Wanting a laptop for Qubes with longevity for my usecase, would appreciate suggestions
Could not find an answer to this on the forums.
My usecase is mainly just Whonix, although this may branch out later.
Upon browsing the forums some, it seems that a laptop is a better option for what I’m looking for than a desktop.
I am looking for the best laptop that will last have the best support for the longest time, in other words. Or, if this is too pricey, I want a budget option.
I have been looking over the certified hardware and community hardware lists.
I have noticed that some more expensive ones, like the NovaCustom V56 Series, don’t have the functionality for options like coreboot+Heads. I am a newb at this moment and I’m not sure how important things like these really are, but I because I want value, I was wanting to get a laptop with all of these kinds of privacy and security preserving functions.
I would appreciate any suggestions you all would have for me! It’s hard to balance privacy, security, budget, and longevity when first coming into this.
Thanks for your time.
I started using Qubes OS with a cheap laptop that I previously used for almost 10 years, and all I had to do was add more RAM. And I’m currently using it on a 5-year-old second-hand mid-range machine, with more RAM again, and it’s smooth. Right now, I could buy a used laptop, upgrade its RAM and the total expense would be less than if I’d bought a brand new laptop a few years ago. Concerning the 10-year-old laptop, I think that the experience wasn’t smooth only because of the insufficient RAM.
From my personal experience I can tell you: take something cheap and reliable like old lenovo laptops e.c. t420/t430 or x220/x230 series. Some of them are available with skulls preinstalled on ebay, so you can install heads yourself. Add some ram for 20$. Learn and after you can buy something more expensive:-)
You will need a laptop with at least 8 GB of memory - 16 GB or more is better. The laptop will need to have both VT-x and VT-d enabled, or AMD equivalent, or Qubes OS simply won’t work. Some cheap processors don’t have these features.
A lot of people buy a Thinkpad off eBay or similar. An OK example is £100, a nice example is £200 - your local marketplace may vary. A lot of the cheap laptops look OK, but further investigation of the listings show problems - cracked cases, damaged keyboards, no charger.
Thanks all for the replies. You all make good points, especially you @absent - I’m still in the phase of not really knowing how much I’ll end up using Whonix at the moment. It would be a shame to under budget and then kick myself for it later.
I think I was mainly surprised that a certified laptop would have a feature not supported. I don’t know how to take that other than the feature not being important?
for most in your situation the answer is t480 (8th gen Intel quad core not dual core version) with 16gb ram. Even if you end up having a more complicated setup later, the Thinkpad is nice because mostly it just works and keeps working
Sorry to possibly ruin it for you (but I might save you some dime, on the other hand) - if that’s the case, you most probably mainly don’t need Qubes at all.
