USB keyboard and mouse stop working when KVM switches away, no sys-usb installed
I’ve installed Qubes 4.2.3 on a Thinkcentre M75q gen 2 to evaluate. I have a CK Lau USB KVM switch connected and a USB keyboard and Logitech wireless mouse plugged into the KVM.
If I boot the Thinkcentre while the KVM is looking at it, the mouse and keyboard work great. When I switch to another computer for a while and switch back, the keyboard does not work and the mouse moves the screen pointer but will not select anything.
I installed without sys-usb. Have tried sys-usb on other installs with similar problems.
Keyboard and mouse do work properly after a power cycle.
I pasted partial output of journalctl (copied to manually mounted USB drive in dom0 after reboot) below. Lines like “Device /dev/input/event9 is already in dom0” do not look good, but I don’t know how this is supposed to work.
I would like to resolve this as I want to use qubes as a replacement for seperate virtualbox VMs for web browsing and email. I don’t need ultimate security from physical or USB attacks on this machine. Can anybody help? Qubes doc is pretty good as far as it goes, but no help here.
dom0 journalctl excerpt:
Oct 20 12:10:41 dom0 kernel: usb 3-1.2.2: new high-speed USB device number 8 using xhci_hcd
Oct 20 12:10:41 dom0 kernel: usb 3-1.2.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
Oct 20 12:10:41 dom0 kernel: usb 3-1.2.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Oct 20 12:10:41 dom0 kernel: usb 3-1.2.2: Product: USB 2.0 Hub
Oct 20 12:10:41 dom0 kernel: hub 3-1.2.2:1.0: USB hub found
Oct 20 12:10:41 dom0 kernel: hub 3-1.2.2:1.0: 4 ports detected
Oct 20 12:10:42 dom0 kernel: usb 3-1.2.2.1: new full-speed USB device number 9 using xhci_hcd
Oct 20 12:10:42 dom0 kernel: usb 3-1.2.2.1: New USB device found, idVendor=2f68, idProduct=0082, bcdDevice= 1.07
Oct 20 12:10:42 dom0 kernel: usb 3-1.2.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Oct 20 12:10:42 dom0 kernel: usb 3-1.2.2.1: Product: DURGOD Taurus K320
Oct 20 12:10:42 dom0 kernel: usb 3-1.2.2.1: Manufacturer: Hoksi Technology
Oct 20 12:10:42 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.0/0003:2F68:0082.000C/input/input31
Oct 20 12:10:42 dom0 kernel: hid-generic 0003:2F68:0082.000C: input,hidraw4: USB HID v1.10 Keyboard [Hoksi Technology DURGOD Taurus K320] on usb-0000:04:00.4-1.2.2.1/input0
Oct 20 12:10:42 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 System Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.000D/input/input32
Oct 20 12:10:42 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.000D/input/input33
Oct 20 12:10:42 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 Keyboard as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.000D/input/input34
Oct 20 12:10:42 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 Mouse as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.000D/input/input35
Oct 20 12:10:42 dom0 kernel: hid-generic 0003:2F68:0082.000D: input,hidraw5: USB HID v1.10 Keyboard [Hoksi Technology DURGOD Taurus K320] on usb-0000:04:00.4-1.2.2.1/input1
Oct 20 12:10:42 dom0 kernel: hid-generic 0003:2F68:0082.000E: hiddev96,hidraw6: USB HID v1.10 Device [Hoksi Technology DURGOD Taurus K320] on usb-0000:04:00.4-1.2.2.1/input2
Oct 20 12:10:43 dom0 systemd[1]: Started qubes-input-sender-keyboard@event12.service - Qubes input proxy sender (keyboard).
Oct 20 12:10:43 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 kernel: audit: type=1130 audit(1729444243.139:401): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 qubes-input-sender[4564]: Device /dev/input/event12 is already in dom0
Oct 20 12:10:43 dom0 systemd[1]: qubes-input-sender-keyboard@event12.service: Deactivated successfully.
Oct 20 12:10:43 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 kernel: audit: type=1131 audit(1729444243.141:402): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 systemd-logind[2007]: Watching system buttons on /dev/input/event12 (Hoksi Technology DURGOD Taurus K320 Keyboard)
Oct 20 12:10:43 dom0 systemd[1]: Started qubes-input-sender-keyboard@event10.service - Qubes input proxy sender (keyboard).
Oct 20 12:10:43 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 kernel: audit: type=1130 audit(1729444243.152:403): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 qubes-input-sender[4567]: Device /dev/input/event10 is already in dom0
Oct 20 12:10:43 dom0 systemd[1]: Started qubes-input-sender-keyboard@event11.service - Qubes input proxy sender (keyboard).
Oct 20 12:10:43 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 kernel: audit: type=1130 audit(1729444243.154:404): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 systemd[1]: qubes-input-sender-keyboard@event10.service: Deactivated successfully.
Oct 20 12:10:43 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 kernel: audit: type=1131 audit(1729444243.155:405): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 qubes-input-sender[4568]: Device /dev/input/event11 is already in dom0
Oct 20 12:10:43 dom0 systemd[1]: qubes-input-sender-keyboard@event11.service: Deactivated successfully.
Oct 20 12:10:43 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 kernel: audit: type=1131 audit(1729444243.157:406): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 systemd[1]: Started qubes-input-sender-keyboard@event9.service - Qubes input proxy sender (keyboard).
Oct 20 12:10:43 dom0 kernel: usb 3-1.2.2.2: new full-speed USB device number 10 using xhci_hcd
Oct 20 12:10:43 dom0 kernel: audit: type=1130 audit(1729444243.164:407): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 systemd-logind[2007]: Watching system buttons on /dev/input/event10 (Hoksi Technology DURGOD Taurus K320 System Control)
Oct 20 12:10:43 dom0 qubes-input-sender[4570]: Device /dev/input/event9 is already in dom0
Oct 20 12:10:43 dom0 systemd[1]: qubes-input-sender-keyboard@event9.service: Deactivated successfully.
Oct 20 12:10:43 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 kernel: audit: type=1131 audit(1729444243.168:408): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 systemd-logind[2007]: Watching system buttons on /dev/input/event11 (Hoksi Technology DURGOD Taurus K320 Consumer Control)
Oct 20 12:10:43 dom0 systemd[1]: Started qubes-input-sender-mouse@event13.service - Qubes input proxy sender (mouse).
Oct 20 12:10:43 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 kernel: audit: type=1130 audit(1729444243.172:409): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 systemd-logind[2007]: Watching system buttons on /dev/input/event9 (Hoksi Technology DURGOD Taurus K320)
Oct 20 12:10:43 dom0 qubes-input-sender[4573]: Device /dev/input/event13 is already in dom0
Oct 20 12:10:43 dom0 systemd[1]: qubes-input-sender-mouse@event13.service: Deactivated successfully.
Oct 20 12:10:43 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 kernel: audit: type=1131 audit(1729444243.175:410): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 kernel: usb 3-1.2.2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.01
Oct 20 12:10:43 dom0 kernel: usb 3-1.2.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Oct 20 12:10:43 dom0 kernel: usb 3-1.2.2.2: Product: USB Receiver
Oct 20 12:10:43 dom0 kernel: usb 3-1.2.2.2: Manufacturer: Logitech
Oct 20 12:10:43 dom0 kernel: logitech-djreceiver 0003:046D:C52B.0011: hiddev97,hidraw7: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-1.2.2.2/input2
Oct 20 12:10:43 dom0 kernel: input: Logitech M315/M235 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.2/3-1.2.2.2:1.2/0003:046D:C52B.0011/0003:046D:4009.0012/input/input36
Oct 20 12:10:43 dom0 kernel: logitech-hidpp-device 0003:046D:4009.0012: input,hidraw8: USB HID v1.11 Mouse [Logitech M315/M235] on usb-0000:04:00.4-1.2.2.2/input2:1
Oct 20 12:10:43 dom0 systemd[1]: Started qubes-input-sender-mouse@event17.service - Qubes input proxy sender (mouse).
Oct 20 12:10:43 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event17 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:43 dom0 qubes-input-sender[4637]: Device /dev/input/event17 is already in dom0
Oct 20 12:10:43 dom0 systemd[1]: qubes-input-sender-mouse@event17.service: Deactivated successfully.
Oct 20 12:10:43 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event17 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:10:46 dom0 xscreensaver-auth[4640]: PAM unable to dlopen(/usr/lib64/security/pam_sss.so): /usr/lib64/security/pam_sss.so: cannot open shared object file: No such file or directory
Oct 20 12:10:46 dom0 xscreensaver-auth[4640]: PAM adding faulty module: /usr/lib64/security/pam_sss.so
Oct 20 12:10:48 dom0 kernel: logitech-hidpp-device 0003:046D:4009.0012: HID++ 2.0 device connected.
Oct 20 12:11:16 dom0 kernel: usb 3-1.2.2: USB disconnect, device number 8
Oct 20 12:11:16 dom0 kernel: usb 3-1.2.2.1: USB disconnect, device number 9
Oct 20 12:11:17 dom0 kernel: usb 3-1.2.2.2: USB disconnect, device number 10
Oct 20 12:11:21 dom0 kernel: usb 3-1.2.2: new high-speed USB device number 11 using xhci_hcd
Oct 20 12:11:21 dom0 kernel: usb 3-1.2.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
Oct 20 12:11:21 dom0 kernel: usb 3-1.2.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Oct 20 12:11:21 dom0 kernel: usb 3-1.2.2: Product: USB 2.0 Hub
Oct 20 12:11:21 dom0 kernel: hub 3-1.2.2:1.0: USB hub found
Oct 20 12:11:21 dom0 kernel: hub 3-1.2.2:1.0: 4 ports detected
Oct 20 12:11:22 dom0 kernel: usb 3-1.2.2.1: new full-speed USB device number 12 using xhci_hcd
Oct 20 12:11:22 dom0 kernel: usb 3-1.2.2.1: New USB device found, idVendor=2f68, idProduct=0082, bcdDevice= 1.07
Oct 20 12:11:22 dom0 kernel: usb 3-1.2.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Oct 20 12:11:22 dom0 kernel: usb 3-1.2.2.1: Product: DURGOD Taurus K320
Oct 20 12:11:22 dom0 kernel: usb 3-1.2.2.1: Manufacturer: Hoksi Technology
Oct 20 12:11:22 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.0/0003:2F68:0082.0013/input/input37
Oct 20 12:11:22 dom0 kernel: hid-generic 0003:2F68:0082.0013: input,hidraw4: USB HID v1.10 Keyboard [Hoksi Technology DURGOD Taurus K320] on usb-0000:04:00.4-1.2.2.1/input0
Oct 20 12:11:22 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 System Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.0014/input/input38
Oct 20 12:11:22 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.0014/input/input39
Oct 20 12:11:22 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 Keyboard as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.0014/input/input40
Oct 20 12:11:22 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 Mouse as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.0014/input/input41
Oct 20 12:11:22 dom0 kernel: hid-generic 0003:2F68:0082.0014: input,hidraw5: USB HID v1.10 Keyboard [Hoksi Technology DURGOD Taurus K320] on usb-0000:04:00.4-1.2.2.1/input1
Oct 20 12:11:22 dom0 kernel: hid-generic 0003:2F68:0082.0015: hiddev96,hidraw6: USB HID v1.10 Device [Hoksi Technology DURGOD Taurus K320] on usb-0000:04:00.4-1.2.2.1/input2
Oct 20 12:11:22 dom0 systemd[1]: Started qubes-input-sender-keyboard@event11.service - Qubes input proxy sender (keyboard).
Oct 20 12:11:22 dom0 qubes-input-sender[4892]: Device /dev/input/event11 is already in dom0
Oct 20 12:11:22 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 20 12:11:22 dom0 kernel: audit: type=1130 audit(1729444282.958:413): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 systemd[1]: qubes-input-sender-keyboard@event11.service: Deactivated successfully.
Oct 20 12:11:22 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 kernel: audit: type=1131 audit(1729444282.961:414): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 kernel: usb 3-1.2.2.2: new full-speed USB device number 13 using xhci_hcd
Oct 20 12:11:22 dom0 systemd-logind[2007]: Watching system buttons on /dev/input/event11 (Hoksi Technology DURGOD Taurus K320 Consumer Control)
Oct 20 12:11:22 dom0 systemd[1]: Started qubes-input-sender-keyboard@event12.service - Qubes input proxy sender (keyboard).
Oct 20 12:11:22 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 systemd-logind[2007]: Watching system buttons on /dev/input/event12 (Hoksi Technology DURGOD Taurus K320 Keyboard)
Oct 20 12:11:22 dom0 kernel: audit: type=1130 audit(1729444282.974:415): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 qubes-input-sender[4895]: Device /dev/input/event12 is already in dom0
Oct 20 12:11:22 dom0 systemd[1]: Started qubes-input-sender-mouse@event13.service - Qubes input proxy sender (mouse).
Oct 20 12:11:22 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 kernel: audit: type=1130 audit(1729444282.977:416): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 systemd[1]: qubes-input-sender-keyboard@event12.service: Deactivated successfully.
Oct 20 12:11:22 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 kernel: audit: type=1131 audit(1729444282.978:417): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 qubes-input-sender[4896]: Device /dev/input/event13 is already in dom0
Oct 20 12:11:22 dom0 systemd[1]: qubes-input-sender-mouse@event13.service: Deactivated successfully.
Oct 20 12:11:22 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 kernel: audit: type=1131 audit(1729444282.980:418): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 systemd[1]: Started qubes-input-sender-keyboard@event10.service - Qubes input proxy sender (keyboard).
Oct 20 12:11:22 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 kernel: audit: type=1130 audit(1729444282.986:419): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 qubes-input-sender[4898]: Device /dev/input/event10 is already in dom0
Oct 20 12:11:22 dom0 systemd[1]: qubes-input-sender-keyboard@event10.service: Deactivated successfully.
Oct 20 12:11:22 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 kernel: audit: type=1131 audit(1729444282.989:420): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 systemd[1]: Started qubes-input-sender-keyboard@event9.service - Qubes input proxy sender (keyboard).
Oct 20 12:11:22 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 kernel: audit: type=1130 audit(1729444282.993:421): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 systemd-logind[2007]: Watching system buttons on /dev/input/event10 (Hoksi Technology DURGOD Taurus K320 System Control)
Oct 20 12:11:22 dom0 qubes-input-sender[4900]: Device /dev/input/event9 is already in dom0
Oct 20 12:11:22 dom0 systemd[1]: qubes-input-sender-keyboard@event9.service: Deactivated successfully.
Oct 20 12:11:22 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:22 dom0 kernel: audit: type=1131 audit(1729444282.997:422): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:23 dom0 systemd-logind[2007]: Watching system buttons on /dev/input/event9 (Hoksi Technology DURGOD Taurus K320)
Oct 20 12:11:23 dom0 kernel: usb 3-1.2.2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.01
Oct 20 12:11:23 dom0 kernel: usb 3-1.2.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Oct 20 12:11:23 dom0 kernel: usb 3-1.2.2.2: Product: USB Receiver
Oct 20 12:11:23 dom0 kernel: usb 3-1.2.2.2: Manufacturer: Logitech
Oct 20 12:11:23 dom0 kernel: logitech-djreceiver 0003:046D:C52B.0018: hiddev97,hidraw7: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-1.2.2.2/input2
Oct 20 12:11:24 dom0 kernel: logitech-hidpp-device 0003:046D:4009.0019: HID++ 2.0 device connected.
Oct 20 12:11:25 dom0 kernel: input: Logitech M315/M235 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.2/3-1.2.2.2:1.2/0003:046D:C52B.0018/0003:046D:4009.0019/input/input42
Oct 20 12:11:25 dom0 kernel: logitech-hidpp-device 0003:046D:4009.0019: input,hidraw8: USB HID v1.11 Mouse [Logitech M315/M235] on usb-0000:04:00.4-1.2.2.2/input2:1
Oct 20 12:11:25 dom0 systemd[1]: Started qubes-input-sender-mouse@event17.service - Qubes input proxy sender (mouse).
Oct 20 12:11:25 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event17 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:25 dom0 qubes-input-sender[4977]: Device /dev/input/event17 is already in dom0
Oct 20 12:11:25 dom0 systemd[1]: qubes-input-sender-mouse@event17.service: Deactivated successfully.
Oct 20 12:11:25 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event17 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 20 12:11:25 dom0 xscreensaver-auth[4980]: PAM unable to dlopen(/usr/lib64/security/pam_sss.so): /usr/lib64/security/pam_sss.so: cannot open shared object file: No such file or directory
Oct 20 12:11:25 dom0 xscreensaver-auth[4980]: PAM adding faulty module: /usr/lib64/security/pam_sss.so
Oct 20 12:11:29 dom0 xscreensaver-auth[4980]: pam_unix(xscreensaver:auth): authentication failure; logname= uid=1000 euid=1000 tty=:0.0 ruser= rhost=  user=rbleidt
Oct 20 12:11:31 dom0 xscreensaver-auth[4980]: Failed login on display ":0.0" for "rbleidt"
Oct 20 12:11:33 dom0 xscreensaver-auth[4986]: PAM unable to dlopen(/usr/lib64/security/pam_sss.so): /usr/lib64/security/pam_sss.so: cannot open shared object file: No such file or directory
Oct 20 12:11:33 dom0 xscreensaver-auth[4986]: PAM adding faulty module: /usr/lib64/security/pam_sss.so
Oct 20 12:12:37 dom0 kernel: usb 3-1.2.2: USB disconnect, device number 11
Oct 20 12:12:37 dom0 kernel: usb 3-1.2.2.1: USB disconnect, device number 12
Oct 20 12:12:38 dom0 kernel: usb 3-1.2.2.2: USB disconnect, device number 13
Oct 20 12:13:19 dom0 kernel: usb 3-1.2.2: new high-speed USB device number 14 using xhci_hcd
Oct 20 12:13:19 dom0 kernel: usb 3-1.2.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
Oct 20 12:13:19 dom0 kernel: usb 3-1.2.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Oct 20 12:13:19 dom0 kernel: usb 3-1.2.2: Product: USB 2.0 Hub
Oct 20 12:13:19 dom0 kernel: hub 3-1.2.2:1.0: USB hub found
Oct 20 12:13:19 dom0 kernel: hub 3-1.2.2:1.0: 4 ports detected
Maybe the screensaver is crashing?
Do you see any change in the desktop image in this state if you wait for a while? Like time changing in the system tray?
Try to type the password blindly and press on the Enter key.
Thanks for the quick reply. I have the screen saver turned off. That was one of the first things I tried. So, no password to enter, the screen does not time out.
You have a good question though - I just checked and the time in the upper right corner is stuck on the time yesterday when it stopped working.
So, what does that indicate?
Check the log in dom0, maybe Xorg crashed for some reason.
You can also try to switch to another TTY by pressing Ctrl+Alt+F2.
Crtl Alt F2 worked!
Transferring logs to other machine, but have to go to meeting, back in few hours.
rb720@imagecircuits.com
Well, I would like to reply here, but this forum says “new users cannot upload files” and if I paste text, it says “there cannot be more than two links in a post.”
If I look at Xorg.0.log.old, I see the last lines of the file filled with NULs.
The last text before that is:
[ 4260.283] (–) modeset(0): HDMI max TMDS frequency 300000KHz
[ 4268.245] (II) modeset(0): EDID vendor “GSM”, prod id 30470
[ 4268.245] (II) modeset(0): Using hsync ranges from config file
[ 4268.245] (II) modeset(0): Using vrefresh ranges from config file
[ 4268.245] (II) modeset(0): Printing DDC gathered Modelines:
[ 4268.245] (II) modeset(0): Modeline "3840x2160"x0.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz eP)
[ 4268.245] (II) modeset(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[ 4268.245] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 4268.245] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 4268.245] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 4268.245] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 4268.245] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 4268.245] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 4268.245] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 4268.245] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 4268.245] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 4268.245] (II) modeset(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz e)
[ 4268.245] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 4268.245] (II) modeset(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 4268.245] (II) modeset(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 4268.245] (–) modeset(0): HDMI max TMDS frequency 300000KHz
[ 4332.290] (II) event9 - Hoksi Technology DURGOD Taurus K320: device removed
[ 4332.499] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320
[ 4332.500] (II) UnloadModule: “libinput”
[ 4332.657] (II) event10 - Hoksi Technology DURGOD Taurus K320 System Control: device removed
[ 4332.757] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320 System Control
[ 4332.758] (II) UnloadModule: “libinput”
[ 4332.770] (II) event11 - Hoksi Technology DURGOD Taurus K320 Consumer Control: device removed
[ 4332.809] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320 Consumer Control
[ 4332.811] (II) UnloadModule: “libinput”
[ 4332.812] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320 Consumer Control
[ 4332.813] (II) UnloadModule: “libinput”
[ 4332.976] (II) event12 - Hoksi Technology DURGOD Taurus K320 Keyboard: device removed
[ 4333.053] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320 Keyboard
[ 4333.055] (II) UnloadModule: “libinput”
[ 4333.088] (II) event13 - Hoksi Technology DURGOD Taurus K320 Mouse: device removed
[ 4333.125] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320 Mouse
[ 4333.128] (II) UnloadModule: “libinput”
[ 4333.241] (II) event17 - Logitech M315/M235: device removed
[ 4333.282] (II) config/udev: removing device Logitech M315/M235
[ 4333.284] (II) UnloadModule: “libinput”
[ 4374.337] (II) modeset(0): EDID vendor “GSM”, prod id 30470
[ 4374.337] (II) modeset(0): Using hsync ranges from config file
[ 4374.337] (II) modeset(0): Using vrefresh ranges from config file
[ 4374.337] (II) modeset(0): Printing DDC gathered Modelines:
[ 4374.337] (II) modeset(0): Modeline "3840x2160"x0.0 297.00 3840 4016 4104 4400 2160 2168 2178 2250 +hsync +vsync (67.5 kHz eP)
[ 4374.337] (II) modeset(0): Modeline "2560x1440"x0.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[ 4374.337] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 4374.337] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 4374.337] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 4374.337] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 4374.337] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 4374.337] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 4374.337] (II) modeset(0): Modeline "720x576"x0.0 27.00
Any thoughts?
You can put the link in the preformatted text block between ``` e.g.:
https://forum.qubes-os.org
Or single ` like this:
Check the dom0 log using journalctl command. Find the log at the time when you’ve switched KVM from Qubes OS PC to another PC.
Excerpt from journalctl output below. I switched the KVM away at 16:36 and switched back at 16:50. About 16:52 I used Cntl-Alt-F2 to switch to the console screen.
Oct 21 16:36:31 dom0 kernel: usb 3-1.2.2: USB disconnect, device number 5
Oct 21 16:36:31 dom0 kernel: usb 3-1.2.2.1: USB disconnect, device number 6
Oct 21 16:36:31 dom0 kernel: usb 3-1.2.2.2: USB disconnect, device number 7
Oct 21 16:38:16 dom0 qrexec-policy-daemon[2018]: qrexec: qubes.NotifyUpdates+: sys-firewall -> @adminvm: allowed to dom0
Oct 21 16:38:16 dom0 audit: BPF prog-id=49 op=LOAD
Oct 21 16:38:16 dom0 kernel: audit: type=1334 audit(1729546696.911:391): prog-id=49 op=LOAD
Oct 21 16:38:16 dom0 kernel: audit: type=1334 audit(1729546696.911:392): prog-id=50 op=LOAD
Oct 21 16:38:16 dom0 kernel: audit: type=1334 audit(1729546696.912:393): prog-id=51 op=LOAD
Oct 21 16:38:16 dom0 audit: BPF prog-id=50 op=LOAD
Oct 21 16:38:16 dom0 audit: BPF prog-id=51 op=LOAD
Oct 21 16:38:16 dom0 systemd[1]: Starting systemd-hostnamed.service - Hostname Service...
Oct 21 16:38:16 dom0 systemd[1]: Started systemd-hostnamed.service - Hostname Service.
Oct 21 16:38:16 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:38:16 dom0 kernel: audit: type=1130 audit(1729546696.959:394): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:38:17 dom0 qui-updates[3005]: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
Oct 21 16:38:21 dom0 qrexec-policy-daemon[2018]: qrexec: qubes.NotifyUpdates+: sys-net -> @adminvm: allowed to dom0
Oct 21 16:38:27 dom0 qrexec-policy-daemon[2018]: qrexec: qubes.NotifyUpdates+: personal -> @adminvm: allowed to dom0
Oct 21 16:38:31 dom0 qrexec-policy-daemon[2018]: qrexec: qubes.NotifyUpdates+: sys-whonix -> @adminvm: allowed to dom0
Oct 21 16:38:37 dom0 systemd[2831]: Created slice background.slice - User Background Tasks Slice.
Oct 21 16:38:37 dom0 systemd[2831]: Starting systemd-tmpfiles-clean.service - Cleanup of User's Temporary Files and Directories...
Oct 21 16:38:37 dom0 systemd[2831]: Finished systemd-tmpfiles-clean.service - Cleanup of User's Temporary Files and Directories.
Oct 21 16:39:01 dom0 systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Oct 21 16:39:01 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:39:01 dom0 kernel: audit: type=1131 audit(1729546741.580:395): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:39:01 dom0 audit: BPF prog-id=51 op=UNLOAD
Oct 21 16:39:01 dom0 audit: BPF prog-id=50 op=UNLOAD
Oct 21 16:39:01 dom0 audit: BPF prog-id=49 op=UNLOAD
Oct 21 16:39:01 dom0 kernel: audit: type=1334 audit(1729546741.610:396): prog-id=51 op=UNLOAD
Oct 21 16:39:01 dom0 kernel: audit: type=1334 audit(1729546741.610:397): prog-id=50 op=UNLOAD
Oct 21 16:39:01 dom0 kernel: audit: type=1334 audit(1729546741.610:398): prog-id=49 op=UNLOAD
Oct 21 16:48:37 dom0 systemd[1]: Starting systemd-tmpfiles-clean.service - Cleanup of Temporary Directories...
Oct 21 16:48:37 dom0 systemd[1]: systemd-tmpfiles-clean.service: Deactivated successfully.
Oct 21 16:48:37 dom0 systemd[1]: Finished systemd-tmpfiles-clean.service - Cleanup of Temporary Directories.
Oct 21 16:48:37 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:48:37 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:48:37 dom0 kernel: audit: type=1130 audit(1729547317.503:399): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:48:37 dom0 kernel: audit: type=1131 audit(1729547317.503:400): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:45 dom0 kernel: usb 3-1.2.2: new high-speed USB device number 8 using xhci_hcd
Oct 21 16:50:45 dom0 kernel: usb 3-1.2.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
Oct 21 16:50:45 dom0 kernel: usb 3-1.2.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Oct 21 16:50:45 dom0 kernel: usb 3-1.2.2: Product: USB 2.0 Hub
Oct 21 16:50:45 dom0 kernel: hub 3-1.2.2:1.0: USB hub found
Oct 21 16:50:45 dom0 kernel: hub 3-1.2.2:1.0: 4 ports detected
Oct 21 16:50:45 dom0 kernel: usb 3-1.2.2.1: new full-speed USB device number 9 using xhci_hcd
Oct 21 16:50:45 dom0 kernel: usb 3-1.2.2.1: New USB device found, idVendor=2f68, idProduct=0082, bcdDevice= 1.07
Oct 21 16:50:45 dom0 kernel: usb 3-1.2.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Oct 21 16:50:45 dom0 kernel: usb 3-1.2.2.1: Product: DURGOD Taurus K320
Oct 21 16:50:45 dom0 kernel: usb 3-1.2.2.1: Manufacturer: Hoksi Technology
Oct 21 16:50:46 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.0/0003:2F68:0082.000C/input/input31
Oct 21 16:50:46 dom0 kernel: hid-generic 0003:2F68:0082.000C: input,hidraw4: USB HID v1.10 Keyboard [Hoksi Technology DURGOD Taurus K320] on usb-0000:04:00.4-1.2.2.1/input0
Oct 21 16:50:46 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 System Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.000D/input/input32
Oct 21 16:50:46 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.000D/input/input33
Oct 21 16:50:46 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 Keyboard as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.000D/input/input34
Oct 21 16:50:46 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 Mouse as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.000D/input/input35
Oct 21 16:50:46 dom0 kernel: hid-generic 0003:2F68:0082.000D: input,hidraw5: USB HID v1.10 Keyboard [Hoksi Technology DURGOD Taurus K320] on usb-0000:04:00.4-1.2.2.1/input1
Oct 21 16:50:46 dom0 kernel: hid-generic 0003:2F68:0082.000E: hiddev96,hidraw6: USB HID v1.10 Device [Hoksi Technology DURGOD Taurus K320] on usb-0000:04:00.4-1.2.2.1/input2
Oct 21 16:50:46 dom0 systemd-logind[1868]: Watching system buttons on /dev/input/event10 (Hoksi Technology DURGOD Taurus K320 System Control)
Oct 21 16:50:46 dom0 systemd[1]: Started qubes-input-sender-keyboard@event10.service - Qubes input proxy sender (keyboard).
Oct 21 16:50:46 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 kernel: audit: type=1130 audit(1729547446.376:401): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 qubes-input-sender[4446]: Device /dev/input/event10 is already in dom0
Oct 21 16:50:46 dom0 systemd[1]: qubes-input-sender-keyboard@event10.service: Deactivated successfully.
Oct 21 16:50:46 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 kernel: audit: type=1131 audit(1729547446.379:402): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 kernel: usb 3-1.2.2.2: new full-speed USB device number 10 using xhci_hcd
Oct 21 16:50:46 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 kernel: audit: type=1130 audit(1729547446.396:403): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 systemd[1]: Started qubes-input-sender-keyboard@event11.service - Qubes input proxy sender (keyboard).
Oct 21 16:50:46 dom0 qubes-input-sender[4452]: Device /dev/input/event11 is already in dom0
Oct 21 16:50:46 dom0 systemd[1]: Started qubes-input-sender-keyboard@event9.service - Qubes input proxy sender (keyboard).
Oct 21 16:50:46 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 systemd-logind[1868]: Watching system buttons on /dev/input/event9 (Hoksi Technology DURGOD Taurus K320)
Oct 21 16:50:46 dom0 kernel: audit: type=1130 audit(1729547446.400:404): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 qubes-input-sender[4453]: Device /dev/input/event9 is already in dom0
Oct 21 16:50:46 dom0 systemd[1]: Started qubes-input-sender-mouse@event13.service - Qubes input proxy sender (mouse).
Oct 21 16:50:46 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 systemd-logind[1868]: Watching system buttons on /dev/input/event11 (Hoksi Technology DURGOD Taurus K320 Consumer Control)
Oct 21 16:50:46 dom0 kernel: audit: type=1130 audit(1729547446.403:405): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 systemd[1]: qubes-input-sender-keyboard@event11.service: Deactivated successfully.
Oct 21 16:50:46 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 systemd[1]: qubes-input-sender-keyboard@event9.service: Deactivated successfully.
Oct 21 16:50:46 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 kernel: audit: type=1131 audit(1729547446.405:406): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 kernel: audit: type=1131 audit(1729547446.405:407): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 qubes-input-sender[4454]: Device /dev/input/event13 is already in dom0
Oct 21 16:50:46 dom0 systemd[1]: qubes-input-sender-mouse@event13.service: Deactivated successfully.
Oct 21 16:50:46 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 kernel: audit: type=1131 audit(1729547446.407:408): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 systemd[1]: Started qubes-input-sender-keyboard@event12.service - Qubes input proxy sender (keyboard).
Oct 21 16:50:46 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 kernel: audit: type=1130 audit(1729547446.411:409): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 qubes-input-sender[4456]: Device /dev/input/event12 is already in dom0
Oct 21 16:50:46 dom0 systemd[1]: qubes-input-sender-keyboard@event12.service: Deactivated successfully.
Oct 21 16:50:46 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 kernel: audit: type=1131 audit(1729547446.414:410): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:46 dom0 systemd-logind[1868]: Watching system buttons on /dev/input/event12 (Hoksi Technology DURGOD Taurus K320 Keyboard)
Oct 21 16:50:46 dom0 kernel: usb 3-1.2.2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.01
Oct 21 16:50:46 dom0 kernel: usb 3-1.2.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Oct 21 16:50:46 dom0 kernel: usb 3-1.2.2.2: Product: USB Receiver
Oct 21 16:50:46 dom0 kernel: usb 3-1.2.2.2: Manufacturer: Logitech
Oct 21 16:50:46 dom0 kernel: logitech-djreceiver 0003:046D:C52B.0011: hiddev97,hidraw7: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-1.2.2.2/input2
Oct 21 16:50:47 dom0 kernel: logitech-hidpp-device 0003:046D:4009.0012: HID++ 2.0 device connected.
Oct 21 16:50:47 dom0 kernel: input: Logitech M315/M235 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.2/3-1.2.2.2:1.2/0003:046D:C52B.0011/0003:046D:4009.0012/input/input36
Oct 21 16:50:47 dom0 kernel: logitech-hidpp-device 0003:046D:4009.0012: input,hidraw8: USB HID v1.11 Mouse [Logitech M315/M235] on usb-0000:04:00.4-1.2.2.2/input2:1
Oct 21 16:50:47 dom0 systemd[1]: Started qubes-input-sender-mouse@event15.service - Qubes input proxy sender (mouse).
Oct 21 16:50:47 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event15 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:47 dom0 qubes-input-sender[4530]: Device /dev/input/event15 is already in dom0
Oct 21 16:50:47 dom0 systemd[1]: qubes-input-sender-mouse@event15.service: Deactivated successfully.
Oct 21 16:50:47 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event15 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:50:47 dom0 xscreensaver-auth[4532]: PAM unable to dlopen(/usr/lib64/security/pam_sss.so): /usr/lib64/security/pam_sss.so: cannot open shared object file: No such file or directory
Oct 21 16:50:47 dom0 xscreensaver-auth[4532]: PAM adding faulty module: /usr/lib64/security/pam_sss.so
Oct 21 16:51:16 dom0 kernel: usb 3-1.2.2: USB disconnect, device number 8
Oct 21 16:51:16 dom0 kernel: usb 3-1.2.2.1: USB disconnect, device number 9
Oct 21 16:51:17 dom0 kernel: usb 3-1.2.2.2: USB disconnect, device number 10
Oct 21 16:51:52 dom0 kernel: usb 3-1.2.2: new high-speed USB device number 11 using xhci_hcd
Oct 21 16:51:53 dom0 kernel: usb 3-1.2.2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
Oct 21 16:51:53 dom0 kernel: usb 3-1.2.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Oct 21 16:51:53 dom0 kernel: usb 3-1.2.2: Product: USB 2.0 Hub
Oct 21 16:51:53 dom0 kernel: hub 3-1.2.2:1.0: USB hub found
Oct 21 16:51:53 dom0 kernel: hub 3-1.2.2:1.0: 4 ports detected
Oct 21 16:51:53 dom0 kernel: usb 3-1.2.2.1: new full-speed USB device number 12 using xhci_hcd
Oct 21 16:51:53 dom0 kernel: usb 3-1.2.2.1: New USB device found, idVendor=2f68, idProduct=0082, bcdDevice= 1.07
Oct 21 16:51:53 dom0 kernel: usb 3-1.2.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Oct 21 16:51:53 dom0 kernel: usb 3-1.2.2.1: Product: DURGOD Taurus K320
Oct 21 16:51:53 dom0 kernel: usb 3-1.2.2.1: Manufacturer: Hoksi Technology
Oct 21 16:51:53 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.0/0003:2F68:0082.0013/input/input37
Oct 21 16:51:54 dom0 kernel: hid-generic 0003:2F68:0082.0013: input,hidraw4: USB HID v1.10 Keyboard [Hoksi Technology DURGOD Taurus K320] on usb-0000:04:00.4-1.2.2.1/input0
Oct 21 16:51:54 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 System Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.0014/input/input38
Oct 21 16:51:54 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.0014/input/input39
Oct 21 16:51:54 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 Keyboard as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.0014/input/input40
Oct 21 16:51:54 dom0 kernel: input: Hoksi Technology DURGOD Taurus K320 Mouse as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.0014/input/input41
Oct 21 16:51:54 dom0 kernel: hid-generic 0003:2F68:0082.0014: input,hidraw5: USB HID v1.10 Keyboard [Hoksi Technology DURGOD Taurus K320] on usb-0000:04:00.4-1.2.2.1/input1
Oct 21 16:51:54 dom0 kernel: hid-generic 0003:2F68:0082.0015: hiddev96,hidraw6: USB HID v1.10 Device [Hoksi Technology DURGOD Taurus K320] on usb-0000:04:00.4-1.2.2.1/input2
Oct 21 16:51:54 dom0 systemd[1]: Started qubes-input-sender-keyboard@event12.service - Qubes input proxy sender (keyboard).
Oct 21 16:51:54 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 kernel: kauditd_printk_skb: 2 callbacks suppressed
Oct 21 16:51:54 dom0 kernel: audit: type=1130 audit(1729547514.235:413): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 qubes-input-sender[4781]: Device /dev/input/event12 is already in dom0
Oct 21 16:51:54 dom0 systemd[1]: qubes-input-sender-keyboard@event12.service: Deactivated successfully.
Oct 21 16:51:54 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 kernel: audit: type=1131 audit(1729547514.239:414): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event12 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 systemd-logind[1868]: Watching system buttons on /dev/input/event12 (Hoksi Technology DURGOD Taurus K320 Keyboard)
Oct 21 16:51:54 dom0 systemd[1]: Started qubes-input-sender-keyboard@event10.service - Qubes input proxy sender (keyboard).
Oct 21 16:51:54 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 kernel: audit: type=1130 audit(1729547514.251:415): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 qubes-input-sender[4784]: Device /dev/input/event10 is already in dom0
Oct 21 16:51:54 dom0 systemd[1]: Started qubes-input-sender-keyboard@event11.service - Qubes input proxy sender (keyboard).
Oct 21 16:51:54 dom0 systemd-logind[1868]: Watching system buttons on /dev/input/event11 (Hoksi Technology DURGOD Taurus K320 Consumer Control)
Oct 21 16:51:54 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 systemd[1]: qubes-input-sender-keyboard@event10.service: Deactivated successfully.
Oct 21 16:51:54 dom0 kernel: audit: type=1130 audit(1729547514.255:416): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 kernel: audit: type=1131 audit(1729547514.256:417): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event10 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 qubes-input-sender[4785]: Device /dev/input/event11 is already in dom0
Oct 21 16:51:54 dom0 systemd[1]: qubes-input-sender-keyboard@event11.service: Deactivated successfully.
Oct 21 16:51:54 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 kernel: audit: type=1131 audit(1729547514.258:418): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event11 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 kernel: usb 3-1.2.2.2: new full-speed USB device number 13 using xhci_hcd
Oct 21 16:51:54 dom0 systemd-logind[1868]: Watching system buttons on /dev/input/event10 (Hoksi Technology DURGOD Taurus K320 System Control)
Oct 21 16:51:54 dom0 systemd[1]: Started qubes-input-sender-keyboard@event9.service - Qubes input proxy sender (keyboard).
Oct 21 16:51:54 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 kernel: audit: type=1130 audit(1729547514.265:419): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 qubes-input-sender[4787]: Device /dev/input/event9 is already in dom0
Oct 21 16:51:54 dom0 systemd[1]: Started qubes-input-sender-mouse@event13.service - Qubes input proxy sender (mouse).
Oct 21 16:51:54 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 kernel: audit: type=1130 audit(1729547514.268:420): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 systemd[1]: qubes-input-sender-keyboard@event9.service: Deactivated successfully.
Oct 21 16:51:54 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 kernel: audit: type=1131 audit(1729547514.269:421): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-keyboard@event9 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 qubes-input-sender[4788]: Device /dev/input/event13 is already in dom0
Oct 21 16:51:54 dom0 systemd[1]: qubes-input-sender-mouse@event13.service: Deactivated successfully.
Oct 21 16:51:54 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 kernel: audit: type=1131 audit(1729547514.271:422): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event13 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:51:54 dom0 systemd-logind[1868]: Watching system buttons on /dev/input/event9 (Hoksi Technology DURGOD Taurus K320)
Oct 21 16:51:54 dom0 kernel: usb 3-1.2.2.2: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.01
Oct 21 16:51:54 dom0 kernel: usb 3-1.2.2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Oct 21 16:51:54 dom0 kernel: usb 3-1.2.2.2: Product: USB Receiver
Oct 21 16:51:54 dom0 kernel: usb 3-1.2.2.2: Manufacturer: Logitech
Oct 21 16:51:54 dom0 kernel: logitech-djreceiver 0003:046D:C52B.0018: hiddev97,hidraw7: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:04:00.4-1.2.2.2/input2
Oct 21 16:52:00 dom0 kernel: logitech-hidpp-device 0003:046D:4009.0019: HID++ 2.0 device connected.
Oct 21 16:52:00 dom0 kernel: input: Logitech M315/M235 as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.2/3-1.2.2.2:1.2/0003:046D:C52B.0018/0003:046D:4009.0019/input/input42
Oct 21 16:52:00 dom0 kernel: logitech-hidpp-device 0003:046D:4009.0019: input,hidraw8: USB HID v1.11 Mouse [Logitech M315/M235] on usb-0000:04:00.4-1.2.2.2/input2:1
Oct 21 16:52:00 dom0 systemd[1]: Started qubes-input-sender-mouse@event15.service - Qubes input proxy sender (mouse).
Oct 21 16:52:00 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event15 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:52:00 dom0 kernel: audit: type=1130 audit(1729547520.713:423): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event15 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:52:00 dom0 qubes-input-sender[4856]: Device /dev/input/event15 is already in dom0
Oct 21 16:52:00 dom0 systemd[1]: qubes-input-sender-mouse@event15.service: Deactivated successfully.
Oct 21 16:52:00 dom0 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event15 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:52:00 dom0 kernel: audit: type=1131 audit(1729547520.716:424): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=qubes-input-sender-mouse@event15 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:52:00 dom0 xscreensaver-auth[4858]: PAM unable to dlopen(/usr/lib64/security/pam_sss.so): /usr/lib64/security/pam_sss.so: cannot open shared object file: No such file or directory
Oct 21 16:52:00 dom0 xscreensaver-auth[4858]: PAM adding faulty module: /usr/lib64/security/pam_sss.so
Oct 21 16:52:08 dom0 systemd[1]: Started getty@tty2.service - Getty on tty2.
Oct 21 16:52:08 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:52:08 dom0 kernel: audit: type=1130 audit(1729547528.042:425): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 21 16:52:11 dom0 login[4869]: PAM unable to dlopen(/usr/lib64/security/pam_sss.so): /usr/lib64/security/pam_sss.so: cannot open shared object file: No such file or directory
Oct 21 16:52:11 dom0 login[4869]: PAM adding faulty module: /usr/lib64/security/pam_sss.so
Oct 21 16:52:12 dom0 audit[4869]: USER_AUTH pid=4869 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_usertype,pam_localuser,pam_unix acct="rbleidt" exe="/usr/bin/login" hostname=dom0 addr=? terminal=/dev/tty2 res=success'
Oct 21 16:52:12 dom0 audit[4869]: USER_ACCT pid=4869 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix,pam_localuser acct="rbleidt" exe="/usr/bin/login" hostname=dom0 addr=? terminal=/dev/tty2 res=success'
Oct 21 16:52:12 dom0 kernel: audit: type=1100 audit(1729547532.493:426): pid=4869 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_usertype,pam_localuser,pam_unix acct="rbleidt" exe="/usr/bin/login" hostname=dom0 addr=? terminal=/dev/tty2 res=success'
Oct 21 16:52:12 dom0 kernel: audit: type=1101 audit(1729547532.493:427): pid=4869 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_unix,pam_localuser acct="rbleidt" exe="/usr/bin/login" hostname=dom0 addr=? terminal=/dev/tty2 res=success'
Oct 21 16:52:12 dom0 audit[4869]: CRED_ACQ pid=4869 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_localuser,pam_unix acct="rbleidt" exe="/usr/bin/login" hostname=dom0 addr=? terminal=/dev/tty2 res=success'
Oct 21 16:52:12 dom0 audit[4869]: SYSCALL arch=c000003e syscall=1 success=yes exit=4 a0=3 a1=7ffe280ca280 a2=4 a3=7ffe280c9f94 items=0 ppid=1 pid=4869 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty2 ses=4 comm="login" exe="/usr/bin/login" key=(null)
Oct 21 16:52:12 dom0 audit: PROCTITLE proctitle=2F62696E2F6C6F67696E002D70002D2D
Oct 21 16:52:12 dom0 kernel: audit: type=1103 audit(1729547532.494:428): pid=4869 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_localuser,pam_unix acct="rbleidt" exe="/usr/bin/login" hostname=dom0 addr=? terminal=/dev/tty2 res=success'
Oct 21 16:52:12 dom0 kernel: audit: type=1006 audit(1729547532.494:429): pid=4869 uid=0 old-auid=4294967295 auid=1000 tty=tty2 old-ses=4294967295 ses=4 res=1
Oct 21 16:52:12 dom0 kernel: audit: type=1300 audit(1729547532.494:429): arch=c000003e syscall=1 success=yes exit=4 a0=3 a1=7ffe280ca280 a2=4 a3=7ffe280c9f94 items=0 ppid=1 pid=4869 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty2 ses=4 comm="login" exe="/usr/bin/login" key=(null)
Oct 21 16:52:12 dom0 kernel: audit: type=1327 audit(1729547532.494:429): proctitle=2F62696E2F6C6F67696E002D70002D2D
Oct 21 16:52:12 dom0 systemd-logind[1868]: New session 4 of user rbleidt.
Oct 21 16:52:12 dom0 systemd[1]: Started session-4.scope - Session 4 of User rbleidt.
Oct 21 16:52:12 dom0 login[4869]: pam_unix(login:session): session opened for user rbleidt(uid=1000) by LOGIN(uid=0)
Oct 21 16:52:12 dom0 audit[4869]: USER_START pid=4869 uid=0 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_selinux,pam_loginuid,pam_selinux,pam_namespace,pam_keyinit,pam_keyinit,pam_limits,pam_systemd,pam_unix,pam_umask,pam_lastlog acct="rbleidt" exe="/usr/bin/login" hostname=dom0 addr=? terminal=/dev/tty2 res=success'
Oct 21 16:52:12 dom0 audit[4869]: CRED_REFR pid=4869 uid=0 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_localuser,pam_unix acct="rbleidt" exe="/usr/bin/login" hostname=dom0 addr=? terminal=/dev/tty2 res=success'
Oct 21 16:52:12 dom0 audit[4869]: USER_LOGIN pid=4869 uid=0 auid=1000 ses=4 msg='op=login id=1000 exe="/usr/bin/login" hostname=dom0 addr=? terminal=tty2 res=success'
Oct 21 16:52:12 dom0 login[4869]: LOGIN ON tty2 BY rbleidt
Oct 21 16:52:12 dom0 kernel: audit: type=1105 audit(1729547532.514:430): pid=4869 uid=0 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_selinux,pam_loginuid,pam_selinux,pam_namespace,pam_keyinit,pam_keyinit,pam_limits,pam_systemd,pam_unix,pam_umask,pam_lastlog acct="rbleidt" exe="/usr/bin/login" hostname=dom0 addr=? terminal=/dev/tty2 res=success'
Oct 21 16:52:12 dom0 kernel: audit: type=1110 audit(1729547532.514:431): pid=4869 uid=0 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_localuser,pam_unix acct="rbleidt" exe="/usr/bin/login" hostname=dom0 addr=? terminal=/dev/tty2 res=success'
Oct 21 16:52:12 dom0 kernel: audit: type=1112 audit(1729547532.514:432): pid=4869 uid=0 auid=1000 ses=4 msg='op=login id=1000 exe="/usr/bin/login" hostname=dom0 addr=? terminal=tty2 res=success'
Oct 21 16:52:12 dom0 audit: BPF prog-id=52 op=LOAD
Oct 21 16:52:12 dom0 audit: BPF prog-id=53 op=LOAD
Oct 21 16:52:12 dom0 audit: BPF prog-id=54 op=LOAD
Oct 21 16:52:12 dom0 systemd[1]: Starting systemd-hostnamed.service - Hostname Service...
Oct 21 16:52:12 dom0 systemd[1]: Started systemd-hostnamed.service - Hostname Service.
Oct 21 16:52:12 dom0 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
I have some experience with Linux, but not Qubes, so I’m limited in what I can figure out, but it appears the system saw the KVM disconnect at 16:36:31, nothing else logged.
When the KVM reconnects at 16:50:45, I see log entries for starting and then stopping services like “qubes-input-sender-keyboard@event12”.
Any thoughts?
I don’t see anything related in the log.
Can you upload Xorg log at the same time from 16:36 to 16:52?
This took some time as I had to find a script to convert boot time values to wall clock time.
2024-10-21 16:36:33] (II) event9  - Hoksi Technology DURGOD Taurus K320: device removed
[2024-10-21 16:36:33] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320
[2024-10-21 16:36:33] (II) UnloadModule: "libinput"
[2024-10-21 16:36:33] (II) event10 - Hoksi Technology DURGOD Taurus K320 System Control: device removed
[2024-10-21 16:36:33] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320 System Control
[2024-10-21 16:36:33] (II) event11 - Hoksi Technology DURGOD Taurus K320 Consumer Control: device removed
[2024-10-21 16:36:33] (II) event12 - Hoksi Technology DURGOD Taurus K320 Keyboard: device removed
[2024-10-21 16:36:33] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320 Consumer Control
[2024-10-21 16:36:33] (II) event13 - Hoksi Technology DURGOD Taurus K320 Mouse: device removed
[2024-10-21 16:36:33] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320 Keyboard
[2024-10-21 16:36:33] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320 Mouse
[2024-10-21 16:36:34] (II) event15 - Logitech M315/M235: device removed
[2024-10-21 16:36:34] (II) config/udev: removing device Logitech M315/M235
[2024-10-21 16:36:34] (II) UnloadModule: "libinput"
[2024-10-21 16:50:47] (II) modeset(0): EDID vendor "GSM", prod id 30470
[2024-10-21 16:50:47] (II) modeset(0): Using hsync ranges from config file
[2024-10-21 16:50:47] (II) modeset(0): Using vrefresh ranges from config file
[2024-10-21 16:50:47] (II) modeset(0): Printing DDC gathered Modelines:
[2024-10-21 16:50:47] (II) modeset(0): Modeline "3840x2160"x0.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.5 kHz eP)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "1920x1080"x0.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz e)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[2024-10-21 16:50:47] (II) modeset(0): Modeline "1280x800"x0.0   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[2024-10-21 16:50:47] (--) modeset(0): HDMI max TMDS frequency 300000KHz
[2024-10-21 16:50:48] (II) config/udev: Adding input device Hoksi Technology DURGOD Taurus K320 Mouse (/dev/input/mouse1)
[2024-10-21 16:50:48] (II) No input driver specified, ignoring this device.
[2024-10-21 16:50:48] (II) This device may have been added with another device file.
[2024-10-21 16:50:48] (II) config/udev: Adding input device Hoksi Technology DURGOD Taurus K320 System Control (/dev/input/event10)
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 System Control: Applying InputClass "evdev keyboard catchall"
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 System Control: Applying InputClass "libinput keyboard catchall"
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 System Control: Applying InputClass "system-keyboard"
[2024-10-21 16:50:48] (II) Using input driver 'libinput' for 'Hoksi Technology DURGOD Taurus K320 System Control'
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 System Control: always reports core events
[2024-10-21 16:50:48] (**) Option "Device" "/dev/input/event10"
[2024-10-21 16:50:48] (II) event10 - Hoksi Technology DURGOD Taurus K320 System Control: is tagged by udev as: Keyboard
[2024-10-21 16:50:48] (II) event10 - Hoksi Technology DURGOD Taurus K320 System Control: device is a keyboard
[2024-10-21 16:50:48] (II) event10 - Hoksi Technology DURGOD Taurus K320 System Control: device removed
[2024-10-21 16:50:48] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.000D/input/input32/event10"
[2024-10-21 16:50:48] (II) XINPUT: Adding extended input device "Hoksi Technology DURGOD Taurus K320 System Control" (type: KEYBOARD, id 15)
[2024-10-21 16:50:48] (**) Option "xkb_layout" "us"
[2024-10-21 16:50:48] (II) config/udev: Adding input device Hoksi Technology DURGOD Taurus K320 (/dev/input/event9)
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320: Applying InputClass "evdev keyboard catchall"
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320: Applying InputClass "libinput keyboard catchall"
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320: Applying InputClass "system-keyboard"
[2024-10-21 16:50:48] (II) Using input driver 'libinput' for 'Hoksi Technology DURGOD Taurus K320'
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320: always reports core events
[2024-10-21 16:50:48] (**) Option "Device" "/dev/input/event9"
[2024-10-21 16:50:48] (II) event9  - Hoksi Technology DURGOD Taurus K320: is tagged by udev as: Keyboard
[2024-10-21 16:50:48] (II) event9  - Hoksi Technology DURGOD Taurus K320: device is a keyboard
[2024-10-21 16:50:48] (II) event9  - Hoksi Technology DURGOD Taurus K320: device removed
[2024-10-21 16:50:48] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.0/0003:2F68:0082.000C/input/input31/event9"
[2024-10-21 16:50:48] (II) XINPUT: Adding extended input device "Hoksi Technology DURGOD Taurus K320" (type: KEYBOARD, id 16)
[2024-10-21 16:50:48] (II) config/udev: Adding input device Hoksi Technology DURGOD Taurus K320 Mouse (/dev/input/event13)
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Mouse: Applying InputClass "evdev pointer catchall"
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Mouse: Applying InputClass "libinput pointer catchall"
[2024-10-21 16:50:48] (II) Using input driver 'libinput' for 'Hoksi Technology DURGOD Taurus K320 Mouse'
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Mouse: always reports core events
[2024-10-21 16:50:48] (**) Option "Device" "/dev/input/event13"
[2024-10-21 16:50:48] (II) event13 - Hoksi Technology DURGOD Taurus K320 Mouse: is tagged by udev as: Mouse
[2024-10-21 16:50:48] (II) event13 - Hoksi Technology DURGOD Taurus K320 Mouse: device is a pointer
[2024-10-21 16:50:48] (II) event13 - Hoksi Technology DURGOD Taurus K320 Mouse: device removed
[2024-10-21 16:50:48] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.000D/input/input35/event13"
[2024-10-21 16:50:48] (II) XINPUT: Adding extended input device "Hoksi Technology DURGOD Taurus K320 Mouse" (type: MOUSE, id 17)
[2024-10-21 16:50:48] (**) Option "AccelerationScheme" "none"
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Mouse: (accel) selected scheme none/0
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Mouse: (accel) acceleration factor: 2.000
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Mouse: (accel) acceleration threshold: 4
[2024-10-21 16:50:48] (II) config/udev: Adding input device Hoksi Technology DURGOD Taurus K320 Consumer Control (/dev/input/event11)
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: Applying InputClass "evdev keyboard catchall"
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: Applying InputClass "libinput keyboard catchall"
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: Applying InputClass "system-keyboard"
[2024-10-21 16:50:48] (II) Using input driver 'libinput' for 'Hoksi Technology DURGOD Taurus K320 Consumer Control'
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: always reports core events
[2024-10-21 16:50:48] (**) Option "Device" "/dev/input/event11"
[2024-10-21 16:50:48] (II) event11 - Hoksi Technology DURGOD Taurus K320 Consumer Control: is tagged by udev as: Keyboard
[2024-10-21 16:50:48] (II) event11 - Hoksi Technology DURGOD Taurus K320 Consumer Control: device is a keyboard
[2024-10-21 16:50:48] (II) event11 - Hoksi Technology DURGOD Taurus K320 Consumer Control: device removed
[2024-10-21 16:50:48] (II) libinput: Hoksi Technology DURGOD Taurus K320 Consumer Control: needs a virtual subdevice
[2024-10-21 16:50:48] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.000D/input/input33/event11"
[2024-10-21 16:50:48] (II) XINPUT: Adding extended input device "Hoksi Technology DURGOD Taurus K320 Consumer Control" (type: MOUSE, id 18)
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: (accel) selected scheme none/0
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: (accel) acceleration factor: 2.000
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: (accel) acceleration threshold: 4
[2024-10-21 16:50:48] (II) libinput: Hoksi Technology DURGOD Taurus K320 Consumer Control: is a virtual subdevice
[2024-10-21 16:50:48] (II) XINPUT: Adding extended input device "Hoksi Technology DURGOD Taurus K320 Consumer Control" (type: KEYBOARD, id 19)
[2024-10-21 16:50:48] (II) config/udev: Adding input device Hoksi Technology DURGOD Taurus K320 Keyboard (/dev/input/event12)
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Keyboard: Applying InputClass "evdev keyboard catchall"
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Keyboard: Applying InputClass "libinput keyboard catchall"
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Keyboard: Applying InputClass "system-keyboard"
[2024-10-21 16:50:48] (II) Using input driver 'libinput' for 'Hoksi Technology DURGOD Taurus K320 Keyboard'
[2024-10-21 16:50:48] (**) Hoksi Technology DURGOD Taurus K320 Keyboard: always reports core events
[2024-10-21 16:50:48] (**) Option "Device" "/dev/input/event12"
[2024-10-21 16:50:48] (II) event12 - Hoksi Technology DURGOD Taurus K320 Keyboard: is tagged by udev as: Keyboard
[2024-10-21 16:50:48] (II) event12 - Hoksi Technology DURGOD Taurus K320 Keyboard: device is a keyboard
[2024-10-21 16:50:48] (II) event12 - Hoksi Technology DURGOD Taurus K320 Keyboard: device removed
[2024-10-21 16:50:48] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.000D/input/input34/event12"
[2024-10-21 16:50:48] (II) XINPUT: Adding extended input device "Hoksi Technology DURGOD Taurus K320 Keyboard" (type: KEYBOARD, id 20)
[2024-10-21 16:50:49] (II) config/udev: Adding input device Logitech M315/M235 (/dev/input/mouse2)
[2024-10-21 16:50:49] (II) No input driver specified, ignoring this device.
[2024-10-21 16:50:49] (II) This device may have been added with another device file.
[2024-10-21 16:50:49] (II) config/udev: Adding input device Logitech M315/M235 (/dev/input/event15)
[2024-10-21 16:50:49] (**) Logitech M315/M235: Applying InputClass "evdev pointer catchall"
[2024-10-21 16:50:49] (**) Logitech M315/M235: Applying InputClass "libinput pointer catchall"
[2024-10-21 16:50:49] (II) Using input driver 'libinput' for 'Logitech M315/M235'
[2024-10-21 16:50:49] (**) Logitech M315/M235: always reports core events
[2024-10-21 16:50:49] (**) Option "Device" "/dev/input/event15"
[2024-10-21 16:50:49] (II) event15 - Logitech M315/M235: is tagged by udev as: Mouse
[2024-10-21 16:50:49] (II) event15 - Logitech M315/M235: device is a pointer
[2024-10-21 16:50:49] (II) event15 - Logitech M315/M235: device removed
[2024-10-21 16:50:49] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.2/3-1.2.2.2:1.2/0003:046D:C52B.0011/0003:046D:4009.0012/input/input36/event15"
[2024-10-21 16:50:49] (II) XINPUT: Adding extended input device "Logitech M315/M235" (type: MOUSE, id 21)
[2024-10-21 16:50:49] (**) Option "AccelerationScheme" "none"
[2024-10-21 16:50:49] (**) Logitech M315/M235: (accel) selected scheme none/0
[2024-10-21 16:50:49] (**) Logitech M315/M235: (accel) acceleration factor: 2.000
[2024-10-21 16:50:49] (**) Logitech M315/M235: (accel) acceleration threshold: 4
[2024-10-21 16:50:49] (II) modeset(0): EDID vendor "GSM", prod id 30470
[2024-10-21 16:50:49] (II) modeset(0): Using hsync ranges from config file
[2024-10-21 16:50:49] (II) modeset(0): Using vrefresh ranges from config file
[2024-10-21 16:50:49] (II) modeset(0): Printing DDC gathered Modelines:
[2024-10-21 16:50:49] (II) modeset(0): Modeline "3840x2160"x0.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.5 kHz eP)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "1920x1080"x0.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz e)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[2024-10-21 16:50:49] (II) modeset(0): Modeline "1280x800"x0.0   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[2024-10-21 16:50:49] (--) modeset(0): HDMI max TMDS frequency 300000KHz
[2024-10-21 16:51:18] (II) event9  - Hoksi Technology DURGOD Taurus K320: device removed
[2024-10-21 16:51:18] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320
[2024-10-21 16:51:18] (II) UnloadModule: "libinput"
[2024-10-21 16:51:18] (II) event10 - Hoksi Technology DURGOD Taurus K320 System Control: device removed
[2024-10-21 16:51:18] (II) event11 - Hoksi Technology DURGOD Taurus K320 Consumer Control: device removed
[2024-10-21 16:51:18] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320 System Control
[2024-10-21 16:51:18] (II) event12 - Hoksi Technology DURGOD Taurus K320 Keyboard: device removed
[2024-10-21 16:51:18] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320 Consumer Control
[2024-10-21 16:51:18] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320 Keyboard
[2024-10-21 16:51:18] (II) event13 - Hoksi Technology DURGOD Taurus K320 Mouse: device removed
[2024-10-21 16:51:18] (II) config/udev: removing device Hoksi Technology DURGOD Taurus K320 Mouse
[2024-10-21 16:51:19] (II) event15 - Logitech M315/M235: device removed
[2024-10-21 16:51:19] (II) config/udev: removing device Logitech M315/M235
[2024-10-21 16:51:19] (II) UnloadModule: "libinput"
[2024-10-21 16:51:55] (II) modeset(0): EDID vendor "GSM", prod id 30470
[2024-10-21 16:51:55] (II) modeset(0): Using hsync ranges from config file
[2024-10-21 16:51:55] (II) modeset(0): Using vrefresh ranges from config file
[2024-10-21 16:51:55] (II) modeset(0): Printing DDC gathered Modelines:
[2024-10-21 16:51:55] (II) modeset(0): Modeline "3840x2160"x0.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.5 kHz eP)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "1920x1080"x0.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz e)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[2024-10-21 16:51:55] (II) modeset(0): Modeline "1280x800"x0.0   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[2024-10-21 16:51:55] (--) modeset(0): HDMI max TMDS frequency 300000KHz
[2024-10-21 16:51:56] (II) config/udev: Adding input device Hoksi Technology DURGOD Taurus K320 Mouse (/dev/input/mouse1)
[2024-10-21 16:51:56] (II) No input driver specified, ignoring this device.
[2024-10-21 16:51:56] (II) This device may have been added with another device file.
[2024-10-21 16:51:56] (II) config/udev: Adding input device Hoksi Technology DURGOD Taurus K320 Keyboard (/dev/input/event12)
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Keyboard: Applying InputClass "evdev keyboard catchall"
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Keyboard: Applying InputClass "libinput keyboard catchall"
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Keyboard: Applying InputClass "system-keyboard"
[2024-10-21 16:51:56] (II) Using input driver 'libinput' for 'Hoksi Technology DURGOD Taurus K320 Keyboard'
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Keyboard: always reports core events
[2024-10-21 16:51:56] (**) Option "Device" "/dev/input/event12"
[2024-10-21 16:51:56] (II) event12 - Hoksi Technology DURGOD Taurus K320 Keyboard: is tagged by udev as: Keyboard
[2024-10-21 16:51:56] (II) event12 - Hoksi Technology DURGOD Taurus K320 Keyboard: device is a keyboard
[2024-10-21 16:51:56] (II) event12 - Hoksi Technology DURGOD Taurus K320 Keyboard: device removed
[2024-10-21 16:51:56] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.0014/input/input40/event12"
[2024-10-21 16:51:56] (II) XINPUT: Adding extended input device "Hoksi Technology DURGOD Taurus K320 Keyboard" (type: KEYBOARD, id 15)
[2024-10-21 16:51:56] (**) Option "xkb_layout" "us"
[2024-10-21 16:51:56] (II) config/udev: Adding input device Hoksi Technology DURGOD Taurus K320 Consumer Control (/dev/input/event11)
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: Applying InputClass "evdev keyboard catchall"
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: Applying InputClass "libinput keyboard catchall"
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: Applying InputClass "system-keyboard"
[2024-10-21 16:51:56] (II) Using input driver 'libinput' for 'Hoksi Technology DURGOD Taurus K320 Consumer Control'
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: always reports core events
[2024-10-21 16:51:56] (**) Option "Device" "/dev/input/event11"
[2024-10-21 16:51:56] (II) event11 - Hoksi Technology DURGOD Taurus K320 Consumer Control: is tagged by udev as: Keyboard
[2024-10-21 16:51:56] (II) event11 - Hoksi Technology DURGOD Taurus K320 Consumer Control: device is a keyboard
[2024-10-21 16:51:56] (II) event11 - Hoksi Technology DURGOD Taurus K320 Consumer Control: device removed
[2024-10-21 16:51:56] (II) libinput: Hoksi Technology DURGOD Taurus K320 Consumer Control: needs a virtual subdevice
[2024-10-21 16:51:56] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.0014/input/input39/event11"
[2024-10-21 16:51:56] (II) XINPUT: Adding extended input device "Hoksi Technology DURGOD Taurus K320 Consumer Control" (type: MOUSE, id 16)
[2024-10-21 16:51:56] (**) Option "AccelerationScheme" "none"
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: (accel) selected scheme none/0
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: (accel) acceleration factor: 2.000
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Consumer Control: (accel) acceleration threshold: 4
[2024-10-21 16:51:56] (II) libinput: Hoksi Technology DURGOD Taurus K320 Consumer Control: is a virtual subdevice
[2024-10-21 16:51:56] (II) XINPUT: Adding extended input device "Hoksi Technology DURGOD Taurus K320 Consumer Control" (type: KEYBOARD, id 17)
[2024-10-21 16:51:56] (II) config/udev: Adding input device Hoksi Technology DURGOD Taurus K320 System Control (/dev/input/event10)
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 System Control: Applying InputClass "evdev keyboard catchall"
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 System Control: Applying InputClass "libinput keyboard catchall"
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 System Control: Applying InputClass "system-keyboard"
[2024-10-21 16:51:56] (II) Using input driver 'libinput' for 'Hoksi Technology DURGOD Taurus K320 System Control'
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 System Control: always reports core events
[2024-10-21 16:51:56] (**) Option "Device" "/dev/input/event10"
[2024-10-21 16:51:56] (II) event10 - Hoksi Technology DURGOD Taurus K320 System Control: is tagged by udev as: Keyboard
[2024-10-21 16:51:56] (II) event10 - Hoksi Technology DURGOD Taurus K320 System Control: device is a keyboard
[2024-10-21 16:51:56] (II) event10 - Hoksi Technology DURGOD Taurus K320 System Control: device removed
[2024-10-21 16:51:56] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.0014/input/input38/event10"
[2024-10-21 16:51:56] (II) XINPUT: Adding extended input device "Hoksi Technology DURGOD Taurus K320 System Control" (type: KEYBOARD, id 18)
[2024-10-21 16:51:56] (II) config/udev: Adding input device Hoksi Technology DURGOD Taurus K320 (/dev/input/event9)
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320: Applying InputClass "evdev keyboard catchall"
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320: Applying InputClass "libinput keyboard catchall"
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320: Applying InputClass "system-keyboard"
[2024-10-21 16:51:56] (II) Using input driver 'libinput' for 'Hoksi Technology DURGOD Taurus K320'
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320: always reports core events
[2024-10-21 16:51:56] (**) Option "Device" "/dev/input/event9"
[2024-10-21 16:51:56] (II) event9  - Hoksi Technology DURGOD Taurus K320: is tagged by udev as: Keyboard
[2024-10-21 16:51:56] (II) event9  - Hoksi Technology DURGOD Taurus K320: device is a keyboard
[2024-10-21 16:51:56] (II) event9  - Hoksi Technology DURGOD Taurus K320: device removed
[2024-10-21 16:51:56] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.0/0003:2F68:0082.0013/input/input37/event9"
[2024-10-21 16:51:56] (II) XINPUT: Adding extended input device "Hoksi Technology DURGOD Taurus K320" (type: KEYBOARD, id 19)
[2024-10-21 16:51:56] (II) config/udev: Adding input device Hoksi Technology DURGOD Taurus K320 Mouse (/dev/input/event13)
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Mouse: Applying InputClass "evdev pointer catchall"
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Mouse: Applying InputClass "libinput pointer catchall"
[2024-10-21 16:51:56] (II) Using input driver 'libinput' for 'Hoksi Technology DURGOD Taurus K320 Mouse'
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Mouse: always reports core events
[2024-10-21 16:51:56] (**) Option "Device" "/dev/input/event13"
[2024-10-21 16:51:56] (II) event13 - Hoksi Technology DURGOD Taurus K320 Mouse: is tagged by udev as: Mouse
[2024-10-21 16:51:56] (II) event13 - Hoksi Technology DURGOD Taurus K320 Mouse: device is a pointer
[2024-10-21 16:51:56] (II) event13 - Hoksi Technology DURGOD Taurus K320 Mouse: device removed
[2024-10-21 16:51:56] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.1/3-1.2.2.1:1.1/0003:2F68:0082.0014/input/input41/event13"
[2024-10-21 16:51:56] (II) XINPUT: Adding extended input device "Hoksi Technology DURGOD Taurus K320 Mouse" (type: MOUSE, id 20)
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Mouse: (accel) selected scheme none/0
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Mouse: (accel) acceleration factor: 2.000
[2024-10-21 16:51:56] (**) Hoksi Technology DURGOD Taurus K320 Mouse: (accel) acceleration threshold: 4
[2024-10-21 16:52:02] (II) config/udev: Adding input device Logitech M315/M235 (/dev/input/mouse2)
[2024-10-21 16:52:02] (II) No input driver specified, ignoring this device.
[2024-10-21 16:52:02] (II) This device may have been added with another device file.
[2024-10-21 16:52:02] (II) config/udev: Adding input device Logitech M315/M235 (/dev/input/event15)
[2024-10-21 16:52:02] (**) Logitech M315/M235: Applying InputClass "evdev pointer catchall"
[2024-10-21 16:52:02] (**) Logitech M315/M235: Applying InputClass "libinput pointer catchall"
[2024-10-21 16:52:02] (II) Using input driver 'libinput' for 'Logitech M315/M235'
[2024-10-21 16:52:02] (**) Logitech M315/M235: always reports core events
[2024-10-21 16:52:02] (**) Option "Device" "/dev/input/event15"
[2024-10-21 16:52:02] (II) event15 - Logitech M315/M235: is tagged by udev as: Mouse
[2024-10-21 16:52:02] (II) event15 - Logitech M315/M235: device is a pointer
[2024-10-21 16:52:02] (II) event15 - Logitech M315/M235: device removed
[2024-10-21 16:52:02] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.2/3-1.2.2.2:1.2/0003:046D:C52B.0018/0003:046D:4009.0019/input/input42/event15"
[2024-10-21 16:52:02] (II) XINPUT: Adding extended input device "Logitech M315/M235" (type: MOUSE, id 21)
[2024-10-21 16:52:02] (**) Option "AccelerationScheme" "none"
[2024-10-21 16:52:02] (**) Logitech M315/M235: (accel) selected scheme none/0
[2024-10-21 16:52:02] (**) Logitech M315/M235: (accel) acceleration factor: 2.000
[2024-10-21 16:52:02] (**) Logitech M315/M235: (accel) acceleration threshold: 4
[2024-10-21 16:52:02] (II) modeset(0): EDID vendor "GSM", prod id 30470
[2024-10-21 16:52:02] (II) modeset(0): Using hsync ranges from config file
[2024-10-21 16:52:02] (II) modeset(0): Using vrefresh ranges from config file
[2024-10-21 16:52:02] (II) modeset(0): Printing DDC gathered Modelines:
[2024-10-21 16:52:02] (II) modeset(0): Modeline "3840x2160"x0.0  297.00  3840 4016 4104 4400  2160 2168 2178 2250 +hsync +vsync (67.5 kHz eP)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "2560x1440"x0.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "1920x1080"x0.0   74.25  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "1920x1080"x0.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "1280x720"x0.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "720x480"x0.0   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "720x576"x0.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz e)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[2024-10-21 16:52:02] (II) modeset(0): Modeline "1280x800"x0.0   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz e)
[2024-10-21 16:52:02] (--) modeset(0): HDMI max TMDS frequency 300000KHz
[2024-10-21 16:52:09] (II) event1  - Power Button: device removed
[2024-10-21 16:52:09] (II) event2  - Video Bus: device removed
[2024-10-21 16:52:09] (II) event0  - Power Button: device removed
[2024-10-21 16:52:09] (II) event3  - USB Keyboard-Mouse USB Keyboard-Mouse_V1.7: device removed
[2024-10-21 16:52:09] (II) event4  - USB Keyboard-Mouse USB Keyboard-Mouse_V1.7 System Control: device removed
[2024-10-21 16:52:09] (II) event5  - USB Keyboard-Mouse USB Keyboard-Mouse_V1.7 Consumer Control: device removed
[2024-10-21 16:52:09] (II) event6  - USB Keyboard-Mouse USB Keyboard-Mouse_V1.7 Mouse: device removed
[2024-10-21 16:52:09] (II) event7  - USB Keyboard-Mouse USB Keyboard-Mouse_V1.7 System Control: device removed
[2024-10-21 16:52:09] (II) event8  - USB Keyboard-Mouse USB Keyboard-Mouse_V1.7 Consumer Control: device removed
[2024-10-21 16:52:09] (II) event12 - Hoksi Technology DURGOD Taurus K320 Keyboard: device removed
[2024-10-21 16:52:09] (II) event11 - Hoksi Technology DURGOD Taurus K320 Consumer Control: device removed
[2024-10-21 16:52:09] (II) event10 - Hoksi Technology DURGOD Taurus K320 System Control: device removed
[2024-10-21 16:52:09] (II) event9  - Hoksi Technology DURGOD Taurus K320: device removed
[2024-10-21 16:52:09] (II) event13 - Hoksi Technology DURGOD Taurus K320 Mouse: device removed
[2024-10-21 16:52:09] (II) event15 - Logitech M315/M235: device removed
[2024-10-21 16:52:09] (II) AIGLX: Suspending AIGLX clients for VT switch
I don’t see any info related to your screen being frozen here as well. I’ve no idea what’s happening.
What if you try to restart lightdm service in TTY2 and then return to TTY1?
Restarting lightdm works, the desktop updates properly, mouse and keyboard restored.
I looked at lightdm.log and only see these messages around the time the switch away happens:
[+1155.71s] DEBUG: Seat seat0 changes active session to
[+1160.40s] DEBUG: Seat seat0 changes active session to 4
So, where to go from here?
Note that this computer and KVM works OK when Mint is installed on the computer, and the computer runs OK for days with Qubes installed and a dedicated keyboard and mouse attached instead of the KVM.
Are you sure that this error is around time when you switch KVM and not when you change TTY with e.g. Ctlr+Alt+F2?
The same messages are generated when you switch TTY.
No, I’m not completely sure. It’s hard to track these logs that only have boot times and not wall clock time. I can try a reboot and re-test.
Did a reboot and tested again. The Seat log messages I mentioned before are from switching to the new screen/terminal with Ctrl-Alt-F2.
Interestingly, if I don’t stay switched away from the machine for very long, it works OK on return. Switching the KVM to another machine for about 7 minutes had it working on return. Switching away for 27 minutes had it frozen on return.
systemctl restart lightdm.service fixes it.
Are you sure that you’ve disabled screensaver?
Click on the power icon in the system tray → enable Presentation mode, then try again.
Presentation mode fixed it. I had previously gone to System Settings, then XScreenSaver and turned off there.
Is there a way to debug what’s going wrong? I would eventually like to get a screen saver working and sys-usb so I can mount flash drives.
Compare the dom0 journalctl logs when you switch the KVM when screensaver in not active and when you switch the KVM with screensaver active.
On a first pass, here’s what I see as a difference:
Oct 25 07:48:04 dom0 xscreensaver-auth[14229]: PAM unable to dlopen(/usr/lib64/security/pam_sss.so): /usr/lib64/security/pam_sss.so: cannot open shared object file: No such file or directory
Oct 25 07:48:04 dom0 xscreensaver-auth[14229]: PAM adding faulty module: /usr/lib64/security/pam_sss.so
These entries are present at the time presentation mode is off and the KVM switches back to the machine.
I don’t know why this would be there - this is a simple, standalone install on my home lab network. There is no LDAP, ActiveDirectory, etc.
