
> [ 2948.655730] iwlwifi 0000:00:07.0: 0x00570000 | FSEQ_PREV_CNVIO_INIT_VERSION
> [ 2948.655822] iwlwifi 0000:00:07.0: 0x00B10005 | FSEQ_WIFI_FSEQ_VERSION
> [ 2948.655914] iwlwifi 0000:00:07.0: 0x00B10005 | FSEQ_BT_FSEQ_VERSION
> [ 2948.656004] iwlwifi 0000:00:07.0: 0x000000F0 | FSEQ_CLASS_TP_VERSION
> [ 2948.656217] iwlwifi 0000:00:07.0: UMAC CURRENT PC: 0x1110bad
> [ 2948.656311] iwlwifi 0000:00:07.0: LMAC1 CURRENT PC: 0x0
> [ 2948.656398] iwlwifi 0000:00:07.0: LMAC2 CURRENT PC: 0x0
> [ 2948.656497] iwlwifi 0000:00:07.0: UMAC CURRENT PC 1: 0x2220bad
> [ 2948.656588] iwlwifi 0000:00:07.0: TCM1 CURRENT PC: 0x0
> [ 2948.656675] iwlwifi 0000:00:07.0: RCM1 CURRENT PC: 0x0
> [ 2948.656763] iwlwifi 0000:00:07.0: RCM2 CURRENT PC: 0x0
> [ 2948.656851] iwlwifi 0000:00:07.0: Function Scratch status:
> [ 2948.656864] iwlwifi 0000:00:07.0: 0x01010000 | Func Scratch
> [ 2949.329779] iwlwifi 0000:00:07.0: Failed to run INIT ucode: -12
> [ 2949.383110] iwlwifi 0000:00:07.0: retry init count 0
> [ 2949.408845] iwlwifi 0000:00:07.0: Unable to init nic
> [ 2949.408870] iwlwifi 0000:00:07.0: Failed to start RT ucode: -12
> [ 2949.408890] iwlwifi 0000:00:07.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
> [ 2949.659633] iwlwifi 0000:00:07.0: Start IWL Error Log Dump:
> [ 2949.659659] iwlwifi 0000:00:07.0: Transport status: 0x00000042, valid: 6
> [ 2949.659677] iwlwifi 0000:00:07.0: Loaded firmware version: 94.62990553.0 gl-c0-fm-c0-94.ucode
> [ 2949.659699] iwlwifi 0000:00:07.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
> [ 2949.659716] iwlwifi 0000:00:07.0: 0x000002F0 | trm_hw_status0
> [ 2949.659733] iwlwifi 0000:00:07.0: 0x00000000 | trm_hw_status1
> [ 2949.659756] iwlwifi 0000:00:07.0: 0x002C4996 | branchlink2
> [ 2949.659770] iwlwifi 0000:00:07.0: 0x00015F80 | interruptlink1
> [ 2949.659786] iwlwifi 0000:00:07.0: 0x00015F80 | interruptlink2
> [ 2949.659803] iwlwifi 0000:00:07.0: 0x00015C56 | data1
> [ 2949.659817] iwlwifi 0000:00:07.0: 0x01000000 | data2
> [ 2949.659830] iwlwifi 0000:00:07.0: 0x00000000 | data3
> [ 2949.659844] iwlwifi 0000:00:07.0: 0x00000000 | beacon time
> [ 2949.659857] iwlwifi 0000:00:07.0: 0xAF590F54 | tsf low
> [ 2949.659871] iwlwifi 0000:00:07.0: 0x00000000 | tsf hi
> [ 2949.659888] iwlwifi 0000:00:07.0: 0x00000000 | time gp1
> [ 2949.659911] iwlwifi 0000:00:07.0: 0xAF57F299 | time gp2
> [ 2949.659925] iwlwifi 0000:00:07.0: 0x00000001 | uCode revision type
> [ 2949.659960] iwlwifi 0000:00:07.0: 0x0000005E | uCode version major
> [ 2949.659980] iwlwifi 0000:00:07.0: 0x62990553 | uCode version minor
> [ 2949.660005] iwlwifi 0000:00:07.0: 0x00000472 | hw version
> [ 2949.660022] iwlwifi 0000:00:07.0: 0x18C80002 | board version
> [ 2949.660039] iwlwifi 0000:00:07.0: 0x8042FA00 | hcmd
> [ 2949.660055] iwlwifi 0000:00:07.0: 0x00020000 | isr0
> [ 2949.660069] iwlwifi 0000:00:07.0: 0x20000000 | isr1
> [ 2949.660086] iwlwifi 0000:00:07.0: 0x58F04082 | isr2
> [ 2949.660099] iwlwifi 0000:00:07.0: 0x00C0000C | isr3
> [ 2949.660116] iwlwifi 0000:00:07.0: 0x02000000 | isr4
> [ 2949.660129] iwlwifi 0000:00:07.0: 0x00E60103 | last cmd Id
> [ 2949.660143] iwlwifi 0000:00:07.0: 0x00015C56 | wait_event
> [ 2949.660158] iwlwifi 0000:00:07.0: 0x10000004 | l2p_control
> [ 2949.660172] iwlwifi 0000:00:07.0: 0x00000000 | l2p_duration
> [ 2949.660188] iwlwifi 0000:00:07.0: 0x00000000 | l2p_mhvalid
> [ 2949.660202] iwlwifi 0000:00:07.0: 0x00000000 | l2p_addr_match
> [ 2949.660221] iwlwifi 0000:00:07.0: 0x0000002B | lmpm_pmg_sel
> [ 2949.660235] iwlwifi 0000:00:07.0: 0x00000000 | timestamp
> [ 2949.660251] iwlwifi 0000:00:07.0: 0x00003064 | flow_handler
> [ 2949.660394] iwlwifi 0000:00:07.0: Start IWL Error Log Dump:
> [ 2949.660410] iwlwifi 0000:00:07.0: Transport status: 0x00000042, valid: 6
> [ 2949.660427] iwlwifi 0000:00:07.0: Loaded firmware version: 94.62990553.0 gl-c0-fm-c0-94.ucode
> [ 2949.660450] iwlwifi 0000:00:07.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
> [ 2949.660486] iwlwifi 0000:00:07.0: 0x000002F0 | trm_hw_status0
> [ 2949.660508] iwlwifi 0000:00:07.0: 0x00000000 | trm_hw_status1
> [ 2949.660524] iwlwifi 0000:00:07.0: 0x002C4996 | branchlink2
> [ 2949.660540] iwlwifi 0000:00:07.0: 0x002B8CC8 | interruptlink1
> [ 2949.660557] iwlwifi 0000:00:07.0: 0x002B8CC8 | interruptlink2
> [ 2949.660576] iwlwifi 0000:00:07.0: 0x002A5B6E | data1
> [ 2949.660590] iwlwifi 0000:00:07.0: 0x01000000 | data2
> [ 2949.660607] iwlwifi 0000:00:07.0: 0x00000000 | data3
> [ 2949.660620] iwlwifi 0000:00:07.0: 0x00000000 | beacon time
> [ 2949.660636] iwlwifi 0000:00:07.0: 0xAF590F54 | tsf low
> [ 2949.660649] iwlwifi 0000:00:07.0: 0x00000000 | tsf hi
> [ 2949.660665] iwlwifi 0000:00:07.0: 0x00000000 | time gp1
> [ 2949.660678] iwlwifi 0000:00:07.0: 0xAF57F29A | time gp2
> [ 2949.660692] iwlwifi 0000:00:07.0: 0x00000001 | uCode revision type
> [ 2949.660711] iwlwifi 0000:00:07.0: 0x0000005E | uCode version major
> [ 2949.660757] iwlwifi 0000:00:07.0: 0x62990553 | uCode version minor
> [ 2949.660774] iwlwifi 0000:00:07.0: 0x00000472 | hw version
> [ 2949.660820] iwlwifi 0000:00:07.0: 0x18C80002 | board version
> [ 2949.660839] iwlwifi 0000:00:07.0: 0x8041F503 | hcmd
> [ 2949.660853] iwlwifi 0000:00:07.0: 0x00020000 | isr0
> [ 2949.660869] iwlwifi 0000:00:07.0: 0x20000000 | isr1
> [ 2949.660883] iwlwifi 0000:00:07.0: 0x58F00082 | isr2
> [ 2949.660900] iwlwifi 0000:00:07.0: 0x00C0000C | isr3
> [ 2949.660922] iwlwifi 0000:00:07.0: 0x02000000 | isr4
> [ 2949.660939] iwlwifi 0000:00:07.0: 0x00000000 | last cmd Id
> [ 2949.660952] iwlwifi 0000:00:07.0: 0x002A5B6E | wait_event
> [ 2949.660966] iwlwifi 0000:00:07.0: 0x10000004 | l2p_control
> [ 2949.660982] iwlwifi 0000:00:07.0: 0x00000000 | l2p_duration
> [ 2949.660996] iwlwifi 0000:00:07.0: 0x00000000 | l2p_mhvalid
> [ 2949.661009] iwlwifi 0000:00:07.0: 0x00000000 | l2p_addr_match
> [ 2949.661035] iwlwifi 0000:00:07.0: 0x00000028 | lmpm_pmg_sel
> [ 2949.661049] iwlwifi 0000:00:07.0: 0x00000000 | timestamp
> [ 2949.661062] iwlwifi 0000:00:07.0: 0x00003064 | flow_handler
> [ 2949.661243] iwlwifi 0000:00:07.0: Start IWL Error Log Dump:
> [ 2949.661265] iwlwifi 0000:00:07.0: Transport status: 0x00000042, valid: 7
> [ 2949.661291] iwlwifi 0000:00:07.0: 0x20000074 | ADVANCED_SYSASSERT
> [ 2949.661308] iwlwifi 0000:00:07.0: 0x00000000 | umac branchlink1
> [ 2949.661325] iwlwifi 0000:00:07.0: 0xC008089A | umac branchlink2
> [ 2949.661341] iwlwifi 0000:00:07.0: 0x8028A292 | umac interruptlink1
> [ 2949.661357] iwlwifi 0000:00:07.0: 0x01077154 | umac interruptlink2
> [ 2949.661373] iwlwifi 0000:00:07.0: 0x01000000 | umac data1
> [ 2949.661387] iwlwifi 0000:00:07.0: 0x01077154 | umac data2
> [ 2949.661400] iwlwifi 0000:00:07.0: 0x00000000 | umac data3
> [ 2949.661413] iwlwifi 0000:00:07.0: 0x0000005E | umac major
> [ 2949.661426] iwlwifi 0000:00:07.0: 0x62990553 | umac minor
> [ 2949.661439] iwlwifi 0000:00:07.0: 0xAF57F28F | frame pointer
> [ 2949.661455] iwlwifi 0000:00:07.0: 0xD00D6258 | stack pointer
> [ 2949.661498] iwlwifi 0000:00:07.0: 0x00EB0F07 | last host cmd
> [ 2949.661515] iwlwifi 0000:00:07.0: 0x00000400 | isr status reg
> [ 2949.661649] iwlwifi 0000:00:07.0: TCM1 status:
> [ 2949.661663] iwlwifi 0000:00:07.0: 0x00000070 | error ID
> [ 2949.661676] iwlwifi 0000:00:07.0: 0x00001A96 | tcm branchlink2
> [ 2949.661692] iwlwifi 0000:00:07.0: 0x00001E38 | tcm interruptlink1
> [ 2949.661709] iwlwifi 0000:00:07.0: 0x00001E38 | tcm interruptlink2
> [ 2949.661725] iwlwifi 0000:00:07.0: 0x40000000 | tcm data1
> [ 2949.661738] iwlwifi 0000:00:07.0: 0xDEADBEEF | tcm data2
> [ 2949.661751] iwlwifi 0000:00:07.0: 0xDEADBEEF | tcm data3
> [ 2949.661765] iwlwifi 0000:00:07.0: 0x00001AF4 | tcm log PC
> [ 2949.661778] iwlwifi 0000:00:07.0: 0x00803FF0 | tcm frame pointer
> [ 2949.661794] iwlwifi 0000:00:07.0: 0x00803F5C | tcm stack pointer
> [ 2949.661810] iwlwifi 0000:00:07.0: 0x00000000 | tcm msg ID
> [ 2949.661823] iwlwifi 0000:00:07.0: 0x40000000 | tcm ISR status
> [ 2949.860316] iwlwifi 0000:00:07.0: 0x000002F0 | tcm HW status[0]
> [ 2949.860344] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[1]
> [ 2949.860368] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[2]
> [ 2949.860387] iwlwifi 0000:00:07.0: 0x00008100 | tcm HW status[3]
> [ 2949.860404] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[4]
> [ 2949.860424] iwlwifi 0000:00:07.0: 0x00000000 | tcm SW status[0]
> [ 2949.860635] iwlwifi 0000:00:07.0: RCM1 status:
> [ 2949.860651] iwlwifi 0000:00:07.0: 0x00000070 | error ID
> [ 2949.860668] iwlwifi 0000:00:07.0: 0x00001AF2 | rcm branchlink2
> [ 2949.860684] iwlwifi 0000:00:07.0: 0x00002468 | rcm interruptlink1
> [ 2949.860703] iwlwifi 0000:00:07.0: 0x00002468 | rcm interruptlink2
> [ 2949.860720] iwlwifi 0000:00:07.0: 0x20000000 | rcm data1
> [ 2949.860736] iwlwifi 0000:00:07.0: 0xDEADBEEF | rcm data2
> [ 2949.860749] iwlwifi 0000:00:07.0: 0xDEADBEEF | rcm data3
> [ 2949.860766] iwlwifi 0000:00:07.0: 0x00001B4C | rcm log PC
> [ 2949.860779] iwlwifi 0000:00:07.0: 0x00803FF0 | rcm frame pointer
> [ 2949.860798] iwlwifi 0000:00:07.0: 0x00803F5C | rcm stack pointer
> [ 2949.860815] iwlwifi 0000:00:07.0: 0x00000000 | rcm msg ID
> [ 2949.860831] iwlwifi 0000:00:07.0: 0x20000000 | rcm ISR status
> [ 2949.860847] iwlwifi 0000:00:07.0: 0x00020400 | frame HW status
> [ 2949.860866] iwlwifi 0000:00:07.0: 0x00000000 | LMAC-to-RCM request mbox
> [ 2949.860883] iwlwifi 0000:00:07.0: 0x00000000 | RCM-to-LMAC request mbox
> [ 2949.860902] iwlwifi 0000:00:07.0: 0x00000000 | MAC header control
> [ 2949.860918] iwlwifi 0000:00:07.0: 0x00000000 | MAC header addr1 low
> [ 2949.860938] iwlwifi 0000:00:07.0: 0x003C0000 | MAC header info
> [ 2949.860954] iwlwifi 0000:00:07.0: 0x00000000 | MAC header error
> [ 2949.861081] iwlwifi 0000:00:07.0: TCM2 status:
> [ 2949.861096] iwlwifi 0000:00:07.0: 0x00000070 | error ID
> [ 2949.861112] iwlwifi 0000:00:07.0: 0x00001A96 | tcm branchlink2
> [ 2949.861129] iwlwifi 0000:00:07.0: 0x00001E38 | tcm interruptlink1
> [ 2949.861148] iwlwifi 0000:00:07.0: 0x00001E38 | tcm interruptlink2
> [ 2949.861164] iwlwifi 0000:00:07.0: 0x40000000 | tcm data1
> [ 2949.861181] iwlwifi 0000:00:07.0: 0xDEADBEEF | tcm data2
> [ 2949.861194] iwlwifi 0000:00:07.0: 0xDEADBEEF | tcm data3
> [ 2949.861210] iwlwifi 0000:00:07.0: 0x00001AF4 | tcm log PC
> [ 2949.861224] iwlwifi 0000:00:07.0: 0x00803FF0 | tcm frame pointer
> [ 2949.861243] iwlwifi 0000:00:07.0: 0x00803F5C | tcm stack pointer
> [ 2949.861259] iwlwifi 0000:00:07.0: 0x00000000 | tcm msg ID
> [ 2949.861276] iwlwifi 0000:00:07.0: 0x40000000 | tcm ISR status
> [ 2949.861292] iwlwifi 0000:00:07.0: 0x000002F0 | tcm HW status[0]
> [ 2949.861312] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[1]
> [ 2949.861328] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[2]
> [ 2949.861348] iwlwifi 0000:00:07.0: 0x00008000 | tcm HW status[3]
> [ 2949.861364] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[4]
> [ 2949.861384] iwlwifi 0000:00:07.0: 0x00000000 | tcm SW status[0]
> [ 2949.861609] iwlwifi 0000:00:07.0: RCM2 status:
> [ 2949.861626] iwlwifi 0000:00:07.0: 0x00000070 | error ID
> [ 2949.861639] iwlwifi 0000:00:07.0: 0x00001AF2 | rcm branchlink2
> [ 2949.861655] iwlwifi 0000:00:07.0: 0x00002468 | rcm interruptlink1
> [ 2949.861676] iwlwifi 0000:00:07.0: 0x00002468 | rcm interruptlink2
> [ 2949.861692] iwlwifi 0000:00:07.0: 0x20000000 | rcm data1
> [ 2949.861706] iwlwifi 0000:00:07.0: 0xDEADBEEF | rcm data2
> [ 2949.861719] iwlwifi 0000:00:07.0: 0xDEADBEEF | rcm data3
> [ 2949.861732] iwlwifi 0000:00:07.0: 0x00001B4C | rcm log PC
> [ 2949.861746] iwlwifi 0000:00:07.0: 0x00803FF0 | rcm frame pointer
> [ 2949.861762] iwlwifi 0000:00:07.0: 0x00803F5C | rcm stack pointer
> [ 2949.861778] iwlwifi 0000:00:07.0: 0x00000000 | rcm msg ID
> [ 2949.861792] iwlwifi 0000:00:07.0: 0x20000000 | rcm ISR status
> [ 2949.861808] iwlwifi 0000:00:07.0: 0x00020400 | frame HW status
> [ 2949.861824] iwlwifi 0000:00:07.0: 0x00000000 | LMAC-to-RCM request mbox
> [ 2949.861841] iwlwifi 0000:00:07.0: 0x00000000 | RCM-to-LMAC request mbox
> [ 2949.861857] iwlwifi 0000:00:07.0: 0x00000000 | MAC header control
> [ 2949.861874] iwlwifi 0000:00:07.0: 0x00000000 | MAC header addr1 low
> [ 2949.861890] iwlwifi 0000:00:07.0: 0x003C0000 | MAC header info
> [ 2949.861906] iwlwifi 0000:00:07.0: 0x00000000 | MAC header error
> [ 2949.862004] iwlwifi 0000:00:07.0: IML/ROM dump:
> [ 2949.862019] iwlwifi 0000:00:07.0: 0x00000000 | IML/ROM error/state
> [ 2949.862116] iwlwifi 0000:00:07.0: 0x00000000 | IML/ROM data1
> [ 2949.862214] iwlwifi 0000:00:07.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
> [ 2949.862309] iwlwifi 0000:00:07.0: Fseq Registers:
> [ 2949.862397] iwlwifi 0000:00:07.0: 0x60000A00 | FSEQ_ERROR_CODE
> [ 2949.862504] iwlwifi 0000:00:07.0: 0x80B00004 | FSEQ_TOP_INIT_VERSION
> [ 2949.862598] iwlwifi 0000:00:07.0: 0x00570000 | FSEQ_CNVIO_INIT_VERSION
> [ 2949.862690] iwlwifi 0000:00:07.0: 0x0000AA14 | FSEQ_OTP_VERSION
> [ 2949.862782] iwlwifi 0000:00:07.0: 0x0000000F | FSEQ_TOP_CONTENT_VERSION
> [ 2949.862874] iwlwifi 0000:00:07.0: 0x4552414E | FSEQ_ALIVE_TOKEN
> [ 2949.862965] iwlwifi 0000:00:07.0: 0x02001910 | FSEQ_CNVI_ID
> [ 2949.863074] iwlwifi 0000:00:07.0: 0x02001910 | FSEQ_CNVR_ID
> [ 2949.863171] iwlwifi 0000:00:07.0: 0x02001910 | CNVI_AUX_MISC_CHIP
> [ 2950.060343] iwlwifi 0000:00:07.0: 0x02001910 | CNVR_AUX_MISC_CHIP
> [ 2950.060446] iwlwifi 0000:00:07.0: 0x8F0F1041 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
> [ 2950.060560] iwlwifi 0000:00:07.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
> [ 2950.060668] iwlwifi 0000:00:07.0: 0x00570000 | FSEQ_PREV_CNVIO_INIT_VERSION
> [ 2950.060764] iwlwifi 0000:00:07.0: 0x00B10005 | FSEQ_WIFI_FSEQ_VERSION
> [ 2950.060861] iwlwifi 0000:00:07.0: 0x00B10005 | FSEQ_BT_FSEQ_VERSION
> [ 2950.060956] iwlwifi 0000:00:07.0: 0x000000F0 | FSEQ_CLASS_TP_VERSION
> [ 2950.061369] iwlwifi 0000:00:07.0: UMAC CURRENT PC: 0x1110bad
> [ 2950.061482] iwlwifi 0000:00:07.0: LMAC1 CURRENT PC: 0x0
> [ 2950.061576] iwlwifi 0000:00:07.0: LMAC2 CURRENT PC: 0x0
> [ 2950.061669] iwlwifi 0000:00:07.0: UMAC CURRENT PC 1: 0x2220bad
> [ 2950.061774] iwlwifi 0000:00:07.0: TCM1 CURRENT PC: 0x0
> [ 2950.061865] iwlwifi 0000:00:07.0: RCM1 CURRENT PC: 0x0
> [ 2950.061966] iwlwifi 0000:00:07.0: RCM2 CURRENT PC: 0x0
> [ 2950.062169] iwlwifi 0000:00:07.0: Function Scratch status:
> [ 2950.062187] iwlwifi 0000:00:07.0: 0x01010000 | Func Scratch
> [ 2950.757054] iwlwifi 0000:00:07.0: Failed to run INIT ucode: -12
> [ 2950.805512] iwlwifi 0000:00:07.0: retry init count 1
> [ 2950.979841] iwlwifi 0000:00:07.0: Unable to init nic
> [ 2950.979885] iwlwifi 0000:00:07.0: Failed to start RT ucode: -12
> [ 2950.979908] iwlwifi 0000:00:07.0: WRT: Collecting data: ini trigger 13 fired (delay=0ms).
> [ 2951.230434] iwlwifi 0000:00:07.0: Start IWL Error Log Dump:
> [ 2951.230473] iwlwifi 0000:00:07.0: Transport status: 0x00000042, valid: 6
> [ 2951.230492] iwlwifi 0000:00:07.0: Loaded firmware version: 94.62990553.0 gl-c0-fm-c0-94.ucode
> [ 2951.230516] iwlwifi 0000:00:07.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
> [ 2951.230533] iwlwifi 0000:00:07.0: 0x000002F0 | trm_hw_status0
> [ 2951.230550] iwlwifi 0000:00:07.0: 0x00000000 | trm_hw_status1
> [ 2951.230566] iwlwifi 0000:00:07.0: 0x002C4996 | branchlink2
> [ 2951.230580] iwlwifi 0000:00:07.0: 0x00015F80 | interruptlink1
> [ 2951.230607] iwlwifi 0000:00:07.0: 0x00015F80 | interruptlink2
> [ 2951.230623] iwlwifi 0000:00:07.0: 0x00015C56 | data1
> [ 2951.230637] iwlwifi 0000:00:07.0: 0x01000000 | data2
> [ 2951.230652] iwlwifi 0000:00:07.0: 0x00000000 | data3
> [ 2951.230666] iwlwifi 0000:00:07.0: 0x00000000 | beacon time
> [ 2951.230679] iwlwifi 0000:00:07.0: 0xAF590F54 | tsf low
> [ 2951.230693] iwlwifi 0000:00:07.0: 0x00000000 | tsf hi
> [ 2951.230707] iwlwifi 0000:00:07.0: 0x00000000 | time gp1
> [ 2951.230721] iwlwifi 0000:00:07.0: 0xAF57F299 | time gp2
> [ 2951.230734] iwlwifi 0000:00:07.0: 0x00000001 | uCode revision type
> [ 2951.230751] iwlwifi 0000:00:07.0: 0x0000005E | uCode version major
> [ 2951.230768] iwlwifi 0000:00:07.0: 0x62990553 | uCode version minor
> [ 2951.230784] iwlwifi 0000:00:07.0: 0x00000472 | hw version
> [ 2951.230798] iwlwifi 0000:00:07.0: 0x18C80002 | board version
> [ 2951.230815] iwlwifi 0000:00:07.0: 0x8042FA00 | hcmd
> [ 2951.230829] iwlwifi 0000:00:07.0: 0x00020000 | isr0
> [ 2951.230842] iwlwifi 0000:00:07.0: 0x20000000 | isr1
> [ 2951.230856] iwlwifi 0000:00:07.0: 0x58F04082 | isr2
> [ 2951.230869] iwlwifi 0000:00:07.0: 0x00C0000C | isr3
> [ 2951.230883] iwlwifi 0000:00:07.0: 0x02000000 | isr4
> [ 2951.230902] iwlwifi 0000:00:07.0: 0x00E60103 | last cmd Id
> [ 2951.230916] iwlwifi 0000:00:07.0: 0x00015C56 | wait_event
> [ 2951.230930] iwlwifi 0000:00:07.0: 0x10000004 | l2p_control
> [ 2951.230943] iwlwifi 0000:00:07.0: 0x00000000 | l2p_duration
> [ 2951.230957] iwlwifi 0000:00:07.0: 0x00000000 | l2p_mhvalid
> [ 2951.230970] iwlwifi 0000:00:07.0: 0x00000000 | l2p_addr_match
> [ 2951.230986] iwlwifi 0000:00:07.0: 0x0000002B | lmpm_pmg_sel
> [ 2951.230999] iwlwifi 0000:00:07.0: 0x00000000 | timestamp
> [ 2951.231013] iwlwifi 0000:00:07.0: 0x00003064 | flow_handler
> [ 2951.231154] iwlwifi 0000:00:07.0: Start IWL Error Log Dump:
> [ 2951.231167] iwlwifi 0000:00:07.0: Transport status: 0x00000042, valid: 6
> [ 2951.231184] iwlwifi 0000:00:07.0: Loaded firmware version: 94.62990553.0 gl-c0-fm-c0-94.ucode
> [ 2951.231206] iwlwifi 0000:00:07.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
> [ 2951.231222] iwlwifi 0000:00:07.0: 0x000002F0 | trm_hw_status0
> [ 2951.231238] iwlwifi 0000:00:07.0: 0x00000000 | trm_hw_status1
> [ 2951.231254] iwlwifi 0000:00:07.0: 0x002C4996 | branchlink2
> [ 2951.231268] iwlwifi 0000:00:07.0: 0x002B8CC8 | interruptlink1
> [ 2951.231286] iwlwifi 0000:00:07.0: 0x002B8CC8 | interruptlink2
> [ 2951.231302] iwlwifi 0000:00:07.0: 0x002A5B6E | data1
> [ 2951.231316] iwlwifi 0000:00:07.0: 0x01000000 | data2
> [ 2951.231334] iwlwifi 0000:00:07.0: 0x00000000 | data3
> [ 2951.231348] iwlwifi 0000:00:07.0: 0x00000000 | beacon time
> [ 2951.231361] iwlwifi 0000:00:07.0: 0xAF590F54 | tsf low
> [ 2951.231374] iwlwifi 0000:00:07.0: 0x00000000 | tsf hi
> [ 2951.231387] iwlwifi 0000:00:07.0: 0x00000000 | time gp1
> [ 2951.231401] iwlwifi 0000:00:07.0: 0xAF57F29A | time gp2
> [ 2951.231414] iwlwifi 0000:00:07.0: 0x00000001 | uCode revision type
> [ 2951.231430] iwlwifi 0000:00:07.0: 0x0000005E | uCode version major
> [ 2951.231446] iwlwifi 0000:00:07.0: 0x62990553 | uCode version minor
> [ 2951.231470] iwlwifi 0000:00:07.0: 0x00000472 | hw version
> [ 2951.231483] iwlwifi 0000:00:07.0: 0x18C80002 | board version
> [ 2951.231521] iwlwifi 0000:00:07.0: 0x8041F503 | hcmd
> [ 2951.231535] iwlwifi 0000:00:07.0: 0x00020000 | isr0
> [ 2951.231549] iwlwifi 0000:00:07.0: 0x20000000 | isr1
> [ 2951.231562] iwlwifi 0000:00:07.0: 0x58F00082 | isr2
> [ 2951.231575] iwlwifi 0000:00:07.0: 0x00C0000C | isr3
> [ 2951.231589] iwlwifi 0000:00:07.0: 0x02000000 | isr4
> [ 2951.231602] iwlwifi 0000:00:07.0: 0x00000000 | last cmd Id
> [ 2951.231616] iwlwifi 0000:00:07.0: 0x002A5B6E | wait_event
> [ 2951.231630] iwlwifi 0000:00:07.0: 0x10000004 | l2p_control
> [ 2951.231643] iwlwifi 0000:00:07.0: 0x00000000 | l2p_duration
> [ 2951.231657] iwlwifi 0000:00:07.0: 0x00000000 | l2p_mhvalid
> [ 2951.231670] iwlwifi 0000:00:07.0: 0x00000000 | l2p_addr_match
> [ 2951.231686] iwlwifi 0000:00:07.0: 0x00000028 | lmpm_pmg_sel
> [ 2951.231700] iwlwifi 0000:00:07.0: 0x00000000 | timestamp
> [ 2951.231713] iwlwifi 0000:00:07.0: 0x00003064 | flow_handler
> [ 2951.231827] iwlwifi 0000:00:07.0: Start IWL Error Log Dump:
> [ 2951.231841] iwlwifi 0000:00:07.0: Transport status: 0x00000042, valid: 7
> [ 2951.231857] iwlwifi 0000:00:07.0: 0x20000074 | ADVANCED_SYSASSERT
> [ 2951.231874] iwlwifi 0000:00:07.0: 0x00000000 | umac branchlink1
> [ 2951.231890] iwlwifi 0000:00:07.0: 0xC008089A | umac branchlink2
> [ 2951.231906] iwlwifi 0000:00:07.0: 0x8028A292 | umac interruptlink1
> [ 2951.231922] iwlwifi 0000:00:07.0: 0x01077154 | umac interruptlink2
> [ 2951.231939] iwlwifi 0000:00:07.0: 0x01000000 | umac data1
> [ 2951.231952] iwlwifi 0000:00:07.0: 0x01077154 | umac data2
> [ 2951.231965] iwlwifi 0000:00:07.0: 0x00000000 | umac data3
> [ 2951.231979] iwlwifi 0000:00:07.0: 0x0000005E | umac major
> [ 2951.231992] iwlwifi 0000:00:07.0: 0x62990553 | umac minor
> [ 2951.232005] iwlwifi 0000:00:07.0: 0xAF57F28F | frame pointer
> [ 2951.232022] iwlwifi 0000:00:07.0: 0xD00D6258 | stack pointer
> [ 2951.232038] iwlwifi 0000:00:07.0: 0x00EB0F07 | last host cmd
> [ 2951.232054] iwlwifi 0000:00:07.0: 0x00000400 | isr status reg
> [ 2951.232175] iwlwifi 0000:00:07.0: TCM1 status:
> [ 2951.232189] iwlwifi 0000:00:07.0: 0x00000070 | error ID
> [ 2951.232202] iwlwifi 0000:00:07.0: 0x00001A96 | tcm branchlink2
> [ 2951.232218] iwlwifi 0000:00:07.0: 0x00001E38 | tcm interruptlink1
> [ 2951.232234] iwlwifi 0000:00:07.0: 0x00001E38 | tcm interruptlink2
> [ 2951.232250] iwlwifi 0000:00:07.0: 0x40000000 | tcm data1
> [ 2951.232264] iwlwifi 0000:00:07.0: 0xDEADBEEF | tcm data2
> [ 2951.232277] iwlwifi 0000:00:07.0: 0xDEADBEEF | tcm data3
> [ 2951.232290] iwlwifi 0000:00:07.0: 0x00001AF4 | tcm log PC
> [ 2951.232304] iwlwifi 0000:00:07.0: 0x00803FF0 | tcm frame pointer
> [ 2951.232320] iwlwifi 0000:00:07.0: 0x00803F5C | tcm stack pointer
> [ 2951.232337] iwlwifi 0000:00:07.0: 0x00000000 | tcm msg ID
> [ 2951.232350] iwlwifi 0000:00:07.0: 0x40000000 | tcm ISR status
> [ 2951.232371] iwlwifi 0000:00:07.0: 0x000002F0 | tcm HW status[0]
> [ 2951.232388] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[1]
> [ 2951.232404] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[2]
> [ 2951.232420] iwlwifi 0000:00:07.0: 0x00008100 | tcm HW status[3]
> [ 2951.232437] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[4]
> [ 2951.232453] iwlwifi 0000:00:07.0: 0x00000000 | tcm SW status[0]
> [ 2951.232586] iwlwifi 0000:00:07.0: RCM1 status:
> [ 2951.232600] iwlwifi 0000:00:07.0: 0x00000070 | error ID
> [ 2951.232614] iwlwifi 0000:00:07.0: 0x00001AF2 | rcm branchlink2
> [ 2951.232630] iwlwifi 0000:00:07.0: 0x00002468 | rcm interruptlink1
> [ 2951.232646] iwlwifi 0000:00:07.0: 0x00002468 | rcm interruptlink2
> [ 2951.232662] iwlwifi 0000:00:07.0: 0x20000000 | rcm data1
> [ 2951.232675] iwlwifi 0000:00:07.0: 0xDEADBEEF | rcm data2
> [ 2951.232688] iwlwifi 0000:00:07.0: 0xDEADBEEF | rcm data3
> [ 2951.232701] iwlwifi 0000:00:07.0: 0x00001B4C | rcm log PC
> [ 2951.232715] iwlwifi 0000:00:07.0: 0x00803FF0 | rcm frame pointer
> [ 2951.232731] iwlwifi 0000:00:07.0: 0x00803F5C | rcm stack pointer
> [ 2951.232747] iwlwifi 0000:00:07.0: 0x00000000 | rcm msg ID
> [ 2951.232760] iwlwifi 0000:00:07.0: 0x20000000 | rcm ISR status
> [ 2951.232776] iwlwifi 0000:00:07.0: 0x00020400 | frame HW status
> [ 2951.232792] iwlwifi 0000:00:07.0: 0x00000000 | LMAC-to-RCM request mbox
> [ 2951.232808] iwlwifi 0000:00:07.0: 0x00000000 | RCM-to-LMAC request mbox
> [ 2951.232825] iwlwifi 0000:00:07.0: 0x00000000 | MAC header control
> [ 2951.232842] iwlwifi 0000:00:07.0: 0x00000000 | MAC header addr1 low
> [ 2951.232858] iwlwifi 0000:00:07.0: 0x003C0000 | MAC header info
> [ 2951.232879] iwlwifi 0000:00:07.0: 0x00000000 | MAC header error
> [ 2951.233000] iwlwifi 0000:00:07.0: TCM2 status:
> [ 2951.233014] iwlwifi 0000:00:07.0: 0x00000070 | error ID
> [ 2951.233027] iwlwifi 0000:00:07.0: 0x00001A96 | tcm branchlink2
> [ 2951.233044] iwlwifi 0000:00:07.0: 0x00001E38 | tcm interruptlink1
> [ 2951.233060] iwlwifi 0000:00:07.0: 0x00001E38 | tcm interruptlink2
> [ 2951.233076] iwlwifi 0000:00:07.0: 0x40000000 | tcm data1
> [ 2951.233090] iwlwifi 0000:00:07.0: 0xDEADBEEF | tcm data2
> [ 2951.233103] iwlwifi 0000:00:07.0: 0xDEADBEEF | tcm data3
> [ 2951.233117] iwlwifi 0000:00:07.0: 0x00001AF4 | tcm log PC
> [ 2951.233130] iwlwifi 0000:00:07.0: 0x00803FF0 | tcm frame pointer
> [ 2951.233147] iwlwifi 0000:00:07.0: 0x00803F5C | tcm stack pointer
> [ 2951.233163] iwlwifi 0000:00:07.0: 0x00000000 | tcm msg ID
> [ 2951.233177] iwlwifi 0000:00:07.0: 0x40000000 | tcm ISR status
> [ 2951.233193] iwlwifi 0000:00:07.0: 0x000002F0 | tcm HW status[0]
> [ 2951.233209] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[1]
> [ 2951.233226] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[2]
> [ 2951.233242] iwlwifi 0000:00:07.0: 0x00008000 | tcm HW status[3]
> [ 2951.233259] iwlwifi 0000:00:07.0: 0x00000000 | tcm HW status[4]
> [ 2951.233276] iwlwifi 0000:00:07.0: 0x00000000 | tcm SW status[0]
> [ 2951.233397] iwlwifi 0000:00:07.0: RCM2 status:
> [ 2951.233413] iwlwifi 0000:00:07.0: 0x00000070 | error ID
> [ 2951.233433] iwlwifi 0000:00:07.0: 0x00001AF2 | rcm branchlink2
> [ 2951.233450] iwlwifi 0000:00:07.0: 0x00002468 | rcm interruptlink1
> [ 2951.233485] iwlwifi 0000:00:07.0: 0x00002468 | rcm interruptlink2
> [ 2951.233502] iwlwifi 0000:00:07.0: 0x20000000 | rcm data1
> [ 2951.233516] iwlwifi 0000:00:07.0: 0xDEADBEEF | rcm data2
> [ 2951.233529] iwlwifi 0000:00:07.0: 0xDEADBEEF | rcm data3
> [ 2951.233543] iwlwifi 0000:00:07.0: 0x00001B4C | rcm log PC
> [ 2951.233556] iwlwifi 0000:00:07.0: 0x00803FF0 | rcm frame pointer
> [ 2951.233572] iwlwifi 0000:00:07.0: 0x00803F5C | rcm stack pointer
> [ 2951.233588] iwlwifi 0000:00:07.0: 0x00000000 | rcm msg ID
> [ 2951.233601] iwlwifi 0000:00:07.0: 0x20000000 | rcm ISR status
> [ 2951.233618] iwlwifi 0000:00:07.0: 0x00020400 | frame HW status
> [ 2951.233634] iwlwifi 0000:00:07.0: 0x00000000 | LMAC-to-RCM request mbox
> [ 2951.233650] iwlwifi 0000:00:07.0: 0x00000000 | RCM-to-LMAC request mbox
> [ 2951.233666] iwlwifi 0000:00:07.0: 0x00000000 | MAC header control
> [ 2951.233682] iwlwifi 0000:00:07.0: 0x00000000 | MAC header addr1 low
> [ 2951.233699] iwlwifi 0000:00:07.0: 0x003C0000 | MAC header info
> [ 2951.233715] iwlwifi 0000:00:07.0: 0x00000000 | MAC header error
> [ 2951.233812] iwlwifi 0000:00:07.0: IML/ROM dump:
> [ 2951.233826] iwlwifi 0000:00:07.0: 0x00000000 | IML/ROM error/state
> [ 2951.233926] iwlwifi 0000:00:07.0: 0x00000000 | IML/ROM data1
> [ 2951.234150] iwlwifi 0000:00:07.0: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0
> [ 2951.234251] iwlwifi 0000:00:07.0: Fseq Registers:
> [ 2951.234339] iwlwifi 0000:00:07.0: 0x60000A00 | FSEQ_ERROR_CODE
> [ 2951.234439] iwlwifi 0000:00:07.0: 0x80B00004 | FSEQ_TOP_INIT_VERSION
> [ 2951.234547] iwlwifi 0000:00:07.0: 0x00570000 | FSEQ_CNVIO_INIT_VERSION
> [ 2951.234645] iwlwifi 0000:00:07.0: 0x0000AA14 | FSEQ_OTP_VERSION
> [ 2951.234745] iwlwifi 0000:00:07.0: 0x0000000F | FSEQ_TOP_CONTENT_VERSION
> [ 2951.234840] iwlwifi 0000:00:07.0: 0x4552414E | FSEQ_ALIVE_TOKEN
> [ 2951.234935] iwlwifi 0000:00:07.0: 0x02001910 | FSEQ_CNVI_ID
> [ 2951.235036] iwlwifi 0000:00:07.0: 0x02001910 | FSEQ_CNVR_ID
> [ 2951.235130] iwlwifi 0000:00:07.0: 0x02001910 | CNVI_AUX_MISC_CHIP
> [ 2951.235229] iwlwifi 0000:00:07.0: 0x02001910 | CNVR_AUX_MISC_CHIP
> [ 2951.235329] iwlwifi 0000:00:07.0: 0x00001041 | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
> [ 2951.235431] iwlwifi 0000:00:07.0: 0x00000000 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
> [ 2951.235544] iwlwifi 0000:00:07.0: 0x00570000 | FSEQ_PREV_CNVIO_INIT_VERSION
> [ 2951.235642] iwlwifi 0000:00:07.0: 0x00B10005 | FSEQ_WIFI_FSEQ_VERSION
> [ 2951.235738] iwlwifi 0000:00:07.0: 0x00B10005 | FSEQ_BT_FSEQ_VERSION
> [ 2951.235834] iwlwifi 0000:00:07.0: 0x000000F0 | FSEQ_CLASS_TP_VERSION
> [ 2951.235938] iwlwifi 0000:00:07.0: UMAC CURRENT PC: 0x1110bad
> [ 2951.236065] iwlwifi 0000:00:07.0: LMAC1 CURRENT PC: 0x0
> [ 2951.236164] iwlwifi 0000:00:07.0: LMAC2 CURRENT PC: 0x0
> [ 2951.236265] iwlwifi 0000:00:07.0: UMAC CURRENT PC 1: 0x2220bad
> [ 2951.236361] iwlwifi 0000:00:07.0: TCM1 CURRENT PC: 0x0
> [ 2951.236453] iwlwifi 0000:00:07.0: RCM1 CURRENT PC: 0x0
> [ 2951.236552] iwlwifi 0000:00:07.0: RCM2 CURRENT PC: 0x0
> [ 2951.236641] iwlwifi 0000:00:07.0: Function Scratch status:
> [ 2951.236655] iwlwifi 0000:00:07.0: 0x01010000 | Func Scratch
> [ 2951.903761] iwlwifi 0000:00:07.0: Failed to run INIT ucode: -12
> [ 2951.951941] iwlwifi 0000:00:07.0: retry init count 2
</details>
<details>
> Physical Slot: 7
> Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
> DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr+ TransPend-
> LnkCtl: ASPM L1 Enabled; RCB 64 bytes, LnkDisable- CommClk+
> IDOReq- IDOCompl- LTR+ EmergencyPowerReductionReq-
> Capabilities: [b0] MSI-X: Enable- Count=32 Masked-
</details>
<details>
> LaneErrStat: 0
</details>
