Why to Qubes backups take a bazillion years?
I’m on 4.1.2 (r4.1) with Debian 11 vm and I need to upgrade Qubes.
Regarding Qubes, I have a PDF reader/writer application. Should I create a VM then install the one off software into that?
Or do I install the software into the template?
      • resolved question below - - -
        Nevermind - I’ll either delete the stand alone. Or wipe the drive and do a fresh install.
        How does the in-place upgrade handle standalone VMs? Will it ignore it? Will it upgrade it? The standalone is a hold over from when I started out with Qubes but now it is time to the Qubes.
      • resolved question above - - - -
Unrelated. Why to Qubes backups take a bazillion years?
My “workaround” will be to copy the data to a drive. Install the upgrade. Then copy the data back.
Thanks.
As of backup it depends.
6 months ago I’ve had 40gb backup, last month I’ve had 160gb backup… to the NAS.
You know you can open several topics? :slight_smile:
I changed the title, could you remove outdated parts of your original post?
You can try to change the compression algorithm:
Or you can remove some qubes from the backup? I have some qubes containing mostly data. I back up the data with another tool and don’t bother backing up those qubes.
Provide more details if you really want to solve this.
I bookmarked a long thread on backups that I will read later. For now I am comfortable with copying the data and software configuration files to storage.
Try turning off compression. Much faster.
