I found this source:
https://dev.qubes-os.org/projects/core-admin-client/en/stable/manpages/qvm-pool.html
I have no clue wth I am looking at.
I just want to know what it is and what it can do or its typical “use cases”
Thanks
Thanks
In contrast what is a “varlibqubes” in context of “storage pool”? And what are its usual suggested use cases?
I think I finally found some starting points as to what these are and do …
Blockquote
/var/lib/qubes/qvm-pool is a command line tool. I don’t know all the use cases but it’s useful to add a Secondary Storage.
I had the impression that it was a way to manipulate LVM volumes the Qubes way.
Yeah at first I was manually inputting spec onto a New Qube in the GUI Qube Manager, but then I gave up for the sake of time and decided to Clone Vault but give the 2nd Vault USB access so to be a place to migrate files from the laptop onto an external drive — especially now realizing how much my future planned Templates will take up in space sheesh I will eventually need more disk space lol even though I maxed out the hard disk specs on this laptop order
