Hi guys,
I know it’s not recommended to connect templatevms to the internet, so is there a safe way to enable the snapstore or flathub on the templatevms while not allowing a internet connection?
Thanks
H
Hi guys,
Thanks
H
See Installing Snap Packages (the documentation is your best friend) – and if you notice they install it in the AppVMs.
Thank you that’s exactly what I was looking for, my apologies I didn’t even think to check the documentation.
