Response from ChatGPT PRO! mode
Diagnosis
The linked message asks what ChatGPT would say about the original post. The underlying “issue” is not a demonstrated Qubes OS vulnerability. It is an incorrect attack-chain assumption:
browser exploit
browser qube compromised
↓ assumed
sys-net compromised
↓ assumed
sys-usb compromised
↓ assumed
all keystrokes captured
Only the first transition follows from a browser exploit. Every later arrow requires a different vulnerability, unsafe policy, or configuration error. The forum argument effectively assumes three successful exploits and then treats the resulting conclusion as proof that isolation does not work.
“VM escape to sys-net” is the wrong terminology
A VM escape normally means escaping a guest into the hypervisor or host. sys-net is another guest VM, not the host.
There are two materially different scenarios:
Browser qube → sys-net through networking:
This is guest-to-guest lateral movement. The attacker would need a separate vulnerability in the virtual network backend, the sys-net kernel, or another service reachable from the browser qube. Sending packets through sys-net does not grant code execution in sys-net.
Browser qube → Xen/dom0 through a genuine VM escape:
This is potentially catastrophic because Xen and dom0 are part of the trusted computing base. But then the attacker has escaped Qubes’ principal security boundary directly; there is no technical reason they must “hop” through sys-net and sys-usb first.
Qubes explicitly says that applications inside one qube are not isolated from each other. A browser compromise can therefore expose that qube’s files, cookies, active sessions, and other applications. The intended protection is that the compromise does not automatically expose software and data in other qubes.
Why the proposed sys-net → sys-usb path does not exist by default
A normal sys-usb configuration has no NetVM, and Qubes’ own configuration disables networking there. The default input policy also denies keyboard forwarding unless the administrator explicitly configures it. In other words, sys-usb is not ordinarily a network peer reachable from sys-net.
A compromised sys-net is still serious. It can:
observe network metadata;
inspect or change unencrypted traffic;
disrupt connections;
attempt active attacks against qubes connected through it;
attack their network stacks with malicious packets.
But Qubes’ documentation specifically distinguishes those connected qubes from qubes using another NetVM or no networking at all. A compromise of one NetVM does not itself confer access to unrelated or networkless qubes.
To move from sys-net into sys-usb, the attacker would still need something such as:
another Xen or virtual-device vulnerability;
a dangerously permissive qrexec policy or vulnerable custom qrexec service;
a dom0/GUI compromise;
a firmware, DMA, or hardware-level attack;
an administrator-created connection between the two qubes.
Qrexec calls are policy-controlled, and the normal result when no matching permission exists is denial. Custom services and broad allow rules can weaken this, which is why qrexec policy should be kept minimal.
The keylogging claim
Ordinary application qubes do not receive keyboard events intended for other qubes. Qubes’ GUI system sends input to the qube containing the focused window, so compromising one ordinary browser qube does not create a system-wide keylogger.
There is an important exception: when a USB keyboard is assigned to sys-usb and its input is intentionally proxied to dom0, sys-usb becomes part of the trusted input path. A compromised sys-usb could then observe input from that keyboard. Qubes explicitly warns about this risk. That is a reason to protect sys-usb carefully—not evidence that sys-net can automatically compromise it.
What Qubes actually promises
Qubes does not promise that:
browser vulnerabilities cease to exist;
Xen can never contain a vulnerability;
dom0, GUI, qrexec, firmware, or hardware can never be compromised;
one machine can safely withstand every hypothetical zero-day chain;
separating identities automatically prevents browser fingerprinting or behavioral correlation.
It promises a reduction in blast radius through compartmentalization. A browser zero-day should ordinarily compromise the browser’s qube, not immediately every document, credential, USB device, and security domain on the computer.
A real Xen or other trusted-computing-base vulnerability can defeat that model. Qubes maintains a Xen security-advisory tracker precisely because such vulnerabilities are possible. The defense is a relatively small trusted computing base, reduced interfaces, compartmentalization, and timely patching—not a claim of invulnerability.
Concrete configuration changes
First, use a supported and fully updated release. As of July 2026, Qubes OS 4.3.1 is the current stable release, while the Qubes 4.2 series reached end of life on June 21, 2026 and no longer receives security updates.
In dom0, inspect the relevant network assignments:
qvm-prefs sys-usb netvm
qvm-prefs vault netvm
Both should show that no NetVM is assigned. To remove networking from a qube deliberately:
qvm-prefs vault netvm ''
qvm-prefs sys-usb netvm ''
Then apply these boundaries:
Use disposable qubes for hostile browsing.
This limits filesystem persistence after shutdown. It does not prevent a live browser exploit or prevent the same remote exploit from succeeding again on a later boot.
Keep secrets in networkless qubes.
Password databases, private keys, recovery codes, and sensitive documents should not reside in the same qube as an everyday browser.
Keep sys-usb offline.
Do not install browsers, communication clients, or unrelated software in it. Treat it as especially trusted when it proxies a USB keyboard.
Consider disposable sys-net and sys-firewall.
Qubes officially supports named disposable service qubes for these roles. This reduces persistent modification of their writable filesystem, although it does not stop live compromise.
Audit qrexec policy.
Inspect /etc/qubes/policy.d/ in dom0. Remove unnecessary broad allow rules, especially rules involving dom0, input devices, file transfer, URL opening, or custom services.
Separate high-risk network domains.
A high-risk browsing qube does not have to share the same NetVM chain as administrative or especially sensitive networked qubes.
Use physical separation for the highest threat levels.
Qubes substantially improves compartmentalization, but all qubes still share Xen, hardware, firmware, and ultimately one physical computer. Truly independent trust domains may warrant separate machines.
A response suitable for posting to the thread
The proposed chain assumes the very vulnerabilities it is supposed to demonstrate. A browser exploit compromises the browser qube. It does not automatically grant execution in sys-net merely because traffic is routed through sys-net. Compromising sys-net would require another vulnerability in a reachable network, kernel, virtual-device, qrexec, or hypervisor interface.
Likewise, sys-usb normally has no network connection, so sys-net has no ordinary route to it. Moving from sys-net to sys-usb would require yet another independent vulnerability or a dangerous administrator-created policy. A compromised ordinary qube also cannot normally read keyboard events delivered to other qubes.
There is a real caveat: if sys-usb proxies a USB keyboard, compromising sys-usb can expose that keyboard’s input. That makes sys-usb a trusted component and is why it should remain offline and minimal. It does not establish that sys-net can compromise sys-usb.
A genuine Xen, dom0, GUI, firmware, or hardware compromise can defeat Qubes. Qubes does not claim otherwise. Its security claim is that an ordinary application compromise is contained by default, so the attacker must find and successfully exploit additional boundaries instead of receiving access to the whole machine automatically.
Therefore, the correct conclusion is not “Qubes cannot secure against hacking.” It is: Qubes turns one compromise into a contained compromise unless the attacker also has a valid escalation chain. Such a chain must be demonstrated arrow by arrow rather than assumed.
That addresses the technical confusion without overstating Qubes’ guarantees.
