kzlz
1
The VPN kill switch does not work when I set net qube to sys-whonix.
If anyone has successfully configured the kill switch, could you please share how you did it?
I am using OpenVPN and ProtonVPN.
I want the setup to be: anon-whonix → VPN gateway → sys-whonix → internet, but I’m struggling with it
solene
2
add a qube providing network between vpn gateway and sys-whonix.
sys-whonix does not support firewall rules added by qubes os, so you need that extra “sys-firewall-vpn” qube to hold the rules for “VPN gateway”.
kzlz
3
I understand. This is how the wiring should be.
anon-whonix→VPN-Gateway→sys-firewall-vpn→sys-whonix→sys-firewall→sys-net
Thank you. I will try again.
