As far as I am aware, there are two ways to use wayland in qubes. The first is to install KDE, which lets you choose between a wayland session and an xorg session at the login screen. Second would be this: GitHub - DemiMarie/qubes-wayland
Just to clarify, that would switch dom0 over from xorg to wayland, yes?
And as for the vms themselves, if I were to install it inside of a hvm, then that would switch it from xorg to wayland also?
Are there any side effects such as the copy-paste breaking? (for the second option) How about the GUI vm? Is it possible to use sys-gui with wayland if dom0 is running on wayland?
I have a custom Fedora 43 Workstation (GNOME and Wayland) with KVM type-1 hypervisor with the same coloured window decoration used in Qubes, but does not implement the high-end cyber-security features.
I first tried to ask for help to setup Qubes on my laptop (AMD Ryzen AI 9 HX370 with Radeon 890M) but never got a reply, so I decided to first implement my own Qubes with Xen and X11. The experience was very disappointing, what motivated me to switch to KVM and Wayland.
Current status: the work is focused on Workstation environment and high-performance work (no cyber-security as done in Qubes), using Wayland. It has a network VM (it uses internal bridges for direct and VPN), personal VM (general browsing), office VM (with LibreOffice and related tools), development VM (with VSCode and all development related tools) and download VM (connected to VPN internal bridge). I also has a basic GNOME extension for VM workflow, but configuration is still by manually editing config files.
What is planned: prepare an ISO image for easy installation, Tor Gateway VM, improvements to the GNOME extension and possibly add more extensions for network monitoring. More improvements will come along as this is still a one-man-work.
