Hello everyone,
im trying to use a wifi dongle Brostrend AC3L.
Problem is when i try to install the drivers in my debian template with terminal command :
sh -c ‘wget linux.brostrend.com/install -O /tmp/install && sh /tmp/install’ it says: unable to resolve host adress ‘linux.brostrend.com’
Thank you for your answer, it seems that the drivers have installed, but the dongle still not appears when i attach it to my sys net vm, do i have to do anything else after that?
Thank you
Maybe you need newer firmware for your dongle from backports. Check the sys-net-vm log to see if you have some errors when you attach your dongle to this VM.
if i install the driver in sys-net, everything works fine and i can use the dongle, but of course when i restart the computeur, the drivers are gone…
I dont really know what to do now…
The install script is using wget to download packages:
# Download a file from the Internet
download() {
if is_command wget; then
re wget --no-check-certificate -nv "$@"
elif is_command curl; then
re curl --insecure -O "$@"
elif is_command busybox; then
re busybox --no-check-certificate wget -nv "$@"
else
die "Please install wget or curl and then re-run the installer"
fi
Add proxy to wget command in install script before you run it in template.
Or you can run this command instead without modifying the install script: export https_proxy=http://127.0.0.1:8082/; export http_proxy=http://127.0.0.1:8082/; wget http://linux.brostrend.com/install -O /tmp/install && sh /tmp/install’
Hello, i did try to type your command in the terminal but nothing happened, i also did try to download and after to run the last command you gave me but still nothing happened in the terminal…
You can check the file type with file - it should be “POSIX shell
script…” ls -l will show you the size - 19168
If correct this is the install script - it will try to install packages and download stuff.
For that to work in the template you will need to set the proxy first:
i went to terminal and i typed: cd Documents because the script is in this folder then i typed: ```
then enter
then export http_proxy=http://127.0.0.1:8082/
then i typed sh/ and manually moved the install script.
the install then begins, and finish by saying: wget: unable to resolve host address ‘linux.brostrend.com’
Aborting, command failed: wget --no-check-certificate -nv https://linux.brostrend.com/rtl88x2bu-dkms.deb
ERROR: The driver was NOT successfully installed!
You can copy from terminal by selecting the text with mouse and pressing Ctrl+Insert and you can paste into terminal by pressing Shift+Insert.
Or right click in terminal window and copy/paste.
