Hello!
Has anyone tried to run HCL Notes, an email client for HCL Domino (formerly IBM Domino Lotus Notes) on Qubes?
Best regards,
Max
Hello!
Best regards,
Max
Generally the rule is: if it runs on linux, it runs on Qubes. Might be more difficult to install, though.
So I’d suggest that you search on the internet for that product on Linux and I’m certain you’ll find there more answers.
Thanks! Will try the Linux version.
