Where is the most optimal place to put custom folder icons?
Anyone know the most optimal place to put custom folder icons in fedora?
~/.local/share/icons
or
/usr/share/icons
would it be the same location in a template as it would to make them persistent in a one-off appvm?
how about debian/whonix?
thanks in advance!
ava
fedora!
info —> User Guide - Customizing the Desktop - Fedora Project Wiki
Would it be the same location in a template as it would to make them persistent in a one-off appvm?
To be persistent in AppVM info —> Redirecting…
How about debian/whonix?
Same just apply fedora instruction its still linux.
You also need to take in cosideration your Windows Manager i3,Awesome,xfce4,Wayland etc:.
RTFM! your Windows Manager docs!
Cheers!
~X
p.s. “Feel free to dm if you need help”
thx for the reply!
not sure why you linked this. it does not help answer my question.
thx. i know how use bind-dirs because, as you said, i “rtfm” :smirk:.
to clarify, what i asked was “where is the most optimal place to put custom folder icons?” and is it the same place in a template (fedora or debian/whonix) as in an appvm to make them persistent?
this is a qubes specific question (answer below).
using bind-dirs is not necessary since “In an app qube all of the file system comes from the template except /home , /usr/local , and /rw.”
so, ~/.local/share/icons is a persistent place to place the custom folder icons and so is /usr/share/icons.
the answer as i have come to understand it is…
if you want the custom icons to be available system-wide for all users and/or install them in a template so they will carry over to appvms based on that template, then place the folder icons in /usr/share/icons
if you only have one user account, or just want to install the custom folder icons for one appvm, then place them in ~/.local/share/icons and they will remain persistent.
hope this helps someone
ava
ps. @xn0px90 cheers! thx for replying and for offering further help via dm.
