Hello,
How can I verify if ClockVM is working? I’ve configured my ClockVM to use the Kicksecure sdwdate AppVM, as it works out of the box.
Thank you.
Hello,
Thank you.
Set a qube (or even dom0) to the wrong time and watch it get corrected.
I ran the command qvm-clock-sync, which synchronized with the current time. I then adjusted my time using timedatectl set-time <time> to test it. I saw a cronjob in /etc/cron.d/qubes-sync-clock.cron that runs every hour. Since manually running qvm-clock-sync works, it should also function correctly with the cronjob. Thanks!
