Virt_mode PVH require kernel to be set
Yesterday computer shut down normally, today started normally. Only sys-net and sys-usb VM are still running. The rest I can not start, there comes the error message:
“virt_mode PVH require kernel to be set”.
I mean I’m glad I can use Qubes, but now being glad if I can use it at all is very detrimental.
In “Qubes Global Settings”, check which kernel is selected for all qubes.
okay, I have checked. Have now selected the other (newer), restarted and lo and behold, everything works again.
Top, thank you
