Whonix update issue
For the last fortnight or so, I am not able to update whonix templates. Rest templates and dom0 can be updated.
I use onion repositories.
Qubes 4.2.4 ?
If yes → Stuck between Whonix 17 deprecation and kernel >6.6 issues on Qubes 4.2 – looking for guidance - #12 by networkman
No? → we need more infos! Error messages etc…
4.3 fully updated with whonix 18.
Some repo fails to connect or download something like that
The (usually reliable) Whonix onion server has been down a good share of the past two weeks, so I’ve had the same update issues. I’ve noticed the Qubes and Debian onion repos have been down a bit over the same time period, an unusual correlation.
I have had the repo issue (non onion) but if i try a couple more times it resolves
Also try posting here. One of the devs will probably respond
Bumping this with the following update from adrelanos, since the problem persists and it’s the qubes onion which appears down atm.
Can confirm. Qubes onion has been down for hours now, I am unable to
update my templates:
Updating <REDACTED>
Refreshing package info
Refreshing available packages.
Fail to refresh InRelease: tor+http://deb.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.3/vm trixie InRelease from tor+http://deb.qubesosfasa4zl44o4tws22di6kepyzfeqv3tg4e3ztknltfxqrymdad.onion/r4.3/vm/dists/trixie/InRelease
Was down yesterday too (didn’t try the repository… but the website uses the same and was not working). If only someone would have invented monitoring… :upside_down_face:
I dont believe this to be true. There may be Tor network issues, but
that’s all.
I was able to connect just now, the first time since sometime yesterday.
Updating <REDACTED>
Just now I was able to connect to the deb.qubes....onion and update my
templates. Get in while its still open.
