I restored my old setup on a new, faster laptop, but the shutdown time of my large-storage qubes is really long now. I don’t know if this has anything to do with the restore, to be fair – but on my older laptop, this never happened.
It takes 2-5 minutes to shut down both AppVMs and templates, and even worse, during that time the rest of the OS is basically locked up. Anything more that dragging windows around is impossible. Sometimes the Qubes Manager goes blank during this time as well, especially if I’m on another desktop space.
I have tried rebooting but I wouldn’t know what else to do to solve this. It’s quite annoying since the system becomes mostly unusable during VM shutdown and the Qubes Manager is not only unusable but also shows no “dot” at all (not yellow) so it can be hard to tell what’s going on. My laptop’s hard drive light is flashing and goes out when the shutdown completes, and everything returns to normal.
The expected messaging is normal – I get the message that the qube is attempting to shut down, then it takes several minutes for the next message to appear that it has completed shutting down.
Even if it’s not related to the above linked issue, I would suggest @qube follows the debugging advice on said issue – particularly the first few comments.
Thanks for that. However they discuss quite a number of things in that thread. Can you point me to something specific you think I ought to try?
This first suggestion by Marek to check out the log /var/log/xen/console/guest-VMNAME.log .
My log looks pretty similar to Heinrich’s. If those numbers at the start of the log entries are timestamps, then the system halt entry happened very quickly and some other processes are what are freezing up the system afterwards.
Regarding the testing, I have confirmed that other restored VMs do NOT have this issue: only the large size template and AppVMs based off it. So it’s unlikely specifically to do with the restore, although it may have triggered this issue that does appear to be based on the storage allocated.
Then I guess you are under the same circumstances as the user who reported the above-mentioned issue. So I guess the best course of action is to move some of that storage elsewhere or following the evolution of the reported issue on Github.
