I’d like to use android as a net qube to take advantage of a free vpn only available on android.
Is this possible? If so, does it require any special steps? Is there any way I can do a backup killswitch setup in qubes in case the one in the vpn android app doesn’t work?
No.
How familiar are you with android networking and iptables?
How familiar are you with nftables and Qubes networking?
The usual configuration is this - Pray this comes out OK -:
NIC
sys-net
sys-firewall
qube qube .......
What you want is this:
firewall
android qube......
NIC
On the Android qube you will need to configure forwarding and NAT.
On the firewall qube you change the rules to allow for inter qube traffic.
Many problems that people have in Qubes are actually not Qubes specific.
This is one of those.
You can find guides online to configuring NAT in android that should help you.
The only Qubes specific part is configuring the firewall qube to pass
through traffic. It is documented in the Qubes docs.
(I’m assuming that you understand how to attach the NIC to the android
qube. Configuring networking using that NIC is an android issue, not
Qubes.)
My familiarity with iptables is next to zero. My familiarity with android networking is zero.
I appreciate the diagram and the instructions, but I have no idea where to begin with either 1. or 2.
Does anyone know how to do this? I really don’t understand why I have to go to great lengths in configuration to use android as proxy. This is qubes, after all isn’t it? If I need to do all kinds of special configuration, couldn’t I accomplish the same thing in ANY other operating system the way whonix does?
