Hello everyone, being desperate, I really count on your help.
Having mounted a new desktop PC specifically to install Qubes OS because my old one was unable to do so (because of the processor…), you can imagine my frustration… First of all, I followed the installation guide in the Qubes OS documentation and enabled AMD SVM and IOMMU for virtualization in my UEFI Bios. Then, to proceed to the installation, I write the iso image of Qubes OS 4.1.1 on a 8Gb USB key. I plug my USB key on the motherboard and start the computer on the USB key. GRUB starts, I select directly install Qubes OS in verbose mode in its menu. Qubes OS starts to boot and an error message appears, then the display freezes. So, as you can see, in the current state, I did not succeed in installing Qubes OS…
Before writing the error message, here is what I did to solve it:
- try the previous version 4.0.4 of Qubes OS (IMPORTANT: this version doesn’t work either!)
- try other Linux distributions (NB: They all worked fine.)
- check the integrity of the iso image.
- try other USB keys.
- write the iso image with Rufus, GNOME disks or even with dd.
- try several USB ports on my motherboard.
- try to configure the UEFI Bios properly.
- look for solutions on the internet.
Here is the error obtained with Qubes OS 4.1.1:
dracut-pre-udev[715]: modprobe: ERROR: could not insert ‘floppy’: No such device
On various other attempts, the message number varies a little but the message remains the same. That is, instead of [715], I get [716] or [717]. For exemple :
dracut-pre-udev[717]: modprobe: ERROR: could not insert ‘floppy’: No such device
Hoping that you will be able to help me. Thank you for reading!
