Hi everyone, I think I’ve broken my vault VM and lost all data 300GB
and don’t know what to do now, I was trying to find some solution, but couldn’t find anything. Please help me restore my data.
Scenario of the issue:
- I got “Out of disk space” error (yellow triangle warning saying 5% space left)
- so I started deleting the biggest files from vault, but it didn’t help
- I started deleting backups by using “lvremove qubes_dom0/vm-name-back”. I am sure I haven’t deleted vm-vault-private, because don’t see that in command history, I just once run command “sudo lvremove qubes_dom0/vm” without name, but nothing happened, so I think it’s not the reason. This process helped me to restore some data space.
- I was working a few days without any issue, putting system to hibernate only at night
- I created new vm-test and deleted it, still all fine, system works, only one info was suspicious, under “Qubes Devices” icon I could attach USB device into this old vm-test, but I ignored that thinking it will disappear after system restart
- I was putting system to hibernate at night, all fine after reboot, until today when “bottom panel” has frozen and I couldn’t change workspace, so I was forced to restart system as usual when it happens
- the system was not able to restart itself, there was black screen at the end of restart process, when I clicked first time on-off button nothing happened so I had to click it a few times to reboot
- now I am trying to start vault-vm but I can’t because of “Domain vault has failed to start: volume qubes_dom0/vm-vault-private missing”
- for all this days I was working with “Out of disk space” error (yellow triangle warning saying less than 5% space left), but I didn’t know how to fix it, because it always increases when I delete some backups and files
Now, when I run “sudo lvs” I can’t find “vm-vault-private”, there is only “vm-vault-private-snap” .
- Seems “vm-vault-private” has disappeared, is it possible to restore it somehow?
- does “vm-vault-private-snap” snapshot have good data? or it can be broken data?
- what is best to do now? is it possible to restore whole “vm-vault-private” from “vm-vault-private-snap”? or I have to create new VM and start restoring data from snapshot to this new VM?
- why did it happen? I’ve never had this issue before with missing vm, but I’d like to avoid it in future
- how to fix this “Out of disk space” error eventually?
please help me
thank you in advance!
