Using Hybrid Graphics to play games with seamless GPU acceleration
Recently got a new motherboard (X670E Tomahawk) that supports Hybrid Graphics, and it works with Qubes OS.
Here is a picture of my games qube running Magic Arena in window mode, with the rendering being done by my 4060 GPU.
The GPU needs to be passed to the qube running the game, it doesn’t allow you to share the GPU with multiple qubes, it only allows you to use the GPU without having a dedicated display connected.
It doesn’t really require any extra configuration, applications using the vulkan driver are automatically moved to the GPU.
It also works with mixing AMD and Nvidia hardware, I’m using an AMD CPU with an Nvidia GPU.
Does it mean, that you passed GPU to the qube as a PCI device and get the rendered output not on external physical video-output connector (like DP or HDMI) but as a usual window visible inside dom0?
Yes, you set up the qube with GPU pass-through, and the GPU output is displayed in native dom0 windows, using the internal graphics.
Forwarding the dGPU to the iGPU seems to work in most games, but not all games work with Qubes OS mouse input and graphics. In one game, I had issues with hold down a mouse button to navigate. The screen size in Qubes OS also seems to cause issues, when using multiple displays and not running window mode.
With nvidia, this can also work for non vulkan if you just use the PRIME rendering (requires to wrap a binary with some environment variables).
It’s new to me, sounds awesome!
About mouse - I recommend to connect additional one via USB and pass it to the qube. Because otherwise there is a know bug in Qubes OS of improperly processing relative/absolute mouse position.
Is there a future timeframe within which this capability becomes (or planned to be become) real for qubesos users?
This sounds very promising, maybe this is the answer to the last great hurdle I have with my Qubes OS install: being able to comfortably use GPU accelerated websites.
I’d love to know more about the security implications of doing this if anyone has more insight. Presumably you’re opening up any qubes you share the GPU with to compromising each other via the GPU, (even though only one qube is connected at a time). But would dom0 and friends also become more vulnerable, or would all other qubes be business at usual?
Running a browser doesn’t work out of the box, but you might be able to make it work if you configure the GPU in xorg.conf.
Without any extra configuration, it only seems to be 3d application it’s able to automatically offload. Lutris will also tell you vulkan isn’t working, but it works just fine when you start a game.
I’m very interested in your seamless GPU acceleration by Hybrid Graphics. I am actually looking forward to purchasing a motherboard that has a support on Hybrid Graphics. I’ve searched this feature if it is only your board that supports, but managed to find that a few more MSI boards seem to support this.
I am curious if anyone else knows other boards that offer the so called the “Hybrid Graphics” thing (possibily as some other name depending on manufactuers). The key is of course, no dedicated monitor connection for each dGPU but the seamless passthrough described by @anon40243023.
Before you spend a lot of money on new hardware, read this thread:
In some games it works out-of-the-box, but in other games it will be extremely difficult to get it to work.
Revisiting this thread… as I expect to purchase a motherboard (probably with AMD CPU) near future.
The curiosity on whether only MSI supports this still remains until now. The best way to verify this would be actual seamless acceleration tests done by the community (or even me) (and thanks for this @anon40243023 :blush:), but so far happens to be only this thread. Limited to MSI boards leaves far fewer choices, and even support list from MSI is outdated (early 2024). Don’t know if support is general for boards with newer chipsets like X870E, B850 and so on.
What’s even worse: native PS/2 port viable through ‘very few’ A or B boards. No PS/2 for high-end boards. This means for more PCIe slots, sacrifice PS/2 :cry:
