Hello, what about using Mac, to installe properly QUBES OS 4. and especially this version
I tested it , so if somebody is interested ; please contact me
imboxm
ps: to languages , I prefere French or Polish
Do you have a solution/suggestions/hint wrt. getting the WiFi (“BCM4350 802.11ac”) working on a MacBook Pro - A1708?
My sys-net keeps getting:
brcmfmac: brcmf_chip_recognition: SB chip is not supported
brcmfmac: brcmf_pcie_probe: failed 14e4:43a3
so I need to add an USB network device (Wireless or ethernet) to get it online . :-/
Running a Fedora or similar from a USB-stick has no issue … ![]()
No, sorry
i use another Mac …( i don’t need Wi Fi in this case); until this verssion 4.2 using qubes for each day is possible …( for me)
YES ![]()
My Qubes OS 4.2 now have working WiFi on the MacBook Pro - A1708! ![]()
Following the advice in No network connection - #26 by DVM I got WiFi working by:
Stop
sys-net -
Remove the Network Card from
sys-netby runningqvm-pci detach sys-net dom0:02_00.0in
dom0 -
Add the Network Card back, with
permissiveandno-strict-resetby running:qvm-pci attach --persistent --option permissive=True --option no-strict-reset=True sys-net dom0:02_00.0in
dom0 -
Start
sys-net
