dkzkz
1
I’m trying to make vscode use qubes-split-gpg following this documentation Split GPG — Qubes OS Documentation and this post Some help with split-gpg2 - #14 by JustAnotherQubesUser
So i tried to do in VScode vm
export QUBES_GPG_DOMAIN=gpg-vscode
git config --global gpg.program qubes-gpg-client-wrapper
In dom0 i added in a policy :
qubes.Gpg * @anyvm gpg-codium ask
qubes.GpgKeyImport * @anyvm gpg-codium ask
qubes.Gpg2 + * @default allow target=gpg-codium
But when i try push a signed commit with vscode i get this error
> git -c user.useConfigOnly=true commit --quiet --allow-empty-message --file - -S
error: gpg failed to sign the data:
[GNUPG:] KEY_CONSIDERED (key number)
[GNUPG:] BEGIN_SIGNING H10
[GNUPG:] PINENTRY_LAUNCHED 820 curses 1.3.1 - - :0 - 1000/1000 -
gpg: signing failed: Inappropriate ioctl for device
[GNUPG:] FAILURE sign (key number)
fatal: failed to write commit object
Key number = the private key inside gpg-vm
split-gpg2-dom0 is installed in dom0 and the split-gpg2 package is installed in the template and the service is enabled for vscode vm
what i’m missing ?
Are you trying to use Split GPG 1 ? Split GPG 2 ? Or both ?
Is gpg -K working?
dkzkz
3
I’m confused with the documenttion so i tried to use all of them i don’t know if we should keep th old qubes-split-gpg
Yes in the gpg-code vm
You should stick to only one of them first.
dkzkz
5
Do you know how to execute split-gpg2 with the cli command ? i can’t find the exec with whereis command
I tried to do git config --global gpg.program /usr/share/split-gpg2/split-gpg2-client
But it does nothing
You just use gpg, split-gpg2-client is a service.
dkzkz
7
I’ve made some progress i do not have the error now but instead i get this :
gpg: skipped "dkzkz <(mail)>": No secret key
[GNUPG:] INV_SGNR 9 dkzkz (mail)
[GNUPG:] FAILURE sign 17
gpg: signing failed: No secret key
The private key is in the gpg-code vm i can see th key with gpg --list-secret-keys commands
Ok, can I assume you followed the Split GPG-2 documentation?
gpg-codium is your server qube and gpg-vscode is your client qube?
Are the instructions in Check that Split GPG-2 works working?
dkzkz
9
Yes doing gpg -K in gpg-codium works
[user@gpg-codium ~]$ gpg -K
[keyboxd]
sec rsa4096 (date of the key) [SC] [expires: ]
(key number is here)
uid [ unknown] dkzkz <(mail)>
ssb rsa4096 (date of the key) [E] [expires: ]
I think VSCode doesn’t work correctly with qubes-split features i spent too much time trying to make it work i give up
I also tried to change the template for gpg-code , i tried the fedora template and debian template and none of them seems to work unfortunately
You haven’t answered my questions so I can’t help.
dkzkz
11
When i replied “Yes” in my previous answer it mean yes for everything you asked me but i should have been more clear sorry for that
But i still don’t think vscode can work with split-gpg-2 i need a last thing before giving up
gpg working in the server qube doesn’t matter. Is it working in a shell session in the client qube?
