Using Graphic/Drawing Tablet on Qubes OS
Hello everyone,
I’m trying to use my graphic tablet with on Qubes R4.2.2 for a while and tried almost every method that written in Qubes Forum but still have some problems with it. There is two ways to use drawing tablet on Qubes OS with some trade-offs:
  1. Connecting graphic tablet directly to dom0
    • Advantages:
      • You can see where you draw through the general system cursor of dom0
    • Disadvantages:
      • You can’t use the buttons of graphic tablet, because you shouldn’t run the
        graphic tablet app image on dom0
      • Some potential security issues that could arise from the direct connection of
        graphic tablet to dom0
      • Decreased drawing quality due to abrupt drawing from dom0
  2. Connecting graphic tablet to App VM
    • Advantages:
      • Normal / High quality drawing
      • Recognizes pen pressure
      • Can use tablet buttons
      • Can use all functionality of graphic tablet
    • Disadvantages:
      • Can’t see the cursor. (Actually that disadvantage is enough on its own, because
        you can’t draw anything if you don’t see where you are
        drawing)
So, besides asking the solution of that problem, I can suggest some potential solutions that I couldn’t figure out how to apply:
  • dom0 can recognize graphic tablet read only and can just show the cursor and
    App VM can recognize it as write and execute, so that all functionalities can be
    used.
  • Mouse cursor layers could be implemented on Qubes OS, so that you can select
    the graphic tablet cursor to be used on App VM and dom0 cursor for all other
    qubes and for system general
Yeah I also would really like to get this implemented, somehow I am currently making it work by directly connecting it to the VM.
I just remembered that it will probably work without much trouble if you create a qube with a normal linux ISO (Just like a windows VM) you will just need to add some qubes packages manually (qubes file transfer etc…) if needed.
Don’t forget that you have to configure networking manually. (Wait maybe there is some qubes package that you could install for that?)
You can just remove the qubes-gui-agent from the template instead of installing OS from ISO and installing agents there:
You can try this:
Running e.g. sway with WLR_NO_HARDWARE_CURSORS=1 will show the full sway desktop with mouse cursor visible and you can run your app inside sway in fullscreen.
