WebAuthn & Passkey only works with Yubico products
I registered a yubikey 5 nano and a nitrokey 3 mini for webauthn (as 2fa) and passkey, the preferences said i registered them successfully.
with the nitrokey i get internal server errors at login, but the yubikey works.
is somebody else experience similar issues? should i report at Search results for 'webauthn #bug' - Discourse Meta or you want to take a peek in this forums logs first??
I tried to use the instructions to install my thetis fido2 key last week on a since deleted install, but noted that despite everything seemingly being accepted by dom0 to restrict access some of my VM’s when I input the instructions from the instructions sheet, I could still access the qubes for which I had attempted to restrict access without needing to use the key.
That said, given that FIDO2 was explicitly mentioned within the instructions, I assumed that I had somehow messed it up rather than the system itself being at fault. It was one of the reasons for my change in deployment strategy (I have now set up a test install and a production install, so that I can use the test environment to experiment with features and ensure they work properly before going live with them on the production install).
i posted this as a forum issue, fido2 works fine with other websites (like github or so) on yubikey and nitrokey.
I don’t think we have access to that granular logging. So probably the best is to report it on Discourse Meta. Sorry about that.
You could also post the issue to the NitroKey forum, since the issue is only with your Nitrokey.
thanks, i got myself a local docker env and could reproduce. since nitrokey works fine on github, gitea, and others as webauthn (and passkey…) i suspect dicourses implementation might be the cause and will follow deeplows recommendation.
