Hi
From qubes-gui-configuration:
- Check for dom0 updates
- Disable (Enable) checking for updates for all qubes.
How to make changes via terminal (or bash)? What configuration files need to be fixed?
Hi
I think it is disabled by qvm-features <vm> service.qubes-update-check ''
Thanks.
probably the easiest way for most is via the Qubes Global Settings application.
