I try to install Qubes on LCDFans Thinkpad T700 laptop (i7 11th gen). “Normal” linux and “normal” windows work with no issues, but Xen kernel goes to s3 sleep every 30 seconds. I tried disabling the ACPI interrupt which seems to have rapidly increasing counter, but it did not help either. Anyone seen something like that?
No, sorry, I haven’t seen this behaviour…
Just dropping by to suggest (although I guess you didn’t play with the system settings) checking the “critical battery level” treshold.
It happens immediately in the installer and I found no workarounds.
more info here:
may be malfunctioning lid sensor. but this does not explain why it works properly with Windows!
