Waydroid info:
Waydroid uses Linux namespaces (user, pid, uts, net, mount, ipc) to run a full Android system in a container and provide Android applications on any GNU/Linux-based platform. The Android inside the container has direct access to needed hardwares. The Android runtime environment ships with a minimal customized Android system image based on the LineageOS. The used image is currently based on Android 10.
The prerequisites are:
Waydroid requires the following in order to work properly on your PC:
python3
lxc
curl
Wayland session manager IMPORTANT!!
Wayland session manager comes with distros running GNOME by default (Ubuntu, Pop!_OS, Fedora, etc), so no need to install separately.Other desktop environments/window managers, might not support Wayland out of the box. (KDE Plasma does after 5.21)
I installed in both a standalone debian 11 and focal VM. I installed task-gnome-desktop to make sure whatever the wayland session manager thing is that its installed plus all the other prerequisites. I get up to the last step:
sudo waydroid init
Error output (both focal & debian 11):
[04:09:03] Failed to load binder driver
[04:09:03] modprobe: FATAL: Module binder_linux not found in directory /lib/modules/5.4.156-1.fc25.qubes.x86_64
[04:09:03] ERROR: Binder node “binder” for waydroid not found
No idea what this means (my nickname is not Dum0 for nothing) but it looks Qubes specific.
Any thoughts?
