What do you think could be the solution? (USB Wi-Fi EDUP EP-AX1672)
The USB Wi-Fi adapter EDUP EP-AX1672 works with Tails but not with Qubes. It is recognized in Qubes’ sys-usb, but even when the adapter is connected to sys-net, it doesn’t work. I wonder why, even though Qubes has a newer kernel than Tails. I used the Debian template.
Can you try with a Fedora template?
Might be missing firmwares.
I changed it to Fedora 42 and tried it. It didn’t work.
Check the output of this command in sys-net terminal and search for errors related to your network adapter:
sudo dmesg
Check these logs in dom0 and search for errors related to your network adapter:
/var/log/xen/console/guest-sys-net-dm.log
/var/log/libvirt/libxl/libxl-driver.log
This is the result
sudo dmesg
[ 116.522635] mt7921u 2-1:1.0: hardware init failed
2025-09-17 13:28:08.671+0000: libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn’t support reset from sysfs for PCI device 0000:00:14.0
2025-09-17 13:28:10.380+0000: libxl: libxl_pci.c:2098:do_pci_remove: Domain 8:xc_physdev_unmap_pirq irq=17: Invalid argument
2025-09-17 13:30:26.895+0000: libxl: libxl_pci.c:1587:libxl__device_pci_reset: The kernel doesn’t support reset from sysfs for PCI device 0000:00:14.0
I couldn’t understand where the problem areas is.
Need to see more log messages before/after this one to see what the problem is.
There should be related errors before this message that were the cause of the hardware init failure.
[ 951.346647] vhci_hcd: urb->status -104
[ 951.352313] vhci_hcd: unlink->seqnum 5312
[ 951.352432] vhci_hcd: urb->status -104
[ 951.357620] vhci_hcd: unlink->seqnum 5313
[ 951.357667] vhci_hcd: urb->status -104
[ 951.366556] vhci_hcd: unlink->seqnum 5314
[ 951.366608] vhci_hcd: urb->status -104
[ 951.370969] vhci_hcd: unlink->seqnum 5315
[ 951.371013] vhci_hcd: urb->status -104
[ 951.376300] vhci_hcd: unlink->seqnum 5316
[ 951.376419] vhci_hcd: urb->status -104
[ 951.381658] vhci_hcd: unlink->seqnum 5317
[ 951.381703] vhci_hcd: urb->status -104
[ 951.386212] vhci_hcd: unlink->seqnum 5318
[ 951.386254] vhci_hcd: urb->status -104
[ 951.391903] vhci_hcd: unlink->seqnum 5319
[ 951.391948] vhci_hcd: urb->status -104
[ 951.397822] vhci_hcd: unlink->seqnum 5320
[ 951.397867] vhci_hcd: urb->status -104
[ 951.402429] vhci_hcd: unlink->seqnum 5321
[ 951.402473] vhci_hcd: urb->status -104
[ 951.408045] vhci_hcd: unlink->seqnum 5322
[ 951.408090] vhci_hcd: urb->status -104
[ 951.418253] vhci_hcd: unlink->seqnum 5323
[ 951.418302] vhci_hcd: urb->status -104
[ 951.424821] vhci_hcd: unlink->seqnum 5324
[ 951.424866] vhci_hcd: urb->status -104
[ 951.430881] vhci_hcd: unlink->seqnum 5325
[ 951.430928] vhci_hcd: urb->status -104
[ 951.436043] vhci_hcd: unlink->seqnum 5326
[ 951.436086] vhci_hcd: urb->status -104
[ 951.442190] vhci_hcd: unlink->seqnum 5327
[ 951.442239] vhci_hcd: urb->status -104
[ 951.569889] mt7921u 2-1:1.0: hardware init failed
user@sys-net:~$
[2025-09-18 07:06:30] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[2025-09-18 07:06:30] MDS: Mitigation: Clear CPU buffers
[2025-09-18 07:06:30] MMIO Stale Data: Unknown: No mitigations
[2025-09-18 07:06:30] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
[2025-09-18 07:06:30] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
[2025-09-18 07:06:30] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
[2025-09-18 07:06:30] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[2025-09-18 07:06:30] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using ‘standard’ format.
[2025-09-18 07:06:30] pid_max: default: 4096 minimum: 301
[2025-09-18 07:06:30] Mount-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[2025-09-18 07:06:30] Mountpoint-cache hash table entries: 512 (order: 0, 4096 bytes, linear)
[2025-09-18 07:06:30] Performance Events: unsupported p6 CPU model 58 no PMU driver, software events only.
[2025-09-18 07:06:30] devtmpfs: initialized
[2025-09-18 07:06:30] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[2025-09-18 07:06:30] futex hash table entries: 16 (order: -4, 384 bytes, linear)
[2025-09-18 07:06:30] NET: Registered protocol family 16
[2025-09-18 07:06:30] xen:grant_table: Grant tables using version 1 layout
[2025-09-18 07:06:30] Grant table initialized
[2025-09-18 07:06:30] PCI: setting up Xen PCI frontend stub
[2025-09-18 07:06:30] xen:balloon: Initialising balloon driver
[2025-09-18 07:06:30] PCI: System does not support PCI
[2025-09-18 07:06:30] clocksource: Switched to clocksource xen
[2025-09-18 07:06:30] NET: Registered protocol family 2
[2025-09-18 07:06:30] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
[2025-09-18 07:06:30] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[2025-09-18 07:06:30] TCP established hash table entries: 2048 (order: 2, 16384 bytes, linear)
[2025-09-18 07:06:30] TCP bind hash table entries: 2048 (order: 2, 16384 bytes, linear)
[2025-09-18 07:06:30] TCP: Hash tables configured (established 2048 bind 2048)
[2025-09-18 07:06:30] UDP hash table entries: 128 (order: 0, 4096 bytes, linear)
[2025-09-18 07:06:30] UDP-Lite hash table entries: 128 (order: 0, 4096 bytes, linear)
[2025-09-18 07:06:30] Unpacking initramfs…
[2025-09-18 07:06:30] Freeing initrd memory: 23544K
[2025-09-18 07:06:30] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2844d5ba3f8, max_idle_ns: 440795222929 ns
[2025-09-18 07:06:30] clocksource: Switched to clocksource tsc
[2025-09-18 07:06:30] workingset: timestamp_bits=62 max_order=15 bucket_order=0
[2025-09-18 07:06:30] xen:xen_evtchn: Event-channel device installed
[2025-09-18 07:06:30] Invalid max_queues (4), will use default max: 1.
[2025-09-18 07:06:30] tun: Universal TUN/TAP device driver, 1.6
[2025-09-18 07:06:30] xen_netfront: Initialising Xen virtual ethernet driver
[2025-09-18 07:06:30] NET: Registered protocol family 17
[2025-09-18 07:06:30] sched_clock: Marking stable (337777040, 269423)->(339125461, -1078998)
[2025-09-18 07:06:30] pcifront pci-0: Installing PCI frontend
[2025-09-18 07:06:30] xen:swiotlb_xen: Warning: only able to allocate 4 MB for software IO TLB
[2025-09-18 07:06:30] software IO TLB: mapped [mem 0x0000000003000000-0x0000000003400000] (4MB)
[2025-09-18 07:06:30] pcifront pci-0: Creating PCI Frontend Bus 0000:00
[2025-09-18 07:06:30] pcifront pci-0: PCI host bridge to bus 0000:00
[2025-09-18 07:06:30] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[2025-09-18 07:06:30] pci_bus 0000:00: root bus resource [mem 0x00000000-0xfffffffff]
[2025-09-18 07:06:30] pci_bus 0000:00: root bus resource [bus 00-ff]
[2025-09-18 07:06:30] pci 0000:00:00.0: [8086:1502] type 00 class 0x020000
[2025-09-18 07:06:30] pci 0000:00:00.0: reg 0x10: [mem 0xdf1e0000-0xdf1fffff]
[2025-09-18 07:06:30] pci 0000:00:00.0: reg 0x14: [mem 0xdf1cb000-0xdf1cbfff]
[2025-09-18 07:06:30] pci 0000:00:00.0: reg 0x18: [io 0xdfa0-0xdfbf]
[2025-09-18 07:06:30] pci 0000:00:01.0: [8086:0085] type 00 class 0x028000
[2025-09-18 07:06:30] pci 0000:00:01.0: reg 0x10: [mem 0xdf200000-0xdf201fff 64bit]
[2025-09-18 07:06:30] pcifront pci-0: claiming resource 0000:00:00.0/0
[2025-09-18 07:06:30] pcifront pci-0: claiming resource 0000:00:00.0/1
[2025-09-18 07:06:30] pcifront pci-0: claiming resource 0000:00:00.0/2
[2025-09-18 07:06:30] pcifront pci-0: claiming resource 0000:00:01.0/0
[2025-09-18 07:06:30] blkfront: xvda: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2025-09-18 07:06:30] xvda: xvda1 xvda2 xvda3
[2025-09-18 07:06:30] blkfront: xvdb: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2025-09-18 07:06:30] blkfront: xvdc: flush diskcache: enabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2025-09-18 07:06:30] blkfront: xvdd: barrier or flush: disabled; persistent grants: enabled; indirect descriptors: enabled; bounce buffer: enabled
[2025-09-18 07:06:30] Freeing unused kernel image (initmem) memory: 708K
[2025-09-18 07:06:30] Write protecting the kernel read-only data: 10240k
[2025-09-18 07:06:30] Freeing unused kernel image (text/rodata gap) memory: 2044K
[2025-09-18 07:06:30] Freeing unused kernel image (rodata/data gap) memory: 1620K
[2025-09-18 07:06:30] Run /init as init process
[2025-09-18 07:06:30] + mount -t devtmpfs none /dev
[2025-09-18 07:06:30] + mount -t sysfs /sys /sys
[2025-09-18 07:06:30] + mount -t proc /proc /proc
[2025-09-18 07:06:30] + mount -t tmpfs -o ‘size=1m,nodev,noexec’ /tmp /tmp
[2025-09-18 07:06:30] + mkdir /dev/shm
[2025-09-18 07:06:30] + mount -t tmpfs -o ‘size=1m,nodev,noexec’ tmpfs /dev/shm
[2025-09-18 07:06:30] + mount -o remount,ro /
[2025-09-18 07:06:30] + echo 1
[2025-09-18 07:06:30] + printf ‘%d\n’ 1073741824
[2025-09-18 07:06:30] + /bin/xenstore-read target
[2025-09-18 07:06:30] + domid=1
[2025-09-18 07:06:30] + xenstore-read /local/domain/1/vm
[2025-09-18 07:06:30] + vm_path=/vm/3158a69b-79ba-45db-8745-952a2286c1a9
[2025-09-18 07:06:30] + sort
[2025-09-18 07:06:30] + xenstore-list -p /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv
[2025-09-18 07:06:30] + xenstore-read /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/001 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/002 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/003 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/004 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/005 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/006 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/007 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/008 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/009 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/010 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/011 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/012 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/013 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/014 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/015 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/016 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/017 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/018 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/019 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/020 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/021 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/022 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/023 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/024 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/025 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/026 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/027 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/028 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/029 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/030 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/031 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/032 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/033 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/034 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/035 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/036 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/037 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/038 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/039 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/040 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/041 /vm/3158a69b-79ba-45db-8745-952a2286c1a9/image/dm-argv/042
[2025-09-18 07:06:30] + dm_args=‘-xen-domid
[2025-09-18 07:06:30] 1
[2025-09-18 07:06:30] -no-shutdown
[2025-09-18 07:06:30] -nodefaults
[2025-09-18 07:06:30] -no-user-config
[2025-09-18 07:06:30] -name
[2025-09-18 07:06:30] sys-net
[2025-09-18 07:06:30] -display
[2025-09-18 07:06:30] none
[2025-09-18 07:06:30] -append
[2025-09-18 07:06:30] root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 clocksource=tsc xen_scrub_pages=0 apparmor=1 security=apparmor
[2025-09-18 07:06:30] -device
[2025-09-18 07:06:30] lsi53c895a
[2025-09-18 07:06:30] VGA,vgamem_mb=16
[2025-09-18 07:06:30] -boot
[2025-09-18 07:06:30] order=dc
[2025-09-18 07:06:30] usb-ehci,id=ehci
[2025-09-18 07:06:30] usb-tablet,bus=ehci.0
[2025-09-18 07:06:30] -smp
[2025-09-18 07:06:30] 3,maxcpus=3
[2025-09-18 07:06:30] -net
[2025-09-18 07:06:30] qubes-gui,domid=0,log-level=0
[2025-09-18 07:06:30] -machine
[2025-09-18 07:06:30] xenfv,suppress-vmdesc=on
[2025-09-18 07:06:30] -qubes-audio:audiovm_xid=0
[2025-09-18 07:06:30] 409
[2025-09-18 07:06:30] -drive
[2025-09-18 07:06:30] file=/dev/xvda,if=ide,index=0,media=disk,format=host_device,cache=writeback
[2025-09-18 07:06:30] file=/dev/xvdb,if=ide,index=1,media=disk,format=host_device,cache=writeback
[2025-09-18 07:06:30] file=/dev/xvdc,if=ide,index=2,media=disk,format=host_device,cache=writeback
[2025-09-18 07:06:30] file=/dev/xvdd,id=scsi0-hd3,format=host_device,if=none,readonly=on,cache=writeback
[2025-09-18 07:06:30] scsi-hd,drive=scsi0-hd3,scsi-id=3’
[2025-09-18 07:06:30] + usb_args=
[2025-09-18 07:06:30] + test -e /bin/qrexec-agent
[2025-09-18 07:06:30] + sed -n /^-qubes-audio:/p
[2025-09-18 07:06:30] + echo ‘-xen-domid
[2025-09-18 07:06:30] + audio_args=‘-qubes-audio:audiovm_xid=0’
[2025-09-18 07:06:30] + sed /^-qubes-audio:/d
[2025-09-18 07:06:30] + ‘[’ -z ‘-qubes-audio:audiovm_xid=0’ ]
[2025-09-18 07:06:30] + sed -n ‘s/^.[:,]audiovm_xid=([^,]+).$/\1/p’
[2025-09-18 07:06:30] + echo ‘-qubes-audio:audiovm_xid=0’
[2025-09-18 07:06:30] + domid=0
[2025-09-18 07:06:30] + sed -n ‘/^(intel-hda|ac97|adlib|es1370|cs4231a|gus|sb16)$/ {p}’
[2025-09-18 07:06:30] + audio_model=
[2025-09-18 07:06:30] + ‘[’ -n ]
[2025-09-18 07:06:30] + sed -n /^-qubes-net:/p
[2025-09-18 07:06:30] + net_args=
[2025-09-18 07:06:30] + sed /^-qubes-net:/d
[2025-09-18 07:06:30] + test -e /sys/class/net/eth0
[2025-09-18 07:06:30] + echo ‘No network interface named eth0.’
[2025-09-18 07:06:30] No network interface named eth0.
[2025-09-18 07:06:30] + ls -l /sys/class/net/
[2025-09-18 07:06:30] total 0
[2025-09-18 07:06:30] lrwxrwxrwx 1 0 lo → …/…/devices/virtual/net/lo
[2025-09-18 07:06:30] + xenstore-read target
[2025-09-18 07:06:30] + target=1
[2025-09-18 07:06:30] + device_model=device-model/1
[2025-09-18 07:06:30] + mkdir /tmp/qmp
[2025-09-18 07:06:30] + kernel=
[2025-09-18 07:06:30] + grep -q ^-append
[2025-09-18 07:06:30] + ‘[’ -b /dev/xvdd ]
[2025-09-18 07:06:30] + mkdir /tmp/boot
[2025-09-18 07:06:30] + mount /dev/xvdd /tmp/boot -o ro
[2025-09-18 07:06:30] EXT4-fs (xvdd): mounting ext3 file system using the ext4 subsystem
[2025-09-18 07:06:30] EXT4-fs (xvdd): mounted filesystem with ordered data mode. Opts: (null)
[2025-09-18 07:06:30] + ‘[’ -f /tmp/boot/vmlinuz ]
[2025-09-18 07:06:30] + kernel=‘-kernel
[2025-09-18 07:06:30] /tmp/boot/vmlinuz’
[2025-09-18 07:06:30] + ‘[’ -f /tmp/boot/initramfs ]
[2025-09-18 07:06:30] -initrd
[2025-09-18 07:06:30] /tmp/boot/initramfs’
[2025-09-18 07:06:30] + mkfifo /tmp/qmp/qemu.in /tmp/qmp/qemu.out
[2025-09-18 07:06:30] + set +x
[2025-09-18 07:06:30] Clearing kmsg buffer…
[2025-09-18 07:06:30] + sed ‘s/$STUBDOM_RESTORE_INCOMING_ARG/fd:3/’
[2025-09-18 07:06:30] + xenstore-read device/console/2
[2025-09-18 07:06:30] + xenstore-read device/console/1
[2025-09-18 07:06:30] + IFS=’
[2025-09-18 07:06:30] ’
[2025-09-18 07:06:30] + set -f
[2025-09-18 07:06:30] + set +f
[2025-09-18 07:06:30] + unset IFS
[2025-09-18 07:06:30] + qemu_pid=102
[2025-09-18 07:06:30] + ‘[’ ‘!’ -e /tmp/qemu.qmp ]
[2025-09-18 07:06:30] + sleep 0.1
[2025-09-18 07:06:30] + qemu -sandbox ‘on,obsolete=deny,elevateprivileges=deny,spawn=deny,resourcecontrol=deny’ -chardev ‘pipe,path=/tmp/qmp/qemu,id=m’ -mon ‘chardev=m,mode=control’ -chardev ‘socket,server,nowait,path=/tmp/qemu.qmp,id=m2’ -mon ‘chardev=m2,mode=control’ -xen-domid 1 -no-shutdown -nodefaults -no-user-config -name sys-net -display none -append ‘root=/dev/mapper/dmroot ro nomodeset console=hvc0 rd_NO_PLYMOUTH rd.plymouth.enable=0 plymouth.enable=0 clocksource=tsc xen_scrub_pages=0 apparmor=1 security=apparmor’ -device lsi53c895a -device ‘VGA,vgamem_mb=16’ -boot ‘order=dc’ -device ‘usb-ehci,id=ehci’ -device ‘usb-tablet,bus=ehci.0’ -smp ‘3,maxcpus=3’ -net none -display ‘qubes-gui,domid=0,log-level=0’ -machine ‘xenfv,suppress-vmdesc=on’ -m 409 -drive ‘file=/dev/xvda,if=ide,index=0,media=disk,format=host_device,cache=writeback’ -drive ‘file=/dev/xvdb,if=ide,index=1,media=disk,format=host_device,cache=writeback’ -drive ‘file=/dev/xvdc,if=ide,index=2,media=disk,format=host_device,cache=writeback’ -drive ‘file=/dev/xvdd,id=scsi0-hd3,format=host_device,if=none,readonly=on,cache=writeback’ -device ‘scsi-hd,drive=scsi0-hd3,scsi-id=3’ -kernel /tmp/boot/vmlinuz -initrd /tmp/boot/initramfs
[2025-09-18 07:06:30] qemu: -chardev socket,server,nowait,path=/tmp/qemu.qmp,id=m2: warning: short-form boolean option ‘server’ deprecated
[2025-09-18 07:06:30] Please use server=on instead
[2025-09-18 07:06:30] qemu: -chardev socket,server,nowait,path=/tmp/qemu.qmp,id=m2: warning: short-form boolean option ‘nowait’ deprecated
[2025-09-18 07:06:30] Please use wait=off instead
[2025-09-18 07:06:30] + tee /proc/self/fd/2
[2025-09-18 07:06:30] + echo ‘{“execute”: “qmp_capabilities”}’
[2025-09-18 07:06:30] {“execute”: “qmp_capabilities”}
[2025-09-18 07:06:31] random: qemu: uninitialized urandom read (16 bytes read)
[2025-09-18 07:06:31] {“QMP”: {“version”: {“qemu”: {“micro”: 2, “minor”: 1, “major”: 8}, “package”: “”}, “capabilities”: [“oob”]}}
[2025-09-18 07:06:31] + ‘[’ ‘!’ -e /tmp/qemu.qmp ]
[2025-09-18 07:06:31] + ‘[’ -e /proc/self/fd/4 ]
[2025-09-18 07:06:31] + ‘[’ -e /proc/self/fd/3 ]
[2025-09-18 07:06:31] + true
[2025-09-18 07:06:31] + printf ‘==== Press enter for shell ====\n’
[2025-09-18 07:06:31] ==== Press enter for shell ====
[2025-09-18 07:06:31] + read
[2025-09-18 07:06:31] + vchan-socket-proxy ‘–mode=server’ ‘–reconnect-marker=1’ --verbose 0 device-model/1/qmp-vchan /tmp/qemu.qmp
[2025-09-18 07:06:31] qubes_gui/init: 574
[2025-09-18 07:06:31] qubes_gui/init: 583
[2025-09-18 07:06:31] qubes_gui/init: 585
[2025-09-18 07:06:31] qubes_gui/init[612]: version sent, waiting for xorg conf
[2025-09-18 07:06:31] {“return”: {}}
[2025-09-18 07:06:31] from-unix: {“QMP”: {“version”: {“qemu”: {“micro”: 2, “minor”: 1, “major”: 8}, “package”: “”}, “capabilities”: [“oob”]}}
[2025-09-18 07:06:31] wrote 110 bytes to vchan
[2025-09-18 07:06:31] from-vchan:
[2025-09-18 07:06:31] from-vchan: {“execute”:“qmp_capabilities”,“id”:2020372737}
[2025-09-18 07:06:31] from-unix: {“return”: {}, “id”: 2020372737}
[2025-09-18 07:06:31] wrote 34 bytes to vchan
[2025-09-18 07:06:31] from-vchan: {“execute”:“device_add”,“id”:2020372736,“arguments”:{“driver”:“xen-pci-passthrough”,“id”:“pci-pt-00_19.0”,“hostaddr”:“0000:00:19.0”}}
[2025-09-18 07:06:31] [00:06.0] xen_pt_realize: Assigning real physical device 00:19.0 to devfn 0x30
[2025-09-18 07:06:31] [00:06.0] xen_pt_register_regions: IO region 0 registered (size=0x00020000 base_addr=0xdf1e0000 type: 0x0)
[2025-09-18 07:06:31] [00:06.0] xen_pt_register_regions: IO region 1 registered (size=0x00001000 base_addr=0xdf1cb000 type: 0x0)
[2025-09-18 07:06:31] [00:06.0] xen_pt_register_regions: IO region 2 registered (size=0x00000020 base_addr=0x0000dfa0 type: 0x1)
[2025-09-18 07:06:31] [00:06.0] xen_pt_config_reg_init: Offset 0x000e mismatch! Emulated=0x0080, host=0x0000, syncing to 0x0000.
[2025-09-18 07:06:31] [00:06.0] xen_pt_config_reg_init: Offset 0x0010 mismatch! Emulated=0x0000, host=0xdf1e0000, syncing to 0xdf1e0000.
[2025-09-18 07:06:31] [00:06.0] xen_pt_config_reg_init: Offset 0x0014 mismatch! Emulated=0x0000, host=0xdf1cb000, syncing to 0xdf1cb000.
[2025-09-18 07:06:31] [00:06.0] xen_pt_config_reg_init: Offset 0x0018 mismatch! Emulated=0x0000, host=0xdfa1, syncing to 0xdfa1.
[2025-09-18 07:06:31] [00:06.0] xen_pt_config_reg_init: Offset 0x00ca mismatch! Emulated=0x0000, host=0x0022, syncing to 0x0022.
[2025-09-18 07:06:31] [00:06.0] xen_pt_pm_ctrl_reg_init_off: PCI power management control passthrough is off
[2025-09-18 07:06:31] [00:06.0] xen_pt_config_reg_init: Offset 0x00cc mismatch! Emulated=0x0008, host=0x2000, syncing to 0x2008.
[2025-09-18 07:06:31] [00:06.0] xen_pt_config_reg_init: Offset 0x00d2 mismatch! Emulated=0x0000, host=0x0080, syncing to 0x0080.
[2025-09-18 07:06:31] [00:06.0] xen_pt_pci_intx: intx=1
[2025-09-18 07:06:31] [00:06.0] xen_pt_realize: Real physical device 00:19.0 registered successfully
[2025-09-18 07:06:31] from-unix: {“return”: {}, “id”: 2020372736}
[2025-09-18 07:06:31] from-vchan: {“execute”:“query-pci”,“id”:2020372738}
[2025-09-18 07:06:31] from-unix: {“return”: [{“bus”: 0, “devices”: [{“irq_pin”: 0, “bus”: 0, “qdev_id”: “”, “slot”: 0, “class_info”: {“class”: 1536, “desc”: “Host bridge”}, “id”: {“device”: 4663, “subsystem-vendor”: 6900, “vendor”: 32902, “subsystem”: 4352}, “function”: 0, “regions”: }, {“irq_pin”: 0, “bus”: 0, “qdev_id”: “”, “slot”: 1, “class_info”: {“class”: 1537, “desc”: “ISA bridge”}, “id”: {“device”: 28672, “subsystem-vendor”: 6900, “vendor”: 32902, “subsystem”: 4352}, “function”: 0, “regions”: }, {“irq_pin”: 0, “bus”: 0, “qdev_id”: “”, “slot”: 1, “class_info”: {“class”: 257, “desc”: “IDE controller”}, “id”: {“device”: 28688, “subsystem-vendor”: 6900, “vendor”: 32902, “subsystem”: 4352}, “function”: 1, “regions”: [{“bar”: 4, “size”: 16, “address”: -1, “type”: “io”}]}, {“irq_pin”: 1, “bus”: 0, “qdev_id”: “”, “irq”: 0, “slot”: 1, “class_info”: {“class”: 1664, “desc”: “Bridge”}, “id”: {“device”: 28947, “subsystem-vendor”: 6900, “vendor”: 32902, “subsystem”: 4352}, “function”: 3, “regions”: }, {“irq_pin”: 1, “bus”: 0, “qdev_id”: “”, “irq”: 0, “slot”: 2, “class_info”: {“class”: 65408}, “id”: {“device”: 1, “subsystem-vendor”: 22611, “vendor”: 22611, “subsystem”: 1}, “function”: 0, “regions”: [{“bar”: 0, “size”: 256, “address”: -1, “type”: “io”}, {“prefetch”: true, “mem_type_64”: false, “bar”: 1, “size”: 16777216, “address”: -1, “type”: “memory”}]}, {“irq_pin”: 1, “bus”: 0, “qdev_id”: “”, “irq”: 0, “slot”: 3, “class_info”: {“class”: 256, “desc”: “SCSI controller”}, “id”: {“device”: 18, “subsystem-vendor”: 0, “vendor”: 4096, “subsystem”: 4096}, “function”: 0, “regions”: [{“bar”: 0, “size”: 256, “address”: -1, “type”: “io”}, {“prefetch”: false, “mem_type_64”: false, “bar”: 1, “size”: 1024, “address”: -1, “type”: “memory”}, {“prefetch”: false, “mem_type_64”: false, “bar”: 2, “size”: 8192, “address”: -1, “type”: “memory”}]}, {“irq_pin”: 0, “bus”: 0, “qdev_id”: “”, “slot”: 4, “class_info”: {“class”: 768, “desc”: “VGA controller”}, “id”: {“device”: 4369, “subsystem-vendor”: 6900, “vendor”: 4660, “subsystem”: 4352}, “function”: 0, “regions”: [{“prefetch”: true, “mem_type_64”: false, “bar”: 0, “size”: 16777216, “address”: -1, “type”: “memory”}, {“prefetch”: false, “mem_type_64”: false, “bar”: 2, “size”: 4096, “address”: -1, “type”: “memory”}, {“prefetch”: false, “mem_type_64”: false, “bar”: 6, “size”: 65536, “address”: -1, “type”: “memory”}]}, {“irq_pin”: 4, “bus”: 0, “qdev_id”: “ehci”, “irq”: 0, “slot”: 5, “class_info”: {“class”: 3075, “desc”: “USB controller”}, “id”: {“device”: 9421, “subsystem-vendor”: 6900, “vendor”: 32902, “subsystem”: 4352}, “function”: 0, “regions”: [{“prefetch”: false, “mem_type_64”: false, “bar”: 0, “size”: 4096, “address”: -1, “type”: “memory”}]}, {“irq_pin”: 1, “bus”: 0, “qdev_id”: “pci-pt-00_19.0”, “irq”: 0, “slot”: 6, “class_info”: {“class”: 0}, “id”: {“device”: 5378, “subsystem-vendor”: 0, “vendor”: 32902, “subsystem”: 0}, “function”: 0, “regions”: [{“prefetch”: false, “mem_type_64”: false, “bar”: 0, “size”: 131072, “address”: -1, “type”: “memory”}, {“prefetch”: false, “mem_type_64”: false, “bar”: 1, “size”: 4096, “address”: -1, “type”: “memory”}, {“bar”: 2, “size”: 32, “address”: -1, “type”: “io”}]}]}], “id”: 2020372738}
[2025-09-18 07:06:31] wrote 2048 bytes to vchan
[2025-09-18 07:06:31] wrote 1127 bytes to vchan
[2025-09-18 07:06:31] vchan client disconnected
[2025-09-18 07:06:31] from-vchan: {“execute”:“device_add”,“id”:2020372736,“arguments”:{“driver”:“xen-pci-passthrough”,“id”:“pci-pt-02_00.0”,“hostaddr”:“0000:02:00.0”}}
[2025-09-18 07:06:31] [00:07.0] xen_pt_realize: Assigning real physical device 02:00.0 to devfn 0x38
[2025-09-18 07:06:31] [00:07.0] xen_pt_register_regions: IO region 0 registered (size=0x00002000 base_addr=0xdf200000 type: 0x4)
[2025-09-18 07:06:31] [00:07.0] xen_pt_config_reg_init: Offset 0x000e mismatch! Emulated=0x0080, host=0x0000, syncing to 0x0000.
[2025-09-18 07:06:31] [00:07.0] xen_pt_config_reg_init: Offset 0x0010 mismatch! Emulated=0x0000, host=0xdf200004, syncing to 0xdf200004.
[2025-09-18 07:06:31] [00:07.0] xen_pt_config_reg_init: Offset 0x00ca mismatch! Emulated=0x0000, host=0x0023, syncing to 0x0023.
[2025-09-18 07:06:31] [00:07.0] xen_pt_pm_ctrl_reg_init_off: PCI power management control passthrough is off
[2025-09-18 07:06:31] [00:07.0] xen_pt_config_reg_init: Offset 0x00d2 mismatch! Emulated=0x0000, host=0x0080, syncing to 0x0080.
[2025-09-18 07:06:31] [00:07.0] xen_pt_config_reg_init: Offset 0x00e4 mismatch! Emulated=0x0000, host=0x10008ec0, syncing to 0x8ec0.
[2025-09-18 07:06:31] [00:07.0] xen_pt_config_reg_init: Offset 0x00ea mismatch! Emulated=0x0000, host=0x0010, syncing to 0x0010.
[2025-09-18 07:06:31] [00:07.0] xen_pt_config_reg_init: Offset 0x00f2 mismatch! Emulated=0x0000, host=0x1011, syncing to 0x1011.
[2025-09-18 07:06:31] [00:07.0] xen_pt_pci_intx: intx=1
[2025-09-18 07:06:31] [00:07.0] xen_pt_realize: Real physical device 02:00.0 registered successfully
[2025-09-18 07:06:31] from-unix: {“return”: [{“bus”: 0, “devices”: [{“irq_pin”: 0, “bus”: 0, “qdev_id”: “”, “slot”: 0, “class_info”: {“class”: 1536, “desc”: “Host bridge”}, “id”: {“device”: 4663, “subsystem-vendor”: 6900, “vendor”: 32902, “subsystem”: 4352}, “function”: 0, “regions”: }, {“irq_pin”: 0, “bus”: 0, “qdev_id”: “”, “slot”: 1, “class_info”: {“class”: 1537, “desc”: “ISA bridge”}, “id”: {“device”: 28672, “subsystem-vendor”: 6900, “vendor”: 32902, “subsystem”: 4352}, “function”: 0, “regions”: }, {“irq_pin”: 0, “bus”: 0, “qdev_id”: “”, “slot”: 1, “class_info”: {“class”: 257, “desc”: “IDE controller”}, “id”: {“device”: 28688, “subsystem-vendor”: 6900, “vendor”: 32902, “subsystem”: 4352}, “function”: 1, “regions”: [{“bar”: 4, “size”: 16, “address”: -1, “type”: “io”}]}, {“irq_pin”: 1, “bus”: 0, “qdev_id”: “”, “irq”: 0, “slot”: 1, “class_info”: {“class”: 1664, “desc”: “Bridge”}, “id”: {“device”: 28947, “subsystem-vendor”: 6900, “vendor”: 32902, “subsystem”: 4352}, “function”: 3, “regions”: }, {“irq_pin”: 1, “bus”: 0, “qdev_id”: “”, “irq”: 0, “slot”: 2, “class_info”: {“class”: 65408}, “id”: {“device”: 1, “subsystem-vendor”: 22611, “vendor”: 22611, “subsystem”: 1}, “function”: 0, “regions”: [{“bar”: 0, “size”: 256, “address”: -1, “type”: “io”}, {“prefetch”: true, “mem_type_64”: false, “bar”: 1, “size”: 16777216, “address”: -1, “type”: “memory”}]}, {“irq_pin”: 1, “bus”: 0, “qdev_id”: “”, “irq”: 0, “slot”: 3, “class_info”: {“class”: 256, “desc”: “SCSI controller”}, “id”: {“device”: 18, “subsystem-vendor”: 0, “vendor”: 4096, “subsystem”: 4096}, “function”: 0, “regions”: [{“bar”: 0, “size”: 256, “address”: -1, “type”: “io”}, {“prefetch”: false, “mem_type_64”: false, “bar”: 1, “size”: 1024, “address”: -1, “type”: “memory”}, {“prefetch”: false, “mem_type_64”: false, “bar”: 2, “size”: 8192, “address”: -1, “type”: “memory”}]}, {“irq_pin”: 0, “bus”: 0, “qdev_id”: “”, “slot”: 4, “class_info”: {“class”: 768, “desc”: “VGA controller”}, “id”: {“device”: 4369, “subsystem-vendor”: 6900, “vendor”: 4660, “subsystem”: 4352}, “function”: 0, “regions”: [{“prefetch”: true, “mem_type_64”: false, “bar”: 0, “size”: 16777216, “address”: -1, “type”: “memory”}, {“prefetch”: false, “mem_type_64”: false, “bar”: 2, “size”: 4096, “address”: -1, “type”: “memory”}, {“prefetch”: false, “mem_type_64”: false, “bar”: 6, “size”: 65536, “address”: -1, “type”: “memory”}]}, {“irq_pin”: 4, “bus”: 0, “qdev_id”: “ehci”, “irq”: 0, “slot”: 5, “class_info”: {“class”: 3075, “desc”: “USB controller”}, “id”: {“device”: 9421, “subsystem-vendor”: 6900, “vendor”: 32902, “subsystem”: 4352}, “function”: 0, “regions”: [{“prefetch”: false, “mem_type_64”: false, “bar”: 0, “size”: 4096, “address”: -1, “type”: “memory”}]}, {“irq_pin”: 1, “bus”: 0, “qdev_id”: “pci-pt-00_19.0”, “irq”: 0, “slot”: 6, “class_info”: {“class”: 0}, “id”: {“device”: 5378, “subsystem-vendor”: 0, “vendor”: 32902, “subsystem”: 0}, “function”: 0, “regions”: [{“prefetch”: false, “mem_type_64”: false, “bar”: 0, “size”: 131072, “address”: -1, “type”: “memory”}, {“prefetch”: false, “mem_type_64”: false, “bar”: 1, “size”: 4096, “address”: -1, “type”: “memory”}, {“bar”: 2, “size”: 32, “address”: -1, “type”: “io”}]}, {“irq_pin”: 1, “bus”: 0, “qdev_id”: “pci-pt-02_00.0”, “irq”: 0, “slot”: 7, “class_info”: {“class”: 0}, “id”: {“device”: 133, “subsystem-vendor”: 0, “vendor”: 32902, “subsystem”: 0}, “function”: 0, “regions”: [{“prefetch”: false, “mem_type_64”: true, “bar”: 0, “size”: 8192, “address”: -1, “type”: “memory”}]}]}], “id”: 2020372738}
[2025-09-18 07:06:31] wrote 1437 bytes to vchan
[2025-09-18 07:06:33] {“timestamp”: {“seconds”: 1758179193, “microseconds”: 566656}, “event”: “DEVICE_DELETED”, “data”: {“path”: “/machine/peripheral-anon/device[3]”}}
[2025-09-18 07:06:33] {“timestamp”: {“seconds”: 1758179193, “microseconds”: 566775}, “event”: “DEVICE_DELETED”, “data”: {“path”: “/machine/peripheral-anon/device[0]”}}
[2025-09-18 07:06:38] [00:06.0] xen_pt_msgctrl_reg_write: setup MSI (register: 81).
[2025-09-18 07:06:38] [00:06.0] xen_pt_msi_setup: MSI mapped with pirq 55.
[2025-09-18 07:06:38] [00:06.0] msi_msix_update: Updating MSI with pirq 55 gvec 0x22 gflags 0x0 (entry: 0x0)
[2025-09-18 07:06:38] [00:07.0] Write-back to unknown field 0x41 (partially) inhibited (0x00)
[2025-09-18 07:06:38] [00:07.0] If the device doesn’t work, try enabling permissive mode
[2025-09-18 07:06:38] [00:07.0] (unsafe) and if it helps report the problem to xen-devel
[2025-09-18 07:06:38] [00:07.0] xen_pt_msgctrl_reg_write: setup MSI (register: 81).
[2025-09-18 07:06:38] [00:07.0] xen_pt_msi_setup: MSI mapped with pirq 54.
[2025-09-18 07:06:38] [00:07.0] msi_msix_update: Updating MSI with pirq 54 gvec 0x23 gflags 0x2 (entry: 0x0)
[2025-09-18 07:06:40] [00:06.0] msi_msix_update: Updating MSI with pirq 55 gvec 0x22 gflags 0x0 (entry: 0x0)
[2025-09-18 07:06:40] [00:06.0] xen_pt_msi_set_enable: disabling MSI.
[2025-09-18 07:06:40] [00:06.0] msi_msix_disable: Unbind MSI with pirq 55, gvec 0x0
[2025-09-18 07:06:40] [00:06.0] msi_msix_disable: Unmap MSI pirq 55
[2025-09-18 07:06:40] [00:06.0] xen_pt_msgctrl_reg_write: setup MSI (register: 81).
[2025-09-18 07:06:40] [00:06.0] xen_pt_msi_setup: MSI mapped with pirq 55.
[2025-09-18 07:06:45] random: crng init done
Perhaps related:
how did you solve?
These messages are not useful. Can you upload the whole dmesg log?
It was resolved unintentionally. It seems that detaching from sys-net and reconnecting is necessary for it to be recognized. This ritual appears to be required, as it doesn’t recognize it no matter how long I wait the first time. Why has it become such a hassle?
how did you solve?
Not solved. The issue remains.
