OK so I have an older 256mb USB drive I was trying to mount. Yesterday I believe I used a Whonix/Fedora disposable VM to format it Fat32 (that should offer the most compatibility no?) and I suspect that may be related because yesterday when I plugged in the USB and mounted to the VM, it showed up in the file manager. Today not so much. When I run a “sudo lsblk” I see the drive, though it shows undersized (16mb) and is labelled ‘sda’. If I try and mount I get:
sudo mount /dev/sda /media
mount: /media wrong fs type, bad option etc.
Is there a way I can mount it without losing the drive contents?
