I’m trying to install onto a newly installed SSD on a newer Lenovo, and it hangs. It seems like others have gotten this model to work.
I downloaded the installer and verified the ISO. I copied it to a new USB 3.1 flash drive using dd. The Lenovo is set to boot first from the USB drive and it does. I get a bunch of screens with tiny text and the installer says it’s starting. Then it just hangs for about 30 seconds and a cursor comes up which I am able to move around. But nothing else happens, just a black screen.
From the help page, might this apply to my situation? I thought that it would not apply since the drive does boot. “Some laptops cannot read from an external boot device larger than 8GB. If you encounter a black screen when performing an installation from a USB stick, ensure you are using a USB drive less than 8GB, or a partition on that USB less than 8GB and of format FAT32.”
So would I have to try something other than dd? I want to download and copy within Tails and I am not sure if I can get “tools like Rufus, balenaEtcher or the GNOME Disk Utility”.
I have TPM and the absolute persistence module disabled.
The ls command returns “(hd0) (hd0,msdos1) (hd1)”.
I tried “configfile (hd0)/boot/efi/EFI/qubes/grub.cfg”, “configfile (hd0,msdos1)/boot/efi/EFI/qubes/grub.cfg”, and “configfile (hd1)/boot/efi/EFI/qubes/grub.cfg” but the screen just refreshes to a new prompt. If I turn off the laptop and turn it back on after any of these, it doesn’t do anything differently either.
Can you enable legacy boot mode from BIOS? But, to enable legacy boot, it seems that you would need to disable “Kernel DMA Protection” in the “Security” → “Virtualization” menu, as far as I googled it.
I don’t see Legacy mode. I don’t think I have that because it’s a 2021 model
“Intel previously announced that in 2020 they are phasing out support for legacy Basic Input/Output System (BIOS) boot mode. This means that many of the Lenovo products launching in 2020 will no longer support the Legacy Boot option in BIOS.”
I just remembered that one of the Qubes OS developers is releasing a weekly build, which includes a newer kernel than the 4.1-rc1 and rc2 build. New hardware requires a new kernel.
So, could you try to download Qubes-20211120-kernel-latest-x86_64.iso from the following link and test it? https://qubes.notset.fr/iso/
