V4.3.1 GRUB video definition stuck in 1024x768
Hello humans!
Context:
As soon as v4.3 was available, I’ve done a fresh install with no problem but the resolution of Grub: cannot get it properly set (1024x768!). Plus grub does’nt recognize command like ‘videoinfo’ or ‘vbeinfo’ (say they doesn’t exist).
With every other preceding version, Grub had a proper video definition on my computer.
Actions:
Checking dom0 for Grub setup, I found out that Grub modules for EFI64 aren’t availbale on FS, whereas related packages are said installed. I’ve tryed to force the reinstallation of those packages (+“Grub Install” +regenerate boot images, etc.) without any success.
Run out of idea.
Any suggestions?
Finally, reinstall Qubes was the point, using Kernel 6.x instead of 7.x.
Do you remember the exact kernel versions? Can you share your HCL? qubes-hcl-report
Kernels were 7.0.12 and 7.0.14.
My current HCL :
Qubes release 4.3.1
Brand:		Micro-Star International Co., Ltd.
Model:		Crosshair 18 HX AI A2XWFKG
BIOS:		E1841IMS.10A
Xen:		4.19.5
Kernel:		7.0.14-1
RAM:		85416 Mb
CPU:
Intel(R) Core™ Ultra 7 255HX
Chipset:
Intel Corporation Device [8086:7d2d] (rev 01)
VGA:
Intel Corporation Arrow Lake-S [Intel Graphics] [8086:7d67] (rev 06) (prog-if 00 [VGA controller])
NVIDIA Corporation GB206M [GeForce RTX 5060 Max-Q / Mobile] [10de:2d19] (rev a1) (prog-if 00 [VGA controller])
Intel Corporation Device [8086:7f2f] (rev 10)
Net:
Intel Corporation Arrow Lake-S PCH CNVi WiFi [8086:7f70] (rev 10)
Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
SCSI:
HVM:		Active
I/O MMU:	Active
HAP/SLAT:	Yes
TPM:		Device not found
Remapping:	yes
Certified:	no
Qubes HCL Files are copied to: ‘dom0’
Qubes-HCL-Micro_Star_International_Co___Ltd_-Crosshair_18_HX_AI_A2XWFKG-20260716-171725.yml		- HCL Info
As said, it’s ok now. Thanks for your concern :slight_smile:
