What happened to attaching USB to qubes?
I don’t know what happened but today I noticed that I can no longer attach USB storage device (“USB stick”) to my disposable qubes (tried attaching to debian-based disposables, as well as whonix-based disposables).
I plug in the USB stick to the USB port of my NV41 laptop. Then, on the devices sys tray icon, I click on “SanDisk” device (sys-usb: 4-3) and attach it to a disposable. In the disposable terminal I use the command lsblk to check any new usb devices, and I don’t see any.
Has something changed with the way qubesos does its usb attaching to the qubes? It was working very well up to today. If it was a change from the qubesos development, well then, these are the kinds of things that make the user wish the devs didn’t change.
OK. I noticed that I can attach the USB to the qubes if I select the device from Data (Block) Devices header. But trying the attaching from USB Devices header fails as I described in my original post (OP).
This was not the way it was before. Before, I had always done my attaching from the USB Devices header and it worked.
What is going on? Why is there now a confusing UI with USB storage device attachment workflow on the devices systray?
Run this command in disposable qube before attaching USB device to it:
sudo journalctl -f -n0
And in sys-usb as well:
Then try to attach the USB device from sys-usb to disposable qube.
Check the logs to see if there are any errors.
Had similar problems yesterday in doing this. Thanks aparatus for your suggestions. Will try this out too.
Thanks for these suggestions, but why are they needed now?
These commands are not a fix to your problem, they will show you the system logs to see if there are any errors there to debug the problem.
Hmm … it works for me… R4.2.3 up-to-date, in a debian-12-xfce -based dvm, attaching USB stick via the menu:
user@disp1999:~$ lsblk
NAME    MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
sda       8:0    1 114.6G  0 disk
└─sda1    8:1    1 114.6G  0 part
EDIT: works in fedora-39 dvm’s too.
what lsusb and lsusb -t shows in disposable after attaching? Does qui-device widget shows that SanDisk is attached to disposable?
