B_ryr
May 16, 2022, 3:53pm
1
So I have Ubuntu & Arch hvm’s I built. Working great, minus the networking issues “qubes os 4.1” is having seen here with this issue…
opened 08:31AM - 03 Apr 22 UTC
T: bug
P: default
needs diagnosis
C: networking
[How to file a helpful issue](https://www.qubes-os.org/doc/issue-tracking/)
#… ## Qubes OS release
4.1
### Brief summary
Installing any OS inside any HVM will require internet configuration (adding IP,GW,netmask..etc), And to know these information they are available from Qubes manager settings for the created HVM, But when adding the Gateway IP inside the network-manager of the OS it wont accept it, instead it needs manual fix for the GW. (This issue appeared in 4.1 **only**, in 4.0 it was correct)
### Steps to reproduce
- Install any OS inside an HVM-Qube (in my case Kali/Debian)
- Try to make it connected to the internet
### Expected behavior
Gateway IP should be like this: (10.137.0.1)
### Actual behavior
But its: (10.138.26.251)
### Good to link
False/Wrong/Not working Netmask (if taken literally)
#4189
Now what would happen IF I changed these “hvm’s” to “pv”?
The reason I ask is I would like to be able to (copy/paste) between the hvm’s and other domains I have open. I have read that I would need to install some qubes packages to provide
some level of interaction with other qubes - qvm-copy, qvm-open,qvm-block…etc. But I can’t find what packages I would need to install into these hvm’s let alone even if Ubuntu or Arch would have suck packages available within there disto’s.
My thinking is changing the hvm’s to PV would address or allow…
Anyone have any ideas??
You need to have Qubes agents installed for these functions to work for either HVM or PV domains.
So changing HVM to PV will change nothing.
B_ryr
May 16, 2022, 5:12pm
3
@tzwcfq thank you
but how or where would I find “these” Qubes agents?
-hvm…ubuntu
-hvm…arch
Both of that systems are avaliable as Community Templates for Qubes Contents/building-archlinux-template.md at master · Qubes-Community/Contents · GitHub . You can easliy build them using Qubes Builder and install them. Also there are install ready templates for those system provided by @unman Index of /Templates_4.1 . Using template will be simpler then trying to install qubes agents for distros that don’t have qubes agent repos.
B_ryr
May 16, 2022, 7:35pm
6
@Szewcu thank you, yes I do know unman builds templates, nice ones too at that. I will review the GitHub link you sent. I never really looked at it.
@tzwcfq yes I will def check out the topics
rrn
October 23, 2023, 6:18pm
7
Are there any Ubuntu templates released for 4.2? @unman ’s templates list only those for 4.1.
