I thought that I had successfully installed Qubes on an Asus laptop. After the installation, I rebooted and removed the installation media. The Select Operating System screen displayed, so I selected Qubes, with Xen hypervisor. Then I got an error message: Warning: USB in dom0 is not restricted. Consider rd.qubes.hide_all_usb or usbcore.authorized_default=0.
When I Googled the error message, I learned that it usually indicates a USB keyboard or mouse that isn’t recognized. But I don’t have a USB keyboard or mouse. In fact, I have no peripheral devices at all.
In dom0, look in /etc/default/grub and make sure you have rd.qubes.hide_all_usb in GRUB_CMDLINE_LINUX. If you don’t have it, add it before rhgb and quiet like this:
It’s not about USB devices. It’s about USB controllers. You didn’t choose to install sys-usb during install. I would reinstall Qubes and choose the option, rather than to manually create sys-usb afterward.
I wasn’t prompted to install sys-usb during install. In fact, I wasn’t prompted to create any Qubes at all. I will reflash the USB and then re-install the OS.
Just to be sure, did you actually Start Qubes after the installation? After you reboot out of the installation media, on your first boot you should see a screen like in the installer that days something like “System - Qubes OS.” THAT’S where you configure what qubes you create, including sys-usb. I ask because, on that first boot you’ll always see that error before it gets to that screen.
