The problem is that is does not boot on a laptop. The same laptop that was booting from R4.2 boot USB drives. And the same laptop boots Kubuntu iso image copied in the same way with dd.
The drive is visible in the boot list, but selecting this flash drive does not boot anything, I get back to the list almost instantly.
Notes:
I checked that Qubes-R4.3.0-x86_64.iso is not corrupted.
I tried writing with dd twice, no difference.
I see the Qubes-R4.3.0 boot media in the list in BIOS, I see EFI directory on flash drive and other files.
Did not get your statement.
Legacy boot - is boot starting from MBR (first sectors of the disk). While EFI directory on is the modern way of boot.
I want to boot with modern boot (from EFI directory). The laptop is not even supporting legacy MBR boot, I do not want to use it, nor it is used by Qubes OS.
OK. I solved it, it was my fault: the problem was that I used 8 GB flash drive, and R4.3.0 is the first version that does not fit in 8GB (I expected 7.6GiB to fit, but it does not).
The error message of dd is hard to notice due to terrible output design, I was falling for that before: no ERROR message, no color in colored terminal, no proper error message location of message (in the middle instead of the last line):
$ sudo dd conv=fsync status=progress of=/dev/sda if=Qubes-R4.3.0-x86_64.iso
7888337408 bytes (7.9 GB, 7.3 GiB) copied, 443 s, 18.4 MB/s
dd: writing to '/dev/sda': No space left on device
15417345+0 records in
15417344+0 records out
7893680128 bytes (7.9 GB, 7.4 GiB) copied, 444.713 s, 18.4 MB/s
