Hi everybody
I hope that someone can spread some light on this problem. This problem relates to the installation of veracrypt in a debian 11 template and debian-based qube.
I download the veracrypt .deb folder and place it in the home directory of the template. It installs fine. It appears in the apps etc. So I close the template and then start up my one other app vm based on debian. Veracrypt appears there as it should but it won’t start. No matter what I do I can’t get veracrypt to run in either the template or the app vm. As I said, veracrypt appears in the qubes settings > applications, and its icon is also in the drop down box from the top left from where I can select what apps to launch for each qube.
Just what am I doing wrong? As far as I can see I am following all of the correct steps.
For the record I’ve tried installing it from the recommended .deb folder and the generic tarball installer. Both go through the motions but don’t run at the end of the installation.
