Why is there a 11G partition called /dev/xvdc3 in sys-usb?
Hello.
Qubes 4.2.4 .
I don’t remember any installation for 11Gigs Linux partition within my laptop that should be available to my sys-usb . I’ve checked - no usb sticks connected to my ports. I run fdisk -l as root in my sys-usb & I have it.
Is it something usual I should be aware of & it’s normal that I can’t mount it?
Or may be this is something that didn’t disconnect properly from previous attachments to sys-usb?
root@sys-usb:/home/user# fdisk -l
Disk /dev/xvda: 20 GiB, 21474836480 bytes, 41943040 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: F4796A2A-E377-45BD-B539-D6D49E569055
Device      Start      End  Sectors  Size Type
/dev/xvda1   2048   411647   409600  200M EFI System
/dev/xvda2 411648   415743     4096    2M BIOS boot
/dev/xvda3 415744 41940991 41525248 19.8G Linux filesystem
Disk /dev/xvdb: 2 GiB, 2147483648 bytes, 4194304 sectors
Disk /dev/xvdc: 12 GiB, 12884901888 bytes, 25165824 sectors
Disklabel type: dos
Disk identifier: 0xc0152bf4
Device     Boot   Start      End  Sectors Size Id Type
/dev/xvdc1         2048  2099199  2097152   1G 82 Linux swap / Solaris
/dev/xvdc3      2099200 25165823 23066624  11G 83 Linux
Disk /dev/xvdd: 683.35 MiB, 716541952 bytes, 1399496 sectors
root@sys-usb:/home/user# mount |grep xvdc
root@sys-usb:/home/user# mkdir /mnt/tmp;mount /dev/xvdc3 /mnt/tmp
mount: /mnt/tmp: wrong fs type, bad option, bad superblock on /dev/xvdc3, missing codepage or helper program, or other error.
      dmesg(1) may have more information after failed mount system call.
it’s the default disks of the qube for it to work.
Your question isn’t “lame” (except the title :slight_smile:).
See: Template implementation | Qubes OS
Thank you both for answer & especially for link to documentation (I mark since then your reply as solution) - the 1st page of Template implementation contained exact note that these partitions will be regenerated on each start, thus I guess it’s okay to have it non-mountable w/o additional efforts.
