I would like each time I plug a usb key into my computer (under qubeOS), a vm opens to be able to read the contents of the key in isolation
Once the key is removed the vm self-destructs.
If it is also possible to have logs on this vm.
Is it possible to do this in qube os ?
How I read is that user wants Qubes to assign USB flash to dispVM to automount it and with autostarting Thunar or Nautilus there, immediately upon the flash is plugged in to the port and attached to sys-usb, regardless of sys-usb is disposable or not?
