What is the best VPN communication for Qubes?
What is the best way to communicate with VPN for Qubes? I’m particularly interested in the two types below.
1 Create an APPVM based on a Whonix template and then use the VPN app to perform VPN communications from there
2 Use VPNConnections on the WIFI network on the home screen and use open VPN communication
What is the difference between these? Also, which is safer? Incidentally, the Qube I use all the time is Whonixqube. Currently, we are using openVPN communication. However, it seems that the VPN communication is directly performed to dom0, the underlying source, rather than to whonixTemplete. Does using OpenVpn from the home screen undermine Whonix’s inherent anonymity? Also, is this method lessening the anonymity related to Dom0 or other things?
