What is your “dream” QubesOS hardware?
The title says it, but some extra clarification:
  • Money is no object (assume it’s free)
  • Can be built, is currently for sale, or release is imminent (realistically attainable, but not necessarily in stock)
  • Laptop or workstation, your choice
  • Security features or performance, your choice
  • Proven “compatible” with QubesOS or not, your choice
  • Approach it however you like, as your personal ideal or as a recommendation for a new user
Personally, I’m very happy with a HEDT with a latest generation Threadripper Pro + lots of fast RAM and disk, on WRX90 platform.
(The downside to this platform, as others have suggested, is the presence of AMD PSP but it’s not a major concern for me.)
Interested to hear others dream platforms
Nice setup! I had to google most of it… I’m so out of touch with modern hardware that for me, a non-vPro Gen 8+ Thinkpad (T- or X-series) with 64Gb RAM would be perfect!
(I have a couple of T480 which are vPro and maxed out on 32Gb)
  • PCIe Gen 5 SSD, 2TB+ (from Goodram ofc :slight_smile: )
  • 128GB of RAM
  • CPU with at least 32 physical cores
EPYC 9005 CPU with a Gigabyte MZ33-AR1 motherboard running coreboot.
  • A fast-enough processor to have 12 or more AVM’s open at once - that means a modern one, but without any remote management capability.
  • No “AI” nonsense, either. (See: Lenovo)
  • 64GB RAM or more. The more the merrier.
  • Two internal disk drives, so when I do backups I don’t write to the drive I am backing up. (Yes, I am going to copy that backup file offline but that will be a separate operation.)
  • For a desktop (for at-home work when a large monitor is desired):
a) TWO PS/2 ports for wired mouse and keyboard. Don’t make me hunt down a compatible Y-cable. Neither USB nor Bluetooth should ever be used for any dedicated local peripherals.
b) Desktop should be “mini” size - there’s no need for bulky towers anymore.
  • For a laptop (for portability):
a) 16" screen at a minimum. Not all of us have 20-year-old eyes anymore.
b*) Physical Left- and Right-click keys that are SEPARATE from the touchpad. Words cannot express the importance of this. I have had too many problems with phantom clicks on boxes that lack these. (In addition, my current laptop has a middle-click response in its touchpad, which cannot be turned off in Qubes and which renders the Right-click area minuscule. It should lose its certification over this. As a result, I am using a USB mouse and have gone through the settings in various applications to disable all the middle-click functions. They’re usually destructive.)
c*) a caps-lock indicator light, preferably on the caps lock key itself. This used to be universal. It’s a hardware configuration; it requires hardware-level notification. There is no other indication when entering disk passwords or the initial login password.
d*) A full-size right shift key. Some vendors try to reuse the space taken by the left half, some the right half. I have to go back and forth between machines. My fingers know where that key is supposed to be and I’m tired of getting an up arrow instead. Move all four arrow keys frontward instead and don’t shrink them.
(In other words, vendors, stop messing with the keyboard layout and fire the minimalists.)
  • Not one but two RJ45 ethernet ports. One for my internal LAN (where there are boxes without an Internet connection) and one for my netVM that handles traffic for updates, the financial AVM, and the router configuration AVM - a completely separate network path from the Wi-Fi that handles ordinary surfing.
  • separate controllers for each USB port so that they can be assigned individually.
  • separate kill switches for Wi-Fi, Bluetooth, camera, and microphone. Too often these are combined, but I need Wi-Fi on and Bluetooth dead.
And, of course,
  • Qubes installs and runs flawlessly without any tweaks. This includes hibernation and suspend.
I don’t mention any preferred brands. This stuff should be sufficiently standardized that the boxes would be interchangeable (except perhaps for the 2nd ethernet port) and EVERY vendor should be offering at least one model that meets these modest criteria. This includes companies like System76, who don’t even think about Qubes. Few of the above features are specific to any OS.
Most of the above is about usability, not power, but that’s where everything that is currently available falls flat. The state of the industry right now is so poor that I dream of simply getting something that I can USE effectively.
I believe this all could be built, but may require several entities in the supply chain to participate.
yes
one day i hope to have pcie gen 5 with TB5 so I can hook up a eGPU for AI tasks
Lenovo THinkPad P16 (newest I have tried) for build quality
CPU w/ Min 48 cores and unified memory
DDR5 w/ min 4 slots (min 128GB) all 64GB compatible
PCIe 5 with min 2 slots
dGPU
as said manual disconnect switches ( from GordonC)
USB groups for say Thunderbolt seperate from USB-C and USB-A
CORE-BOOT
Threadripper PRO 9995WX , 2 TB DDR5 ECC, 6x Nvidia RTX 6000 96GB, WRX90 motherboard, 4x4 TB NVME
Everything cooled by a custom hard water loop
Whatever will take me to iGPU virtualization sooner :-/
Dito.
I wish for hardware that fit meaning of certificated hardware in my eyes:
  1. At less 2 USB controllers that I can split between sys-usb’s according to physical location or type of ports.
  2. Camera and microphone separated from main set of controllers.
  3. Fully function sys-gui (software issue)
  4. Build-in compact version of satellite battery :grin:
A laptop with coreboot, a lot of ram, that doesn’t get super hot and has decent battery life.
@novacustom satisfies the first two of these. But since its CPU is
still x86 architecture, you do feel the heat. The battery life is meh.
But again, the V56 (96 GB RAM) is the best hardware to run QubesOS, imo.
…need to find new battery for my “IBM” T700 :slight_smile:
On my experiense i9-13900H handle smoothly any load in Qubes, compare to Ultra 155H.
Qubes at the moment have optimization problem with combined CPU’s.
Afaik you can pin CPUs so a VM can have only performance or efficiency cores.
And for heavy loads you could just give the VM all cores.(what I do when compiling).
My current setup. A KGPE-D16 without any any PSP blobs running heads with 15h.org coreboot.
Would you consider that your “dream” Qubes OS hardware?
My current system too :). It does everything I want it to, and does it well. A more powerful system would do nothing for me but make me feel guilty about wasted potential.
As for what I like about it
  • 64GB of fast ram (6200MT with manually-tuned timings). Everything feels snappy.
  • iGPU + 2 dGPUs so I can have games and videos all over my screens if I want
  • ps/2 keyboard
  • usb pcie card for dedicated i/o passthru to a qube
