What is the best program to run in dom0 to view images such as screenshots?
None. No one serious about Qubes OS would advise you to do that in dom0, otherwise it would already be there. At the end of the day, it’s just Fedora in dom0 if you insist.
Copy the screenshot from dom0 to a qubes and view it there - eg in dom0:
qvm-copy-to-vm disp7318 Pictures/Screenshot_2024-01-22*.png
and in disp7318:
eog QubesIncomming/dom0/Screenshot_2024-01-22*.png
this is for viewing when i take a screenshot
i would rather view it using a program than view it by making it the wallpaper
if it’s my screenshot it’s not infected
it’s not about the screenshot. It’s about the viewer. Malicious one, some day…
None. View it in an app qube instead.
In Qubes OS 4.2, you have a thumbnail in the screenshot tool.
If it’s not enough, you could use nsxiv or sxiv (the former is a newer fork of the latter), they are minimalist picture viewers.
As other said in the thread, dom0 isn’t meant to be used for anything except managing windows and the system.
Qubes OS has GraphicsMagick installed in dom0, you can use it to view and edit images.
is there a way to associate png files with gm so I can just click on things when I run thunar in dom0? i can associate png files with gm but not gm display.
can i install sxiv in dom0 with sudo dnf install or do I need to get this rpm and then check the hash and move it into dom0 which seems risky?
you need to configure xdg-open, see Solene'% : Change default application for xdg-open
you can install sxiv from dom0 if it’s the official repos, don’t worry ![]()
[user@dom0 ~]$ sudo dnf install sxiv
Qubes OS Repository for Dom0 0.0 B/s | 0 B 00:00
Errors during downloading metadata for repository ‘qubes-dom0-cached’:
- Curl error (37): Couldn’t read a file:// file for file:///var/lib/qubes/updates/repodata/repomd.xml [Couldn’t open file /var/lib/qubes/updates/repodata/repomd.xml]
Error: Failed to download metadata for repo ‘qubes-dom0-cached’: Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
Ignoring repositories: qubes-dom0-cached
No match for argument: sxiv
Error: Unable to find a match: sxiv
i still don’t know how to do it
am i using the wrong command because it’s dom0?
there is a bug currently that should be fixed very soon that prevent the proxy update to work. You can update / install packages at the moment, it’s already fixed in the testing branch though, it should be available within one day or a couple of days.
Hi, I have the same problem and can also not install sxiv. Is there a solution?
For installing in dom0 you use qubes-dom0-update
In this case qubes-dom0-update sxiv will do it.
Hello unman - thank you very much for your help. It installed perfectly:-)
this works really well!
Thank you very much - and apologies for not having replied sooner.
Best regards
