This is probably a really dumb question, but I’m trying to implement split-gpg and following the documentation. When I attempted sudo apt install, I get “command not found”.
I’ve also noticed apt isn’t in /etc and was thinking this has to do with dom0 being based on Fedora. How do I go about resolving this?
Dom0 wouldn’t have apt as it is not based on debian (only debian-based linux distributions use apt). Fedora-based ones (as dom0 is) use the dnf command. However, because dom0 is disconnected from the internet you use instead the command sudo qubes-dom0-update <PACKAGE> which is basically the same as saying sudo dnf install <PACKAGE>.
