I want to use my Microsoft Sculpt wireless keyboard and mouse with Qubes OS. When I plug in the USB dongle I used to get the notification that Keyboard access was denied. I could however use the mouse just fine. I followed the instructions on the Qubes documentation to allow USB keyboard usage. After doing that and restarting my machine I no longer get the Keyboard access denied message when I plug in the dongle but I still cannot use the keyboard, only the mouse. Can anyone help?
- Are you in R4.0?
- In sys-usb is the package qubes-input-proxy-sender installed (most likely yes, since your mouse works)
- In dom0 what is the contents of your /etc/qubes-rpc/policy/qubes.InputKeyboard?
You want it to be like this:
sys-usb dom0 ask,default_target=dom0
$anyvm $anyvm deny
(Post typed on a M$ Sculpt wireless keyboard under Qubes R4.0
I’m on 4.1
Yes, it’s installed
It used to be
#!/usr/bin/sh sys-usb dom0 ask,default_target=dom0I changed it to
#!/usr/bin/sh sys-usb dom0 ask,default_target=dom0 $anyvm $anyvm denyand restarted my laptop but that does not seem to have an effect.
R4.1 has a changed policy system I haven’t worked with yet.
I understand you now have to look under /etc/qubes/policy.d/
I’m still on R4.0 so I have no experience with it yet.
Yes - in 4.1 there are policy files are in /etc/qubes/policy.d/.
Qubes ships a default file in 90-default.policy, which contains most
of the default policy settings.
If you want to change a policy, you create a new lower numbered file - e.g.
30-user.policy, and write your new policy there.
That said, there are still policy files under /etc/qubes-rpc/policy, and
the InputMouse and InputKeyboard files are there.
The line you’ve quoted looks right to me, but I don’t have the bash
shebang at all.
Try it with sys-usb dom0 allow - you shouldn’t need to restart the
laptop, although it wont hurt.
I changed the contents of /etc/qubes-rpc/policy/qubes.InputKeyboard to be just the single line sys-usb dom0 allow. This didn’t seem to have any effect immediatley, so I restart my laptop. When being asked for my disk encryption password I could successfully enter that using the USB keyboard. However, once I reached the login screen typing on the USB keyboard no longer had any effect.
I’m using Qubes with KDE. Could that be the source of the issue? Is there anything I have to change in the KDE settings to make the keyboard be recognized?
You could check by selecting Xfce at the login, but I doubt this is the
problem.
Is the keyboard recognised in sys-usb?
If you open a terminal in sys-usb, can you type there with the keyboard?
Typing in the sys-usb terminal does work indeed…
Switching to Xfce did not have any effect.
